Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
111 registered members (2015_PSD, 762fermeandyou, 01rangerxl, 928, 4WD, 41Pack, 10 invisible), 2,677 guests, and 18 spiders.
Topics303,589
Posts5,237,879
Members71,094
Page 1 of 4 1 2 3 4
245/45ZR20 #5376885 03/15/20 10:54 AM
J
Jarlaxle Online Content OP
OP Online Content
J
My Challenger will need tires soon...currently has (mis-sized) Sumitomo HTR. I will run snows, so dedicated summer tires are preferred...the Kumho Exsta 91 looks good. Anyone here used that tire?
1979 Coupe de Ville, 542 stroker, parked for winter frown
2013 Challenger SRT8 Core, Mobil 1 0W-40, Mopar
2011 Sportster 883, parked for winter frown I hate winter.
Re: 245/45ZR20 [Re: Jarlaxle] #5376893 03/15/20 11:04 AM
M
Mainia Offline
M
These are killer tires, and affordable. I am trying to get some for autocross, but my size was a limited car spec and did not sell so, they maybe dropped. These tires are always a 1/2 wider then any tire on the market in the same size.
https://www.tirerack.com/tires/tire...all&partnum=445YR0UVXL&tab=Sizes
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: 245/45ZR20 [Re: Jarlaxle] #5376908 03/15/20 11:14 AM
O
Olas Offline
O
Im making a couple of assumptions here so forgive me if I'm wrong...
You want a dedicated summer tyre so you're interested in something that will generate a lot of grip in dry conditions
A Challenger is a powerful car so you probably like to 'open her up' from time to time, and, its a heavy car too so you want a tyre that can translate your braking power into stopping power.
In the size you reference in the thread title there are two strong contenders;
Michelin Pilot Sport 4 S
or
Yokohama Parada spec X
Both available on amazon/ebay for home delivery if your preferred tyre place cant get them
Cable ties should hold it
Re: 245/45ZR20 [Re: Jarlaxle] #5376918 03/15/20 11:28 AM
Quattro Pete Offline
Originally Posted by Jarlaxle
I will run snows,
Which size are you going to run for winter?
I was initially considering getting snow tires for the Charger until I saw how obscenely expensive low profile 20" winter tires are, plus not very good against winter potholes. I decided to just continue using my old BMW as a winter beater. This way I can keep salt and grime away from the Charger.
As for your original question, it appears you are looking at low priced max perf tires. That particular Kumho has rather poor ratings on TR. I would look at Hankook Ventus V12 for not a lot more.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: 245/45ZR20 [Re: Jarlaxle] #5376966 03/15/20 12:29 PM
Mr Nice Offline
Yokohama
Re: 245/45ZR20 [Re: Olas] #5376994 03/15/20 01:10 PM
J
OP Online Content
J
or
I will usae 4 different brands of used Chinese trailer tires before giving a cent to Michelin.
The Yokohamas are explicitly NOT dedicated summer tires, they're all-seasons. (They're not even ZR rated.)
Re: 245/45ZR20 [Re: Quattro Pete] #5376995 03/15/20 01:11 PM
J
OP Online Content
J
I will run snows,
Probably 235/55 or 235/60R18 for snows.
Re: 245/45ZR20 [Re: Mainia] #5376997 03/15/20 01:12 PM
J
OP Online Content
J
That...might work.
Re: 245/45ZR20 [Re: Jarlaxle] #5377004 03/15/20 01:18 PM
O
Olas Offline
O
or
They're Z rated - I read it as Z R20. The pedant in me sees a difference between ZRr20 and Z R20. Sorry
Re: 245/45ZR20 [Re: Jarlaxle] #5377012 03/15/20 01:24 PM
Mr Nice Offline
That...might work.
Can you post a photo of your car ?
I know you were search high and low for the perfect Challenger. 👍
Re: 245/45ZR20 [Re: Jarlaxle] #5377019 03/15/20 01:30 PM
O
Olas Offline
O
https://www.jegs.com/i/Mickey-Thompson/672/6221/10002/-1
As an aside, Z is above 149mph, but how far above is not determined. There should be another number after the load rating, probably Y or W?
Re: 245/45ZR20 [Re: Jarlaxle] #5377043 03/15/20 02:00 PM
Hmm... I thought your car had the same Brembo brakes as mine. On mine, nothing smaller than 20" will fit.
If 18s do fit, then yeah, there will be lots of reasonably priced winter tires available.
Re: 245/45ZR20 [Re: Quattro Pete] #5377377 03/15/20 08:38 PM
J
OP Online Content
J
Check challengertalk.com for details...several people have put 18s on theirs. It seems SXT wheels will fit with 1/4-1/2" spacers, and Tire Rack has "KV5 Sport Edition" 18s that will clear the 4-piston Brembos, no spacers required. (Though I'd bet you'd need to put all balance weights on the side away from the caliper.)
You probably have 6-piston brakes (switched, at least on Challengers, in 2015), in which case...I have no idea and you're on your own. Got a pic of your front calipers? I can compare to mine easily enough.
Factory SXT 18s on an SRT 392:
[Linked Image from uploads.tapatalk-cdn.com]
Re: 245/45ZR20 [Re: Olas] #5377379 03/15/20 08:41 PM
J
OP Online Content
J
or
https://www.tirerack.com/tires/tire...wall&partnum=445VR0PSX&tab=Specs
No, they are not. They are V-rated all-seasons.
Re: 245/45ZR20 [Re: Jarlaxle] #5377446 03/15/20 09:55 PM
[Linked Image from live.staticflickr.com]
Page 1 of 4 1 2 3 4
