Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
106 registered members (apollo18, 2015_PSD, agarb, 4WD, 2010Civic, 87sammy, 10 invisible), 2,286 guests, and 32 spiders.
Topics305,921
Posts5,282,802
Members71,537
Page 2 of 2 1 2
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: BlueOvalFitter] #5376653 03/15/20 06:13 AM
4WD Online Confused
Online Confused
You guys see the little corrugations in the pleats ?
Reckon that’s there in an attempt to add structural integrity to a thin and weak paper media. I do.
But that will not beef up the common location where they fail.
By comparison, Mobil 1 (Champ) has synthetic blend and thick material so no need for that extra “wave” …
I have cut them all and attempted to tear them all. Only MC/Purolator tear like xerox paper.
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: BlueOvalFitter] #5376662 03/15/20 06:38 AM
I
IndyFan Offline
I
Outside of this forum, I've not witnessed personaly a torn Motorcraft, but I did see years ago much fraying on Purolator PurOne filters in a GM 2.4 Ecotec in my Pontiac Soltice and stopped using them. I moved to Supertechs and they held up much better.
I tore apart a used Fram XG cartridge filter from my Jeep. It took a pair of vice grips and pliars and LOTS of force to tear the pleats apart. I was shocked at how strong they were. The media itself was strong, but it was extremely well bonded to a monofiliment-like mesh.
Some are made stronger than others. That's just a fact. I'll be pulling apart a Mobil 1 filter soon that will have over 7k on it and probably over 8k. I run my Jeep pretty hard, with lots of throttle excursions to the highest rpm range of the Pentastar, so these filters haven't been babied.
I will say this, though. While I only had 2k on it, the OEM Mopar, which I'm certain is a Purolator, held up fine. The pleats, however, were nowhere near as strong as the XG. Of course they aren't backed by anything, either, but the media itself isn't as strong, even without considering the mesh backing in the XG.
I ran FL500S and FL400S filters for a good while in my Jeep 3.8 and Ford 3.5. I never had a known issue, but the bad press makes you wonder if they all held up. A couple of the 3.5 filters went 10k, too. I now run XG's in both vehicles. I'd expect that the odds are good that those MC filters held up, but seeing torn examples shakes the confidence. I've not one time on this forum or anywhere else seen an example of a torn XG or M1. I certainly know why with the M1.
This is why I greatly prefer cartridge filters. You can inspect every one of them.
Thanks OP for posting this. It at least tells us that they probably hold up at least most of the time. I hope they do all the time, really, but I don't think we've seen that.
18 Jeep JLUR Wrangler 3.6 31k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 29k
08 Jeep Wrangler 3.8 141k
04 Jeep Grand Cherokee 4.7 111k
99 Mercedes E430 Sport 90k
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: BlueOvalFitter] #5377093 03/15/20 03:30 PM
Z
ZeeOSix Offline
Z
Originally Posted by BlueOvalFitter
Originally Posted by tig1
But that doesn't prove anything either. It boils down to the % that tear that are examined. We only see the ones that people want us to see.
There, I fixed it for you.
popcorn2
And what's that supposed to mean?
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: BlueOvalFitter] #5377099 03/15/20 03:37 PM
PimTac Offline
”But that doesn't prove anything either. It boils down to the % that tear that are examined. We only see the ones that do.“
The original sentence. TIFIFY is poor etiquette and manners.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: BlueOvalFitter] #5377147 03/15/20 04:51 PM
B
bullwinkle Offline
B
Originally Posted by CR94
Tears are much less likely to occur in Louisiana than in the frozen North, other things being equal.
crackmeup
That thar is funny right thar!
Cold starts/thicker oil, more condensation in cold winter weather, means a cellulose media filter has to be stronger to avoid tears. Even when it is changed EVERY OCI! I had drainback issues with the FL-820S (& even a Frampion CQ Blue) on my 4.6, I've gone to Ultras & haven't looked back, have 10K on the XG2 on there now & will go another 12.5K before I change it.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: ZeeOSix] #5377502 03/16/20 01:20 AM
BlueOvalFitter Offline OP
popcorn2
What are you WANTING it to mean?
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: BlueOvalFitter] #5377503 03/16/20 01:22 AM
I will be cutting open a few more MC-FL-820S filters later today.
Stay tuned............... wink
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: BlueOvalFitter] #5377509 03/16/20 01:45 AM
Z
ZeeOSix Offline
Z
popcorn2
Beats me ... you're the one who thought someone else's post statement needed to be changed per your thoughts.
Re: In Search Of Torn Filter Media (FL-820S) Part 2 [Re: BlueOvalFitter] #5377536 03/16/20 04:07 AM
M
M56959 Offline
Global Moderator
Global Moderator
M
If you're going to cut and contribute filter dissections that's acceptable. Doing it to prove a point only you care about, then sniping when others respond, is unacceptable and will result in locked threads and time away.
Review filter forum rules, we don't exist to attack or defend car parts.
As for "FIFY" that's unhelpful trolling as far as I'm concerned. Prior thread was locked because making a topic to announce you're going to make a topic wastes everybody's time.
This thread is locked for bickering. Please start a new topic for additional each filter dissection. Be sure to include model of filter and standard dissection information so each filter can be discussed.
This applies to all members.
Page 2 of 2 1 2
