Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Turn signals all blinking fast
by JHZR2 - 03/30/20 12:14 AM
New Ram... thoughts by owners?
by wallyuwl - 03/29/20 11:38 PM
rider9195, kingsville911, B34R, ChrisSnowden, DIY4quality
71055 Registered Users
117 registered members (007, 53' Stude, alanwayne1908, 4WD, 762fermeandyou, 55hambone, 7 invisible), 2,126 guests, and 22 spiders.
Topics303,356
Posts5,234,697
Members71,055
Remember... you seen it here first! #5377374 03/15/20 08:33 PM
P10crew Offline OP
[Linked Image]
[Linked Image]
[Linked Image]
This project is in its infancy but I thought I would invoke my copy rights here and now. 1823 3/15/20.
This press punch and die / press modifacation design works so well it’s almost scary.
Ok so my son does so many of these at his shop they wanted to automate this process as much as possible.
[img]https://www.bobistheoilguy.com/forums/attachments/usergals/2020/03/full-84637-42339-image.jpg[/
More to come next week end.
Re: Remember... you seen it here first! [Re: P10crew] #5377381 03/15/20 08:42 PM
N
NYEngineer Offline
N
Nice.
Re: Remember... you seen it here first! [Re: P10crew] #5377434 03/15/20 09:39 PM
clinebarger Offline
Alright....How much $ P10?? I have my own arbor press wink
2001 Chevy Camaro L92/4L80E
Re: Remember... you seen it here first! [Re: P10crew] #5377652 03/16/20 08:09 AM
K
Kira Offline
K
Handsome looking machine. I went to the link also.
What is it set up for? Is this a press-tool to which specific dies / cutters are fitted?
Re: Remember... you seen it here first! [Re: P10crew] #5377703 03/16/20 09:43 AM
Yah-Tah-Hey Online Content
Online Content
I SAW it here first. Wrong verb tense. See, Saw,Seen.
Re: Remember... you seen it here first! [Re: P10crew] #5377718 03/16/20 10:16 AM
Z
zzyzzx Offline
Z
What is it?
Re: Remember... you seen it here first! [Re: P10crew] #5378006 03/16/20 05:32 PM
P10crew Offline OP
It’s a tool that aids in the disassembling of LSx rocker arm trunnions. The latest trunnion upgrade kit from Brian Tooly racing requires pressing in new captured needle Torrington’s. Most other manufactures are slip fit bushings.
Disassembling is one of those deals where you need 6 hands. This contraption makes it a quick one hand operation. The lower die plate locates and fully supports the rocker below the centerline of the punch. The lower die plate is pocketed to hold the dies and is bolted to the press frame so nothing moves. It requires 2 punch and die sets 1 set for disassembling and one set for pressing in the BTR Torrington’s.
CLine does the bottom of your ram have a sacrificial pad on it or is it a square ram with no pad? It would be nice to have a way to mount the upper punch to the ram rather than having to hold it.
To help hold the lower die plate to your press platen I could pocket and epoxy 4 neodendium magnets as well. Ooooorrrr you could run down to HF and snag one of these from the return table.
hide
I picked up one of these 2 from the return table for 27 bones and the only thing wrong was the rubber handle ends were missing. Either way no prob.
This is the V2 punch adapter [Linked Image]
Re: Remember... you seen it here first! [Re: P10crew] #5378224 03/16/20 11:46 PM
clinebarger Offline
hide
No pad on the Ram, When I bought it.....It had the solid end of the Ram pointed down, I flipped it around & use the @.761" counterbored end. Had a buddy machine the end of my bushing installer-knockers to .760". Drilled & tapped a 6mm hole in the Ram for a set screw to hold them.
[Linked Image from i.imgur.com]
Re: Remember... you seen it here first! [Re: P10crew] #5378664 03/17/20 01:20 PM
P10crew Offline OP
Perfect..... I’ll hook you up🤙
Re: Remember... you seen it here first! [Re: P10crew] #5382024 03/21/20 11:00 AM
P10crew Offline OP
[Linked Image]
[Linked Image]
