Twilight Zone
by 2015_PSD - 04/04/20 03:57 PM
Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
103 registered members (41Pack, 2015_PSD, 55hambone, 762fermeandyou, 01rangerxl, 928, 8 invisible), 2,458 guests, and 18 spiders.
Topics303,589
Posts5,237,888
Members71,094
Audi rings and bearings? what ones? #5378038 03/16/20 06:25 PM
R
Redright9 Offline OP
R
Hello,
I have a friend at work with a an Audi that has the 4 cylinder turbo (around MY 2000 I think), he is going to rebuild the engine and was asking me what the best rings and bearings to run are? He asked is there a difference between the cheap ones he can find or the expensive fancy coated "racing" ones..? any feedback for whats best for an Audi/VW?
Re: Audi rings and bearings? what ones? [Re: Redright9] #5378045 03/16/20 06:34 PM
2
2004tdigls Offline
2
this is what my mechanic uses, yes they are more expensive than chinesium sand castings, but they are far superior
http://www.us.mahle.com/en/motorspo...-powerpak-&-powerpak-piston-kits.jsp
Re: Audi rings and bearings? what ones? [Re: Redright9] #5378058 03/16/20 06:53 PM
bdcardinal Online Content
Online Content
Clevite for the bearings, they are owned by Mahle and used by a lot of OEMs and engine builders.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Audi rings and bearings? what ones? [Re: Redright9] #5378098 03/16/20 07:42 PM
T
tiger862 Offline
T
For Audi go with Mahle rings. I have used all sorts of bearings but I like OEM although expensive. Depending on shape of crank as to what is best as you can get a crank kit that has everything just mic it for clearances. This is a job best left for pros. Can it be done by DIY yes but lots of checks and balances needed
Tiger862
2018 Grand Caravan
Re: Audi rings and bearings? what ones? [Re: Redright9] #5378179 03/16/20 09:57 PM
Snagglefoot Offline
Mahle sounds good but keep in mind they have 160 plants world wide including 33 in China.
If you want the job done right......do it yourself.
Re: Audi rings and bearings? what ones? [Re: Snagglefoot] #5378293 03/17/20 05:33 AM
O
Olas Offline
O
China has an operational Space Program unlike a lot of other countries - their manufacturing is amongst the best in the world so the location of the Mahle plant does not matter.
Consider that Lockheed and GM are both in the US, one of them makes gold and the other makes junk so the country in which the factories are situated is not relevant, it's about choosing the right company irrespective of what country you're in.
There are manufacturers in China that make junk, but there are also lots of cars being manufactured in China - most of the car comapnies we are familiar with have manufacturing in china and so need access to components - they take their pre-existing contracts and renegotiate to get the same suppliers and the same goods at their new location.
Unless you are building an extreme-use racecar, Mahle will do you proud with rings and shells.
Cable ties should hold it
Re: Audi rings and bearings? what ones? [Re: Snagglefoot] #5378311 03/17/20 06:13 AM
T
Trav Offline
T
I just got some injector adapters and seal kit from Mahle that were made in Vietnam, no problem with the quality. The machine that produces them doesn't care where it is located or who is running it. It could be on Mars with a little green man at the controls and still spit out the same product if the raw materials are the same quality.
