VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
116 registered members (53' Stude, 2004tdigls, Alfred_B, Al, 2010Civic, 2009Edge, 13 invisible), 1,899 guests, and 24 spiders.
Topics303,447
Posts5,235,425
Members71,072
Mazda cx5 diff case fluids and which tranny fluid type? #5376584 03/15/20 01:45 AM
sh40674 Offline OP
Owner of a new to us 16 mazda cx5 2.5 with 26k miles
Been reading it has "lifetime fluid" for the tranny..
But also reading it came with red fluid but the manual calls for the fz.. I read this is blue fluid? Any insight on this and if I should change it out? What about the "lifetime" deal? Only 26k miles so not too worried right now
As for the front and rear cases it calls out a specific fluid which is no problem.. standard drain and fill the oil school way? (Until it pours out of the top hole?)
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5376585 03/15/20 01:51 AM
sh40674 Offline OP
For the record I have not checked the fluid color yet.. we've only had the car a couple days
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5376591 03/15/20 02:11 AM
bachman Offline
I think you can do a VIN sweep per service history just to make sure you know what's what.
Other than that, I would follow the vehicle warranty expectations per service book guidelines and leave it at that. I was told lifetime on our CX-7 too but when you get upward of 70 or 80 k , we all like to hedge our bets.
Unless something pops up on your search indicating a fluid change was done and questioning the use of the correct 'stuff', I'd be settled on it.
Tranny fluid was a "very spec'd" item on our 2008 CX-7 - maybe a type 5 by Mazda. Toyo might have been the same too as per a type 5 that would have worked. Just recall it was fussy and expensive and I chose not to take any chances when I did my own drain and fill.
Not sure how that follows through though, I have yet to look up the spec on our '16 CX-9.
95 Honda Nighthawk- Rotella T6 syn
17 Golf SW 4MO dsg- Dealer LOF/5-6k *New spec syn -VW/Audi XOM ?
16 Mazda CX9 Tour- Dealer LOF/5-6k Casterol full syn
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5376597 03/15/20 02:24 AM
B
blufeb95 Online Content
Online Content
B
I'd change it like every 30-50k miles if you plan on keep the vehicle for the long haul, lifetime is a little misleading, "lifetime" means for the service life of the transmission which from Mazda's standpoint means that it'll last at least the warranty period but beyond that they don't care, changing it out every 30-50k should help extend the service life of the transmission.
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5376620 03/15/20 03:53 AM
bachman Offline
One item I forgot to add that made me a bit weary at the time we had the CX-7;
I was fairly familiar with many posts by various brands of vehicles mentioning a tranny flush brought on issues or troubles that were not pre existing. For that reason, my tactic was (if) to have the tranny flush done, only by the dealer and priorto the car passing it's warranty coverage date. We traded it off before such time but in the meantime, I did drain the fluid and top off with the spec stuff.
I mention this because I'll bet a warranty claim could get a bit sticky or worse by Mazda or the serving dealership IF one is to have flush done elsewhere, yet within the warranty period / miles. I wasn't going to take that chance.
*As above recommended, not a bad idea to get it done early or at those miles but what if ?
A) The dealer isn't the one doing it, B) Doesn't recommend it per "lifetime" claim, C) Another place does the work leading to a problem ?
Will Mazda back it or is it a fight ?
I'm just thinking strategically because I'm seeing more slop in the way things are being handled these days by a few. Mfg's making crazy claims on what is normal oil use or consumption over a few thousand miles etc....
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5376743 03/15/20 08:32 AM
K
Kira Offline
K
Gotta say "thanks" because I bought 4 qts. of FZ for the D&F on a family member's 2016 Mazda3 come 60K but....
I totally forgot about the diff. I assume the FWD versions have a front diff.
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5376766 03/15/20 08:59 AM
L
LotI Offline
L
The fluid is FZ and a drain and fill is all you should ever do. There's a drain plug and fill plug for that reason. Do not ever do a "flush".
My M6 took 3.75qts when I performed the service. It's just as easy as a Honda. Buy 5-6qts from the dealer if they take back what you don't use.
You'll probably have to let the dealer look up the PTU and rear diff fluids for you. Then you can look to see if there are other alternatives.
My AWD car uses 75w-90 in the PTU and rear diff but they are different fluids.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450 Cutaway
19 Buick Regal TourX
Retired:
17 VW GTI
17 Mazda6 GT
14 Honda Accord Sport
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5376919 03/15/20 11:32 AM
R
RamFan Offline
R
Yes, the correct fluid is FZ. You have two options (as of the last time I looked into this) Mazda or Ravenol. I chose to go with Ravenol as you can purchase it from Blauparts for a decent price when they run a special.
Has far as the diff & transfer case, you'll want to use Mazda Long Life Hypoid Gear Oil SG1. To my knowledge there is no aftermarket alternative at this time.
I will be changing the trans, t-case and rear diff at 75k.
18 Giulia Ti Sport Q4
  • 2.0T I4 - 26k - PP Euro LX 0w30 - PureOne - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 70k - Citgo Supergard Syn 5w30 - Wix - 7.5k/1yr
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5377125 03/15/20 04:17 PM
B
bulwnkl Offline
B
All gear boxes should have early fluid changes, after which they can run rather a long time before the next change. This means that instead of waiting until 60-90k miles, change at 10-15k miles at the very latest, _then_ change every xxx (whatever you like. 30k? 50k?).
The A/T also puts clutch debris into the fluid. I’d do a 3x or 4x drain and fill now if I was interested in keeping it for a loooong time. If I just planned to lease and return, or drive for a few years then sell (or crash and total), then you can ignore it if you like.
I did multiple d&fs on my ‘15 6’s A/T when I got it.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5377512 03/16/20 01:58 AM
sh40674 Offline OP
Since the lifetime spec is on there.. what I did with the wifes old fusion was check the fluid first, and as long as it was full, whatever I drained out was the exact amount I put back in (say I drained 4 quarts I replace 4 quarts)
Now.. say I drain 3.5 out of the Mazda... do I fill it off or start it in park and then fill? I know a complete refill of a tranny you cant get it all in at once without it running generally (at least the old school ones).. any issues with overflowing while it's off in these mazdas with a simple drain and fill?
Any additives needed on the front or rear pumpkin or just the mazda spec oil?
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5377514 03/16/20 02:00 AM
sh40674 Offline OP
And just fill the front and rear until it comes out of the drain holes? Any issues if it's on ramps or jacked up or must it be absolutley level for the diffs?
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5377938 03/16/20 03:27 PM
B
bulwnkl Offline
B
Follow the procedure in the service manual. If you don't already know where to find that, you need to search around on a Mazda forum or two. To check the level you'll need to measure the ATF temp. You can do that with a ScanGauge (or similar) or get good and close with an infrared thermometer. When the ATF is at the correct temp, you measure the level on the dipstick. It's not as hard as it sounds.
If you want to simply add the same volume you removed, you can do that. Generally it is recommended to let what you removed cool down to the same temp as the fluid you plan to add before you measure the removed volume.
Re: Mazda cx5 diff case fluids and which tranny fluid type? [Re: sh40674] #5379446 03/18/20 10:41 AM
SoNic67 Offline
It's not the fluid that changes the volume that much with the temperature, it's the aluminum transmission case and pan.
So letting the fluid "cool" after it was drained does not change the volume that much.
