Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
95 registered members (amblerman, 2015_PSD, 41Pack, 4WD, 762fermeandyou, 8 invisible), 2,928 guests, and 20 spiders.
Topics303,589
Posts5,237,861
Members71,094
Race fuel in small engines? #5377508 03/16/20 01:43 AM
Clayslayer Offline OP
Ok. Been toying around with the idea of buying a small supply of Sunoco Optima 95 for use in small engines that see very little use over the course of a year. It advertises a shelf life of several YEARS. So... I live in the middle of nowhere and of course it's not available but there's a shop that'll sell me Sunoco Standard 110 octane leaded gas. Similar shelf life. Keep in mind. NO VP gas in my area. The ONLY thing available is the Sunoco 110 Standard. Economically there is not another viable option. (Shipping is a thing and gas is not only heavy but a hazardous material) This will be for a pressure washer, to sit in the generator, for who knows how long it'll sit before I need it again, 2 stroke gas, and a few other small engines that might get used frequently in fair weather but not for long periods of time. For example. I'll get my pressure washer out on a weekly basis but It's unlikely that I'll burn more than a tank a year on it. Two at most. Then it sits for another winter. Do you know how little fuel a Stihl weed eater uses?! Curious on thoughts?
Re: Race fuel in small engines? [Re: Clayslayer] #5377515 03/16/20 02:01 AM
SubieRubyRoo Offline
Why not just buy the smaller quart/gallon metal cans of ethanol-free OPC fuel from a Lowe's, Home Depot, etc? It should be WAY cheaper than 110 leaded, plus why breathe in leaded fumes if you don't need to? Plus, since it comes in quarts, only buy a couple and use them as needed until you can guesstimate your yearly usage.
I'd use the canned stuff first, then the 95, then local E0 (or use the dyed water trick to remove most of the ethanol) with some Stabil Marine 360, and not even mess with the leaded race fuel. That high of octane will be very hard to burn in the low-compression engines you're discussing and I'd avoid that choice at all costs.
Or, simply only add enough fuel for the task at hand and leave the tank dry in between uses, and every 3-6 months dump your remaining gas can contents into your vehicle and refresh it from the pump.
De omnibus dubitandum.
Re: Race fuel in small engines? [Re: Clayslayer] #5377530 03/16/20 03:30 AM
O
Olas Offline
O
race fuel is still fuel, just better quality and the size of the engine does not matter.
buy normal fuel and remove the ethanol from it?
Cable ties should hold it
Re: Race fuel in small engines? [Re: Clayslayer] #5377595 03/16/20 06:49 AM
Donald Offline
I would not use leaded gas. Bad for the enc environment and most likely your engine.
2015 Ford F-250 w/Powerstroke
Re: Race fuel in small engines? [Re: Clayslayer] #5377631 03/16/20 07:29 AM
Chris142 Offline
Wont leaded gas plug up the cats on your equipment?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Race fuel in small engines? [Re: Clayslayer] #5377637 03/16/20 07:48 AM
B
BMWTurboDzl Offline
B
I don't see any benefit running race fuel in a low compression engine.
BTW...Gasoline today, with or w/out ethanol, goes stale in a couple of weeks.
435i
Re: Race fuel in small engines? [Re: Clayslayer] #5377658 03/16/20 08:17 AM
SHOZ Offline
Here in Central Illinois Casey's sells 91 premium with no ethanol. As far as I've read, with most 2 cycle motors it's recommend to use premium for best performance. And the zero ethanol will make the fuel lines last. It's what I use for my 2 cycles and my Gen Coupe turbo.
I keep fuel for 6 months easily. Usually fill 15 gallons in jugs before winter after done mowing. I use out of date fuel treatment. Then usually fill two more times during the summer with no treatment.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Race fuel in small engines? [Re: Clayslayer] #5377708 03/16/20 09:47 AM
CT8 Offline
I use regular up to 10% gas in my two string trimmers.back pack blower 2 lawn mowers pressure washer. 2 line movers and generator some are 20 years old with out problems why do people have a problem?
2015 F150 2.7
2018 F350 6.2
Re: Race fuel in small engines? [Re: Olas] #5377741 03/16/20 11:09 AM
J
jeepman3071 Offline
J
Why would you run expensive race fuel in an engine that is not designed to run on something with such high octane?
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (60k) - Liqui Moly 5w40, MANN HU816X
Re: Race fuel in small engines? [Re: jeepman3071] #5377797 03/16/20 12:30 PM
domer10 Online Content
Online Content
Why would you want to run or put something in your engine, most knowingly small engines that causes adverse effects. If one has ways, and means and it doesn’t adversely effect them.....why not?
2013Jeep Wrangler Sahara Unlimited
2001 Toyota 4Runner
20010 Harley Davidson Rocker
Re: Race fuel in small engines? [Re: jeepman3071] #5377828 03/16/20 12:54 PM
RDY4WAR Online Content
Online Content
I run 110 octane fuel, in an engine that'll run fine on 87, because it's more consistent than pump fuel, has a faster burn rate, and has a leaner stoich.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Race fuel in small engines? [Re: CT8] #5377857 03/16/20 01:24 PM
SHOZ Offline
I have a Craftsman pressure washer from the 90's I would guess. it's got a Briggs and Stratton motor. But you cannot drain the gas tank all the way. Nor can you run the engine to completely drain it. Even if you take the tank off, which is pretty involved due to the carb sitting on it and the linkage, you still cannot get all the gas out. You have to use an air hose and rag. It's a terrible design.
But using ethanol it will slowly fill with water until it gets to where the fuel pickup starts sucking it up. About a 1/4" will be in the tank. Then you have to disassemble it to get it all out. PITA for something that seldom gets used. So I put in a drain plug. Don't think it will hold though once the engine vibration kicks in as the metal tank is pretty thin.
And the rotting fuel lines. But I assume they are gasoline safe but not alcohol.
Re: Race fuel in small engines? [Re: Clayslayer] #5377887 03/16/20 02:07 PM
Alright. Some of you missed the purpose. I want to use race gas because it's a higher quality fuel that will last on the shelf for over three years. I'm not looking for power gain. I can buy it by the gallon for about $7 and put it in my own cans. High price maybe but the low usage will mean that I really won't spend much at all on it. The "leaded" part is exactly the same as gas sold in the 60s. Not a problem. None of the pull stuff I have has a cat anyway.
I want to store all my crap over the winter without worry. I want everything to start in the spring just like it did when I put it away. That's all.
Those who are recommending removing the ethanol from pump gas?! Are you out of your mind?! You got the fire department on speed dial?
Re: Race fuel in small engines? [Re: Clayslayer] #5377902 03/16/20 02:25 PM
E
emmett442 Offline
E
In an age where a bottle of fuel stabilizer is under $10 and perfectly functional replacement China carburetors can be had for under $20, I see no reason to be concerned about $7 fuel.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Race fuel in small engines? [Re: Clayslayer] #5377907 03/16/20 02:28 PM
O
ondarvr Offline
O
Lots of not so smart things mentioned so far.
The only problem with leaded fuel in this application is that it may tend to lead foul the plugs. This was a small hassle in 2 strokes back when that was the only option.
