Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
87 registered members (4WD, 762fermeandyou, ArrestMeRedZ, 2015_PSD, 2010Civic, bdcardinal, 9 invisible), 2,801 guests, and 19 spiders.
Topics303,589
Posts5,237,854
Members71,094
Clay vs Metal Chiminea #5377431 03/15/20 09:36 PM
spasm3 Offline OP
I have a clay chiminea, probably 4 years old. I am interested in the Blue Rooster chimineas. They have cast aluminum and cast iron models.
I put 4 inches of sand in mine before i ever used it, and i have no cracks, I need to repaint it.
But i am curious as to heat output of the clay vs metal. Our clay one does not really warm you on a chilly evening , unless you sit close and right in front of the mouth. Does a metal one radiate heat better than the clay?
Thanks.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Clay vs Metal Chiminea [Re: spasm3] #5377440 03/15/20 09:49 PM
M
Mad_Hatter Offline
M
Don't have either because I have a pit but I'd think that clay or metal, you're still gonna have problems because all that heat just goes up and out with zero retention. My fire pit doesn't keep me warm either unless you're practically right on top of it.
Re: Clay vs Metal Chiminea [Re: spasm3] #5377531 03/16/20 03:32 AM
O
Olas Offline
O
I have a metal one and it kicks out a good amount of heat about 3-4 feet
Cable ties should hold it
Re: Clay vs Metal Chiminea [Re: spasm3] #5377561 03/16/20 05:30 AM
Shannow Offline
I've got clay...Steel/iron would be OK, but if people fall against it, they "stick", and flesh gets pulled off.
Al...knowing my luck would become a molten pool.
If it's the truth....it can handle the pressure !!!
Re: Clay vs Metal Chiminea [Re: spasm3] #5377782 03/16/20 12:19 PM
3
379KITTY Offline
3
Had a nice clay one about 4-5' tall. Accidental bump while on mower and watched it slowly fall and become multiple pieces. No more clay for me.
Re: Clay vs Metal Chiminea [Re: spasm3] #5381553 03/20/20 06:59 PM
spasm3 Offline OP
I will probably repaint this one, and use it till fall.
Re: Clay vs Metal Chiminea [Re: Mad_Hatter] #5381904 03/21/20 08:46 AM
H
hatt Offline
H
Yep. You're going to need a big fire to put out a lot of heat when it's cold. My clay chiminea starts to put out a little heat after it's been going for a few hours and has a nice bed of coals. I'm a chiminea convert for our uses of mainly just having a fire on the patio. It uses much less wood than a pit and has very little smoke once it gets hot.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Clay vs Metal Chiminea [Re: hatt] #5381910 03/21/20 08:54 AM
spasm3 Offline OP
That's why i like them. No smoke moving around making people constantly move.
Re: Clay vs Metal Chiminea [Re: hatt] #5381915 03/21/20 08:59 AM
4WD Online Confused
Online Confused
Too much white on our patio so I put an open pit next to the cook shed under a tin roof.
The Cajun wok sits on a cast iron base and FP grating in that to let air move ... so all in a fair amount of metal to heat up
