Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
Oil change
by IvanPletex - 04/01/20 12:52 PM
New Battery --> Group 25 (stock), 24 or 34???
by gathermewool - 04/01/20 12:49 PM
KenoshaWizard, junipertoxic, mtnrider, Rickborn, TreyT42
71071 Registered Users
108 registered members (2002 Maxima SE, 53' Stude, 2K2AcuraTL, apollo18, AC1DD, 12 invisible), 1,885 guests, and 20 spiders.
Topics303,443
Posts5,235,360
Members71,071
Page 1 of 3 1 2 3
Why are 20" and 21" tires so much more $$$ than 17-18" tires? #5377800 03/16/20 12:33 PM
grampi Offline OP
I don't get it. There isn't more rubber on the larger diameter wheel size tires, in fact there's less rubber because they have shorter sidewalls. Is it more costly to manufacture tires with a larger diameter hole in the middle? Makes no sense...
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: grampi] #5377807 03/16/20 12:36 PM
J
JustN89 Offline
J
Economies of scale.
17-18" tires are much more common and therefore produced in higher quantities than 20-21" tires. As you produce more, the cost per unit gets driven down and then sold at a lower price point.
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: grampi] #5377810 03/16/20 12:38 PM
E
edyvw Offline
E
It is lower profile tire, which means sidewall have to be stronger to deal with same imperfections on the road. Also, those tires are usually higher performance category which means different rubber compound. Granted, more and more appliance vehicles are venturing into that category, and they are definitely cheaper than before, but still lower volume, higher performance and more complex product.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: grampi] #5377812 03/16/20 12:39 PM
U
userfriendly Offline
U
When I buy donuts at Tim Hortons, I pick the ones with the smallest holes.
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: grampi] #5377858 03/16/20 01:28 PM
Donald Offline
Same reason 17-18" tires are much more expensive that 13-14"
2015 Ford F-250 w/Powerstroke
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: grampi] #5377861 03/16/20 01:31 PM
9
97prizm Offline
9
Actually even finding 13" tires for my Mazda is becoming difficult. I have a feeling those tire sizes will get more expensive.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: 97prizm] #5377863 03/16/20 01:33 PM
W
Wolf359 Offline
W
Boy back in the day I remember getting a set of 155/80/13 tires for under $100. Slightly over $100 after mounting and balancing, but that was a long time ago.
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: JustN89] #5377880 03/16/20 01:59 PM
CKN Offline
Originally Posted by JustN89
Economies of scale.
Can't directly dispute this-but I will mention that many pickups come with 20's and we know how many the big three sell of those things.
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: grampi] #5377886 03/16/20 02:05 PM
B
BMWTurboDzl Offline
B
Why would you think there's less rubber? It's fairly obvious the larger tires require more material just by the weight difference. Demand also impacts cost. Unique tire sizes have limited demand which drives up cost per unit. A unique size can be large or small vs the population.
PS A/S 3+:
245/45R20 - 30 lbs
245/45R18 - 28 lbs
435i
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: BMWTurboDzl] #5377894 03/16/20 02:12 PM
grampi Offline OP
PS A/S 3+:
245/45R20 - 30 lbs
245/45R18 - 28 lbs
I guess the bigger hole in the middle of the tire adds extra weight...
shocked2
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: grampi] #5377915 03/16/20 02:37 PM
B
BMWTurboDzl Offline
B
PS A/S 3+:
245/45R20 - 30 lbs
245/45R18 - 28 lbs
shocked2
I also just wanted to apologize for my condescending answer.
435i
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: BMWTurboDzl] #5377916 03/16/20 02:40 PM
O
ondarvr Online Content
Online Content
O
PS A/S 3+:
245/45R20 - 30 lbs
245/45R18 - 28 lbs
You aren’t comparing tires of the same size, the 20” is 2” taller
You need to go to a 245/55 18 to get the same diameter to compare the weight.
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: BMWTurboDzl] #5377917 03/16/20 02:40 PM
grampi Offline OP
PS A/S 3+:
245/45R20 - 30 lbs
245/45R18 - 28 lbs
shocked2
Cheers1
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: grampi] #5377920 03/16/20 02:44 PM
Quattro Pete Offline
PS A/S 3+:
245/45R20 - 30 lbs
245/45R18 - 28 lbs
shocked2
245/45R20 has larger overall diameter and circumference than 245/45R18, so more rubber is needed on the outside.
Now, if we're talking about a tire with the same overall outside diameter, just different inner diameter, then yes, the one with less sidewall should weigh less, unless that shorter sidewall is further reinforced, say like 245/55R18 vs 245/45R20.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: Why are 20" and 21" tires so much more $$$ than 17-18" tires? [Re: Quattro Pete] #5377930 03/16/20 03:04 PM
grampi Offline OP
PS A/S 3+:
245/45R20 - 30 lbs
245/45R18 - 28 lbs
shocked2
It does, but I was comparing tires that would have the same overall TIRE diameter. For example a 245/65/R18 to a 245/40/R20. In this case there would be less rubber required for the 20" tire vs the 18" tire, while overall tire diameter would be about the same...
Page 1 of 3 1 2 3
