Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
118 registered members (92saturnsl2, ABomb369, 5AcresAndAFool, 53' Stude, 55hambone, 19 invisible), 1,792 guests, and 21 spiders.
Topics303,450
Posts5,235,463
Members71,072
Mower leaves clumps #5376978 03/15/20 12:49 PM
B
buck91 Offline OP
B
So I have a Lawnboy walk behind with the smart drive speed thingy (pushbar controls drive speed). Past few seasons it has been leaving progressively worse grass clumps behind as well as missing patches of grass while mowing. These missed pieces tend to be approximately centerline with the mower deck. I tried sharpening the blade without improvement so I replaced it- no improvement. Definitely gets worse in between cleaning the deck of built up clippings but also is present with a freshly cleaned deck.
This is making me want to upgrade to a nice, new Husqvarna but not really in the plan for this year. Any suggestions to combat this issue (other than even more frequent mowings)? I do typically cut with the mulching plug in but if I miss a cut I have to open the side cute otherwise it bogs out pretty easily.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Mower leaves clumps [Re: buck91] #5376987 03/15/20 01:06 PM
R
RhondaHonda Offline
R
How much are you cutting off each time you mow?
2019 Ford Raptor
2017 Corvette Grand Sport
2017 Yukon XL Denali
Re: Mower leaves clumps [Re: buck91] #5376990 03/15/20 01:08 PM
B
Brian123 Online Content
Online Content
B
Are you mowing when the grass is completely dry?
Re: Mower leaves clumps [Re: Brian123] #5376993 03/15/20 01:10 PM
B
buck91 Offline OP
B
Ideally. And that definitely decreases the problem but it still misses tufts down the center line. Unfortunately, especially early in the season there are a few sections which stay rather damp 24/7.
Re: Mower leaves clumps [Re: buck91] #5376998 03/15/20 01:12 PM
T
TheLawnRanger Offline
T
A streak in the middle usually means the blade is unbalanced or installed backwards according to SFGuides site.
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Mower leaves clumps [Re: buck91] #5377007 03/15/20 01:19 PM
Clayslayer Offline
Clumps are the result of the blade not chopping up the grass properly. To reduce clumping slow down, sharpen the blade, and clean the deck. If none of the above work try a different blade? The cheapie mulching blades at Runnings and Tractor Supply are actually pretty good.
Re: Mower leaves clumps [Re: buck91] #5377009 03/15/20 01:20 PM
T
tundraotto Offline
T
Check the leveling of the deck.....needs to be a certain way - in manual. - and of course - sharp blades.
Re: Mower leaves clumps [Re: buck91] #5377038 03/15/20 01:50 PM
chemman Offline
After you level your deck, try installing a set of Oregon Gator G5 Mulching Blades. They are fabulous! I could not believe the difference between using the lawn tractor manufacturer's mulching blades and the Gator G5 blades. Day and night difference and reduced my clumping issues by 90%. I even put Gator blades on my Toro mulching push mower.
https://www.oregonproducts.com/en/p...tor-mulching-blades/c/g6-mulchingblade-p
I recommended them to a couple of friends with large lawns who also use mulching blades and they love them as well.
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: Mower leaves clumps [Re: buck91] #5377060 03/15/20 02:36 PM
R
riff1006 Offline
R
delete.
2013 GMC Sierra 2500HD-6.6L Duramax
2008 Ford Fusion-2.3L
Re: Mower leaves clumps [Re: tundraotto] #5377168 03/15/20 05:18 PM
doitmyself Offline
Try mowing with the front wheels one notch lower than the back. You should only be cutting off about 1/3 of the grass blade length, i.e., cut 5 inch grass down to about 3 to 3.5 inches, the proper length for our Michigan grasses.
Re: Mower leaves clumps [Re: buck91] #5377179 03/15/20 05:29 PM
B
Bottom_Feeder Offline
B
Yes, if everything else is in order, make 100% sure the blade is on correctly. You wouldn't be the first person to install it backwards so no shame in verifying.
Re: Mower leaves clumps [Re: buck91] #5377216 03/15/20 06:07 PM
W
whatnext Offline
W
Is the motor at full speed? Are you bagging or mulching?
Re: Mower leaves clumps [Re: buck91] #5377411 03/15/20 09:12 PM
I
incognito_2u Online Content
Online Content
I
That time of year....... grin
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -91k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Mower leaves clumps [Re: buck91] #5377511 03/16/20 01:55 AM
W
whatnext Offline
W
OK, it sounds like you are mulching from the OP. So I would conclude the lawn boy is getting over whelmed (for whatever reasons). Is the engine bogging when the clumping happens? A mower upgrade with a bigger engine might be the solution.
Re: Mower leaves clumps [Re: buck91] #5377597 03/16/20 06:51 AM
L
Lubener Offline
L
Sounds like the engine needs a "tweek" to get the RPM up just a little. Also, the decks need to be clear of all dried grass to work well.
The "thinking" man's friend.
