When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
Oil change
by IvanPletex - 04/01/20 12:52 PM
KenoshaWizard, junipertoxic, mtnrider, Rickborn, TreyT42
71071 Registered Users
114 registered members (2009Edge, 53' Stude, AC1DD, 2015_PSD, Astro14, 16 invisible), 1,913 guests, and 25 spiders.
Topics303,443
Posts5,235,386
Members71,071
Idemitsu Type H Plus - Fluid Color #5377914 03/16/20 02:35 PM
The Critic Online Crying OP
OP Online Crying
I have installed Idemitsu Type H Plus in three Honda automatics. In each vehicle, a triple drain-and-refill was performed.
In all three vehicles, within 5k miles, the fluid has lost its red color and has turned yellow (same color as new engine oil).
Not sure why this is happening.
But from a performance standpoint, every vehicle shifted smoother compared to ATF DW1.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Idemitsu Type H Plus - Fluid Color [Re: The Critic] #5377946 03/16/20 03:41 PM
H
hallstevenson Offline
H
My understanding is with Z-1 or DW-1 fluid in Honda transmissions, "smooth" shifts are actually not desired (by design). I don't mean jarring, slamming into the next gear, but a firm gear shift is normal.
Re: Idemitsu Type H Plus - Fluid Color [Re: The Critic] #5378075 03/16/20 07:14 PM
W
WagonWheel Offline
W
I’ve noticed once it gets up to operating temp after driving on the highway for 30+ minutes, the shifts to the upper gears on my 06 Ody EX-L are a little abrupt or clunky. I use Maxlife MV ATF though.
2003 Honda Accord 2.4L 5AT - 153k miles
2006 Honda Odyssey 3.5L EX-L 127k miles (S-VCM)
Re: Idemitsu Type H Plus - Fluid Color [Re: The Critic] #5378122 03/16/20 08:08 PM
B
bbhero Offline
B
Probably a bit of oxidation going on there... My blue blue Eneos CVT fluid turned from that color to a very clear translucent motor oil color in hardly no time... No hint of blue at all... Now after 16k miles plus the fluid is hard to see on the transmission dipstick just like right after changing be the motor oil.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
