Hello al!
Trying to decide if it is better to sell the car or open up the engine and drop more money into this car.
2010 Accord EX-L, V6 at 118k miles. I love my car, got the timing belt, valve adjustment and the big service done at 105k mi, but it is coming up with different noises and I'm having a hard time whether to keep it or not. I included a video link below. This started a few hundred miles ago, It does this noise starting at 2300 rpm, where it is the loudest. It does it at neutral or when driving, It is less above those rpms but still there. No sound is present at idle or below 2300 rpm. The engine runs very smooth, no jerking, shaking, vibration etc.
I took it to our Honda/Acura only mechanic, who has been servicing the car since 2014, he knows the car very well. He took the belt off to rule out other things and said that it definitely is coming from the top of the engine. He said he would have to further diagnose it but it will not be simple. He is worried that it may be worn cam lobes. The car never had any low oil issues (I read a few different threads on this here), so we are not sure if that is the reason. The oil level does not seem to drop. He said the engine will not likely seize right now, and it does not look like it is going to hurt the engine but obviously it is an issue that we need to get to the bottom of. He said he has had only a few cars with similar issues and if it went all the way to replacing the cam it may run up to $700 (all OEM parts).
Could you please see the video and let me know what your thoughts are? BTW the sound is a lot louder in the video compared to what you hear if you listened to it in person.
https://youtu.be/6z4mouIxZi0
