Prolong
by IMSA_Racing_Fan - 04/04/20 01:34 AM
With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
26 registered members (dishdude, alchargo, Blkstanger, Cdn17Sport6MT, Gasbuggy, 2 invisible), 1,246 guests, and 18 spiders.
Topics303,558
Posts5,237,361
Members71,086
Gen 3 EcoDiesel - Proper oil spec? #5377636 03/16/20 07:46 AM
O
OFFRD Offline OP
O
I have a 2020 Ram 1500 with the new Gen 3 EcoDiesel engine. The owners manual is contradictory, and I want you guys' opinions on this.
Page 369 states, "The manufacturer recommends engine oils that meet the requirements of FCA Material Standard MS-10902, and that are API CJ-4 certified."
On page 370 I read, "We recommend you use 5W40 synthetic engine oil such as Mopar or Shell Rotella that meets FCA Material Standard MS-10902 and the API CJ-4 engine oil category is required."
Then on page 424 it states, "We recommend you use 5W40 synthetic engine oil such as Mopar or Pennzoil Platinumn Euro that meets FCA Material Standard MS-12991 and the API SN engine oil category is required."
An FCA forum representative claims on the Ram forum that the MS-12991 is the correct spec for this engine.
At my local stores, I've found 5W40 Shell Rotella T6 which I believe would meet the MS-10902 spec just fine, but I can't find any oil anywhere that meets MS-12991. The dealership sells it for over $10 per quart. They've quoted $250 total for oil and oil filter change.
What would you guys do? This truck has 1,000 miles on the odometer and my goal is maximum longevity.
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377646 03/16/20 08:01 AM
O
Olas Offline
O
If they quote both of those different specs in their manual then ou can use either one to keep the warranty happy.
CJ4 is more of a diesel spec than SN I'd be tempted to use CJ4 .
Pennzoil Euro had the MS-12991 specification recently, I dont know for sure if it still does but it would be worth checking
RAVENOL J1A1550 VST is 12991
Valvoline European Vehicle Full Synthetic SAE 5W-40 is 12991
Cummins CES 20081 and MS-10902 are interchangeable wink
Cable ties should hold it
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377653 03/16/20 08:10 AM
T
tundraotto Offline
T
This is a list of oils that have the Chrysler MS-12991 and API SN Certification/Standard/Approval
Pennzoil Platinum Euro 5W-40
Ravenol 5W-40 VST
Valvoline 5W-40 MST SynPower
Shell Ultra Helix 5W-40
Total Quartz 9000 5W-40
Redline Full Synthetic 5W-40
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377688 03/16/20 09:12 AM
R
racin4ds Offline
R
Wow DC is getting as bad as VW with their ludicrous oil specs and lack of product on shelves!
The trick is to find out which spec oil was for CAFE and Emissions and which one favors engine longevity!
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377692 03/16/20 09:20 AM
F
Farnsworth Offline
F
Are there any 5w 40's made that even meet the diesel specs? If not then it must be a misprint on the first recommendations. Maybe look at the dealer's mopar oil bottle to see the specs on what they would use. It says in all three of the four places to use 5w 40.
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377743 03/16/20 11:21 AM
L
loneryder Offline
L
Valvoline MST oils are C3 diesel oils. You can order them online thru NAPA or even Walmart. I've seen MST oils in Walmart but not enough quantity to change a diesel.
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377744 03/16/20 11:22 AM
L
loneryder Offline
L
Offroad, does it state anywhere in the manual about C3 oils?
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377752 03/16/20 11:30 AM
O
OVERKILL Offline
O
I would use Delvac 1 5w-40 or Rotella, something specifically developed for diesels.
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: tundraotto] #5377792 03/16/20 12:28 PM
E
edyvw Offline
E
It has DPF!
Ravenol 5W-40 VST
No, no, no! It has DPF, only ACE C3 oils should go in. FCA completely messed up their sheets after their debacle with that engine.
I am not sure where MST is available anymore as Valvoline now moved to European Vehicle full SAPS version.
OP, go online and check Motul X-Clean 5W40. Or go with Delvac 1 5W40 or Rotella 5W40 as Overkill stated.
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: loneryder] #5377833 03/16/20 12:58 PM
O
OFFRD Offline OP
O
Nope, the sentences I posted above are the ONLY mentions of oil in the manual. I've been front to back a few times, that's all it mentions.
The only info I can find online refers to the Gen 2 engine, and says that FCA switched from Pennzoil Euro to Rotella T6 recommendation after they had a rash of rod bearing failures. But, I'm under warranty and right now my main focus is not giving the dealership any reason to deny potential warranty work in the future. Hence, my confusion.
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: edyvw] #5377835 03/16/20 01:01 PM
O
OFFRD Offline OP
O
Originally Posted by edyvw
It has DPF!
Ravenol 5W-40 VST
Just to clarify, when you say "Rotella 5W40", this is the one you're speaking of, correct?
https://www.walmart.com/ip/Shell-Ro...y-Duty-Diesel-Engine-Oil-1-gal/102646780
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377954 03/16/20 03:54 PM
R
racin4ds Offline
R
It has DPF!
Ravenol 5W-40 VST
That is the one and only. Does anyone know if the new T6 formulation is low SAPS and safe for DPF?
05 F350 Powerstroke
05 Hyundai Tucson
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: racin4ds] #5377960 03/16/20 04:03 PM
4WD Offline
1
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5377990 03/16/20 04:53 PM
F
Farnsworth Offline
F
I am out of date on diesel oils, plenty of 5w 40. Personally on that kind of investment I would contact the dealer and factory as to which is right.
Re: Gen 3 EcoDiesel - Proper oil spec? [Re: OFFRD] #5378037 03/16/20 06:24 PM
J
Jimmy_Russells Offline
J
Is there an under hood sticker?
