Need a dial gauge indicator (mm) and a dial gauge holder but haven't decided on what kind of indicator.
I've heard good things about Noga holders so I'm set on getting one of those.
As for the dial indicator, not sure which to get.
I need the indicator so that I can correctly tighten a nut that secures an axle flange shaft to a rear hub (car).
Need to achieve end play of 0.04-0.06 mm (rear axle shaft)
https://handbook.w116.org/Chassis/35-130.pdf
Recommendations are greatly appreciated
