Forums Migration
Please read this thread
626,000 mile Pentastar teardown
by wwillson - 07/10/20 08:25 AM
Price components of gasoline and diesel
by Snagglefoot - 07/10/20 08:20 AM
Peak Synthetic
by oilchangeguy - 07/10/20 07:01 AM
[Cut Open] FRAM Ultra XG7317 (6230 miles)
by DuckRyder - 07/10/20 06:41 AM
Need a New Frig
by Boomer - 07/10/20 06:01 AM
How to tell what engine mount is gone.
by mossietheno1 - 07/10/20 04:28 AM
Raybestos Specialty Rotors
by The Critic - 07/10/20 03:33 AM
Castrol Euro at Walmart, but which one?
by Impatient - 07/10/20 12:48 AM
Car Stereo Upgrade
by montero1 - 07/09/20 11:55 PM
GM 1.4T Hengst vs UFI housing
by hardcore302 - 07/09/20 10:56 PM
2018 Charger Hellcat 16,000 mile update
by mbacfp - 07/09/20 10:01 PM
Grease. Temperature rating
by Chris142 - 07/09/20 09:45 PM
Utility Trailer Tire Size
by Propflux01 - 07/09/20 09:17 PM
0w20 VW oil observation......201
9 GLI - oil temp
by Zack1978 - 07/09/20 08:33 PM
Bogus Facebook sludge video
by cknight49090 - 07/09/20 07:53 PM
Tire recommendation--will be towing
by geekster - 07/09/20 07:18 PM
Japan Working on New Stealth Fighter
by Jackson_Slugger - 07/09/20 07:03 PM
Puckster02, TurbodogTodd, TNVOL, lowon, 907Lynette
71904 Registered Users
125 registered members (77Se7en, AdamZ, Alfred_B, 4WD, Aichiguy, 1978elcamino, 12 invisible), 1,720 guests, and 33 spiders.
Topics307,680
Posts5,315,501
Members71,904
Mazda MV the same as Mercon V? #5377343 03/15/20 08:16 PM
M
Micahmcmeen Offline OP
M
I have a 2008 mazda 5 and it calls for at MV mazda fluid however, it is a Ford transmission in it. Is there any real difference between the too? I realize there probably isn't but I am a purist when it comes to my vehicles. It's just easier to get my hands on mercon v than the MV. Thanks in advance.
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377350 03/15/20 08:18 PM
P
PandaBear Offline
P
No, it is a different spec. From what I searched in the past it has a spec that is from a high temperature compressor fluid, so it is likely some sort of synthetic or at least blend.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377365 03/15/20 08:27 PM
B
blufeb95 Offline
B
I'd use whatever says it's compatible with Mazda M5, maybe try Idemitsu Type M, it seems to be available for a little cheaper than genuine Mazda fluid which I think may be made by Idemitsu as well.
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377389 03/15/20 08:55 PM
P
PandaBear Offline
P
Recently (a few years) Maxlife starts supporting Mazda MV, it wasn't the case back in 2015 when my dad got a Mazda5, but now it does.
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377404 03/15/20 09:08 PM
simple_gifts Offline
Mind boggling that with 10 numerical digits, 26 letters of the alphabet and various emoji, Mazda engineers could have picked a less confusing fluid name. Especially with Mazda and Ford being closely tied @ one point and, I believe, some transmissions taking possible either of the fluids. This is a spec, as Triumph would put it, for me to poop on.
2004 Prius; 134K; ATM
2007 Yaris 114K M1 ESP 5W-30
2006 B2300;137K;ALM
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377476 03/15/20 11:16 PM
5
50jeffrey Offline
5
The Ford version of the M-V fluid is called FNR5. Same stuff.
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377500 03/16/20 01:16 AM
B
blufeb95 Offline
B
[Linked Image]
In the Ford Manual for the 2009 Mercury Milan, it says to use the Motorcraft fluid that they sell specifically for the FNR5 (xt-9-qmm5) or Mazda M-V fluid for cars equipped with the 5 speed Mazda Transmission.
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377544 03/16/20 04:48 AM
P
Popsy Online Content
Online Content
P
My Mazda 6 has the FNR5 transmission, I tried Maxlife and the Mazda original fluid, shifts better with Mazda fluid (which is the same thing as Idemitsu type M apparently).
Apparently originally Mazda had a different programming and they were saying that Mercon V wasn't compatible...I think they changed their mind after. Whatever, I'm using the Mazda fluid because it's the same price as Maxlife, amongst the cheapest things I can get in my corner of world, so to me it's a no brainer smile
In any case my transmission is slowwww, but shifts very smoothly. Not sure if typical of these transmissions, as it's my first long term use of an automatic transmission.
(off topic but i'm also using the Mazda M5 fluid in the power steering)
96 Barchetta, 300V 5W40 | Forfour 95, M1 0W40
Mazda 6 2.3, M1 TDT 5W40 | Colt Ralliart, 300V 0W40
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377612 03/16/20 07:05 AM
SoNic67 Offline
Those ATF fluids have the same specs, they are just manufactured by different suppliers, based on car manufacturer contracts.
Re: Mazda MV the same as Mercon V? [Re: blufeb95] #5377625 03/16/20 07:22 AM
M
M
Very useful. Thank you!
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377635 03/16/20 07:37 AM
Q
quint Offline
Q
Mazda MV and Mercon V are NOT the same spec.
Idemitsu Type M is the real deal and is readily available and relatively cheap on ebay. I've had several cases of it shipped and its never been a problem (I have multiple pre-Skyactiv Mazdas that use this fluid). You can also use Ford FNR5 fluid from a Ford dealer, if they are stocking it. It is the exact same as Mazda MV.
The various forums are littered with people having used Mercon V and various others (Maxlife, Valvoline Import, etc) long term successfully, others not so successfully. Use whatever you want, but with the real deal being available and not expensive, personally I'm sticking to that.
Re: Mazda MV the same as Mercon V? [Re: 50jeffrey] #5377764 03/16/20 11:51 AM
P
PandaBear Offline
P
But from what I remember different color dye.
Re: Mazda MV the same as Mercon V? [Re: Micahmcmeen] #5377765 03/16/20 11:53 AM
P
PandaBear Offline
P
Seriously, when I bought the Mazda M-V at Mazda dealer 5 years ago, it was only like $4 or $5 a quart, you are wasting your time saving like $1 or $2 a quart over Maxlife.
Re: Mazda MV the same as Mercon V? [Re: blufeb95] #5466367 06/30/20 01:19 PM
corster Offline
Originally Posted by blufeb95
[Linked Image]
The interesting twist is that Ford discontinued the XT-9-QMM5 fluid a few years ago and now lists XT-5-QMC (Mercon V) as the appropriate ATF for vehicles with an FNR5 transmission.
Mazda, of course, continues to sell their version of the the M5 fluid and continues to recommend against the use of Mercon V in their vehicles.
Personally, I'll just buy the Mazda stuff.
Re: Mazda MV the same as Mercon V? [Re: corster] #5466407 06/30/20 02:15 PM
bdcardinal Offline
[Linked Image]
This is one of those things that makes us parts people hit our head on the wall.
1995 Ford Mustang GT
2003 Chevy Silverado 2500
Ford/Mazda Parts Counter
NRA Benefactor Member
