Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
Life2race, rider9195, kingsville911, B34R, ChrisSnowden
71056 Registered Users
110 registered members (10ecfarmer, 4WD, 2009Edge, 53' Stude, 2010Civic, 2K2AcuraTL, 8 invisible), 1,801 guests, and 20 spiders.
Topics303,360
Posts5,234,772
Members71,056
Good hands free DI cleaner? #5377871 03/16/20 01:44 PM
J
jayjr1105 Offline OP
J
I have bought the CRC brand in the past but that requires 2 people, one on the gas and one under the hood spraying.
I just found this stuff on Amazon and it appears to be a 1 person job... https://www.amazon.com/gp/product/B00DSMH078/ref=ask_ql_qh_dp_hza
Good stuff? How often should DI owners be running this?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: Good hands free DI cleaner? [Re: jayjr1105] #5377873 03/16/20 01:50 PM
B
blufeb95 Online Content
Online Content
B
Most manufacturers of that stuff seem recommend running it every other oil change, So like every 10-20k miles.
Re: Good hands free DI cleaner? [Re: jayjr1105] #5377912 03/16/20 02:32 PM
T
Triple_Se7en Offline
T
Get a snow brush that fits between the front of the drivers seat and the gas pedal. Fit it so the gas pedal accelerates between 2-3 grand when spraying the 2.4 GDI intake. I've don't this numerous times in 16 years with my Colorado. Not sure about my GDI yet. But I'm about to find out. Give it short spurts as rapidly as it takes to keep the engine running.
This method only requires one person. Yesterday I bought Seafoam spray with the long red, very thin straw that supposedly will let me keep the intake hose loosened, but mostly in a unclamped, closed position. That should allow the engine to run a little smoother when spraying - hope that it won't stall the idle as easy.
I plan on doing my Hyundai just prior to it's 12K OCI. All my oil changes with it are every 4K. So my plan is to spray the intake with a half-can every 12k. Someday I may need to increase the dosage to one full can of spray. I'm hoping never.
Keep Your Pistons Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: Good hands free DI cleaner? [Re: jayjr1105] #5377926 03/16/20 02:55 PM
B
Online Content
B
I think I watched a video one time where a guy got a length of hose long enough to attach to the brake booster line so that he could sit in the drivers seat and rev the car to 2-3k while spraying in the CRC cleaner, he put a rubber stopper in the end of the hose with a hole just big enough to fit the straw in.
Re: Good hands free DI cleaner? [Re: jayjr1105] #5378028 03/16/20 06:08 PM
Dave9 Offline
Never? If you try to get it clean in one shot that pulls the deposits through the engine, you'll eventually ruin your cats because it comes off in larger chunks than if it were never accumulating in the first place. It can also jam up the piston rings so you burn more oil, and suffer from blowby and oil contamination.
Someone stating they did this to a non-DI engine for a long time, isn't contradictory because non-DI doesn't build up deposits anywhere near the same rate. It is not magic in a can. It's a short term solution that causes more long term problems than if you waited and did a proper intake/valve cleaning that does not push those chunks further into the engine.
If your auto manufacturer disagrees and prescribes using it, follow their recommendation. Are there any that recommend this? If you use it otherwise and cause engine problems, that SHOULD, rightfully void your warranty if still under one. I'm not stating it would make me happy that anyone suffers loss, it's not like it's a "you deserve it" lesson, not at all, just that gummy sludge is something you do not want to pull through a modern engine.
Re: Good hands free DI cleaner? [Re: jayjr1105] #5378062 03/16/20 06:56 PM
B
benjy Offline
B
you are NOT going to clean the VALVES!! cleaners can help injectors spray better but top tier gas is said to do the same.
Re: Good hands free DI cleaner? [Re: benjy] #5378510 03/17/20 10:23 AM
M
MarkM66 Offline
M
The additive in question doesn't run through the injectors.
Re: Good hands free DI cleaner? [Re: benjy] #5378519 03/17/20 10:31 AM
J
J
Except gas doesn't touch the valves in a DI engine. thus why this product is developed.
Re: Good hands free DI cleaner? [Re: Dave9] #5378542 03/17/20 10:58 AM
J
JTK Offline
J
In line with what Dave9 said, unnecessary loading of the catalytic converters is what would concern me with frequent use of spray cleaners. Secondly, are these products really going to do anything for DI engine intake valve build-up?
Regardless, it's on my mind given I own a Nissan with the VQ35DD and haven't done a thing engine-wise aside from oil/filter changes.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
