Prolong
by IMSA_Racing_Fan - 04/04/20 01:34 AM
With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
32 registered members (Blkstanger, Cdn17Sport6MT, carlprop, blufeb95, AndyB, 2 invisible), 1,174 guests, and 17 spiders.
Topics303,558
Posts5,237,357
Members71,086
Dino oils available in Europe? #5377540 03/16/20 04:39 AM
A
allepunta Offline OP
A
Hi everyone,
seriouly considering a Auto-rx cleaning in my Euro Honda K24Z3. I read in their website it sould be performed with a dino oils (I understand Group II)
I cannot find info about wich group different oils belong to when reading the specs. Am confused, is a semi-synthetic a dino?
My car will take anything from 0w20 to 10w30. Currently using Petro Canada Supreme Synthetic 10w30.
Any ideas?
Thanks
2012 Euro Honda Accord Tourer 2.4 (CW2)
Re: Dino oils available in Europe? [Re: allepunta] #5377546 03/16/20 04:48 AM
K
Kamele0N Offline
K
Go to closest Lidl/Hofer and buy their API CD/SF 15w40...
[Linked Image from images.folders.eu]
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Dino oils available in Europe? [Re: allepunta] #5377547 03/16/20 04:51 AM
O
Olas Offline
O
'Mineral' or 'Semi Synthetic' is dinosaur oil
Shell HX5 is available in your marketplace - or use Ebay/Amazon to search for '5w30 mineral oil' or 5w30 semi synthetic'
Cable ties should hold it
Re: Dino oils available in Europe? [Re: Olas] #5377548 03/16/20 04:53 AM
K
Kamele0N Offline
K
Originally Posted by Olas
'or use Ebay/Amazon to search for '5w30 mineral oil' or 5w30 semi synthetic'
Any lawnmover Shop should have cheap Dino Sae30 oil also smile
Re: Dino oils available in Europe? [Re: allepunta] #5377567 03/16/20 05:48 AM
A
A
would something like this be ok?
https://www.landi.ch/shop/motorenoele_170702/motorenoel-5w-30-c3-okay-4-l_02738
thanks for the help guys
Re: Dino oils available in Europe? [Re: allepunta] #5377568 03/16/20 05:51 AM
Z
zeng Offline
Z
C3 can't be a group II, CMIIMW .
Re: Dino oils available in Europe? [Re: allepunta] #5377638 03/16/20 07:49 AM
O
Olas Offline
O
5w30 C3 is appropriate, it will be mostly group 3 with is semi synthetic - in Germany they would call it sythesetechnologie. It is not Vollsythetische
Re: Dino oils available in Europe? [Re: allepunta] #5377669 03/16/20 08:45 AM
B
BMWTurboDzl Offline
B
Hi everyone,
Any ideas?
Thanks
Fyi...Auto-Rx, an ester product, is a temporary fix for tired seals so leaks will reappear once you switch back to synthetic.
If a HM oil isn't working then just replace the seals.
435i
Re: Dino oils available in Europe? [Re: allepunta] #5377674 03/16/20 08:50 AM
K
Kira Offline
K
How long would you leave the Auto-rx in?
Is this a 20 minute, "idling in a warm engine only" application or a 2,000 km driving cleanse?
Re: Dino oils available in Europe? [Re: BMWTurboDzl] #5377681 03/16/20 09:08 AM
O
Olas Offline
O
I've said that close to a hundred times on this site because I believe the best way to fix a leak is to replace the comprimised gasket.
Every single time, without fail, I would see several replies saying it would be too hard to replace the gasket, or take too long, or that people would rather live with the drip than 'waste' time repairing an older vehicle that isn't worth a lot.
Its good to see another member on here who advocates replacing failed gaskets smile
Re: Dino oils available in Europe? [Re: BMWTurboDzl] #5377862 03/16/20 01:33 PM
A
A
not a single leak in my engine. only a a bit of oil consumption (1.5 liters per 10000 km). thinking it might be sticky rings. The first owner did long OCI's
I am following the procedure described on the website. add the additive during the oil change, run it for 3-4000km, change the oil againg and run it as a rinse for another 5000km.
Re: Dino oils available in Europe? [Re: allepunta] #5381786 03/21/20 03:13 AM
F
FordCapriDriver Offline
F
Generally on BITOG,
Dino = "Mineral" or "Conventional"
Blend = " Semi-Synthetic" or "Syn Blend"
Full Synthetic, explains itself
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Whatever keeps the lifters quiet...
Re: Dino oils available in Europe? [Re: allepunta] #5382563 03/22/20 12:33 AM
U
UG_Passat Offline
U
Group III is still dino oil, just refined even more.
Sometimes referred is "Synthetic Technology"
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Dino oils available in Europe? [Re: allepunta] #5383412 03/23/20 05:48 AM
ChristianReske Offline
Dino = Group I = "Mineraloel".
Visit the Liqui Moly Homepage.
Then Choose Engine oil , then "Oelart" (Type of oil), then choose "Mineral".
On the german Homepage, you then have the choice of 24 different Mineral - Group I - Dino oils.
