VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
115 registered members (53' Stude, 2004tdigls, Alfred_B, Al, 2010Civic, 2009Edge, 12 invisible), 1,921 guests, and 24 spiders.
Topics303,447
Posts5,235,425
Members71,072
Page 1 of 3 1 2 3
"Effects of OEM vs K&N air filters on various engine parameters" #5376604 03/15/20 02:38 AM
wemay Online Happy OP
OP Online Happy
19 VW Passat Wolfsburg 2.0TSI: VW 508.00 0W-20+VW o.filter+Fram CA9711 a.filter
13 Hyundai Santa Fe Sport 2.0T: Shell RGT 5W-30+H/K o.filter+NAPA 9670 a.filter
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5376657 03/15/20 06:26 AM
T
tcp71 Offline
T
Looks like the K&N flows significantly worse than an oem filter. Goes directly against their marketing claims.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: tcp71] #5376689 03/15/20 07:24 AM
G
GON Offline
G
Not surprised. If KN had some magical feature that increased MPG or HP, they would have been bought out years ago. Simply a marketing ploy.
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: GON] #5376720 03/15/20 08:04 AM
X
XCIDMigs Offline
X
Did either of you guys or the OP actually read the whole study? she conclusion at the end reads
"The acceleration and fuel economy tests conducted on the vehicle shows that the vehicle performance will be
slightly better when the filter is new compared to that when it is clogged. The fuel economy tests shows that K&N
air filter provides a better fuel economy compared to OEM style paper filter in both new and clogged condition. The
acceleration tests also shows that acceleration times for K&N was slightly lower than OEM style paper filter in both
new and clogged condition"
So the independent test basically confirms exactly what K&N claims as the reasoning that anyone should purchase their product. All the other parameters that the experiment purports to test, on just a single small engine like a mower would use, are somewhat meaningless to most vehicle owners.
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5376784 03/15/20 09:27 AM
T
tcp71 Offline
T
Fuel economy is improved because there is less flow of air and therefor less fuel being injected to maintain the stoichiometeric ratio. K&N doesn’t market fuel economy gains nearly as much as better flow and more power, which this study directly opposes.
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5376800 03/15/20 09:38 AM
splinter Offline
Quote
The filtering efficiency test conducted on OEM and K&N air filter shows that OEM air filter exhibits superior air filtering qualities compared to K&N filter.
From real Indian scientists. If you're into filtering efficiency testing.
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5376818 03/15/20 09:57 AM
M
mclasser Offline
M
Bro my K&N has given me like 30+ HP. I fly by suckas in my Hyundai.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5376835 03/15/20 10:18 AM
DrDanger Offline
Yes, they also noted an increase in motor vibration after installing the K&N...
We all know how much a change in air filter affects motor vibrations Coffee
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5376847 03/15/20 10:26 AM
Danno Offline
In some ways opposite to this YouTube piece.
K&N provided more airflow/power, but less effective filtering.
Confirmed my thinking on K&N.
WIX for the win IMO.
https://www.youtube.com/watch?v=sJ3L-E-ufYo
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5377055 03/15/20 02:19 PM
T
TiGeo Offline
T
Yes?
2018 VW Atlas SEL 4Motion 3.6 - Castrol OE 5W40 VW filter
2018 VW GSW S 4Motion 1.8 Unitronic St2 IS20 - LiquiMoly 5W40 VW filter+Ceratec/MoS2
2013 Ford Focus SE HB 2.0 - MC syn-blend 5W20 MC filter
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5377074 03/15/20 03:02 PM
OP Online Happy
Every application is different. K&N works for some and not for others. It's far from a marketing ploy.
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: XCIDMigs] #5377079 03/15/20 03:07 PM
OP Online Happy
Agreed, that's how I read it too.
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: XCIDMigs] #5377232 03/15/20 06:36 PM
Z
ZeeOSix Offline
Z
The YouTube guy "Engineering Explained" showed the same thing.
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5377266 03/15/20 07:17 PM
T
TiGeo Offline
T
It's v. simple. K&Ns 1) flow more air and do deliver some additional power to many vehicles and 2) conversely let more dirt in to obtain that higher flow. It's not rocket science or controversial, it just "is". The question has always been, does the small drop in filtering efficiency matter to you/your car in your driving conditions? To me, it does not and I welcome the slight, proven gain in power on my tuned/modified car. If you don't like the little bit of extra bits getting in, cool, use a paper filter. This will not ruin or reduce the life of my engine and my car will fall apart from old age or me blowing it up sending it before that slightly lower filtering efficiency will ever come into play. The end.
Re: "Effects of OEM vs K&N air filters on various engine parameters" [Re: wemay] #5377384 03/15/20 08:43 PM
OP Online Happy
Agreed, and will add that it isn't only tuners or performance enthusiasts buying these anymore. Some just like the sound, the environmental aspect or all the above.
Page 1 of 3 1 2 3
