Applications for a new job
by 97prizm - 03/28/20 02:55 AM
Petro Canada 20L bucket
by MalteseFalcon - 03/27/20 11:34 PM
Toolbox corrosion protection
by buck91 - 03/27/20 09:39 PM
Milwaukee 2767-20 Impact Wrench
by Wolf359 - 03/27/20 09:38 PM
Economic choices?
by buck91 - 03/27/20 09:33 PM
Stripped Bolt...best extractor set?
by TXCarGeek - 03/27/20 09:27 PM
HF Charger barely lasted a year
by jayjr1105 - 03/27/20 08:52 PM
My dog is not doing well.
by Chris142 - 03/27/20 08:40 PM
head rest stain. how to get out
by WhyMe - 03/27/20 07:50 PM
Heavy fuel oil: can we talk about it?
by 53' Stude - 03/27/20 07:35 PM
ramping up production of something
by andyd - 03/27/20 07:29 PM
Who waits for the RPMs to settle before ...?
by TXCarGeek - 03/27/20 06:45 PM
Signed up for Instacart
by 14Accent - 03/27/20 05:53 PM
Future Toyota Vehicle Line-Up
by The Critic - 03/27/20 04:45 PM
Brake Shoes cleaned after soaked in brake fluid?
by Cressida - 03/27/20 04:34 PM
bdowning, OliverQ50, NorCalHD, narelikg, Rhino2278
71032 Registered Users
22 registered members (bachman, anndel, bmod305, Black_Thunder, 97prizm, AAIRCraig, 1 invisible), 562 guests, and 18 spiders.
Topics303,255
Posts5,232,686
Members71,032
8mm Hex Impact 1/2" Drive Suggestions #5376523 03/14/20 10:13 PM
gathermewool Offline OP
Any recommendations?
With a standard 8mm allen key I can't for the life of me get the Legacy's front differential fill plug to budge, even hours after applying Deep Creap and putting as much weight on the key as possible. The 8mm allen key fits in perfectly, leaving ZERO extra room for a breaker bar or longer key.
I'm hoping that my 1/2"-drive breaker bar will align so that I can use it with the subject drive.
Any suggestions on how to get it loose would be helpful, too. The fill plug requires removal of the passenger front wheel, since it's right above and to the left of the drive axle. to reach it, I have to reach on either side of the second cat-converter.
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: gathermewool] #5376529 03/14/20 10:22 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
On my Mercedes cars the diff plugs always are seized tight. I leave the car on the ground, fit the Allen socket in tightly, use a cheater on a breaker bar. Ive had to use leg power in some cases.
An impact rated Allen might be worthwhile here.
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: gathermewool] #5376534 03/14/20 10:27 PM
spasm3 Offline
HEAT. Heat it with a torch. It might have lock-tite red or some locking compound that needs heat. Get it at least 300 degrees or so and try again.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: spasm3] #5376537 03/14/20 10:48 PM
Unfortunately, there's not much room in there to use a cheater bar. I'm hoping I'll be able to get an 8mm socket in there and use my breaker bar past either side of the cat and exhaust.
If that doesn't work I'm hoping I can fit my impact gun in there.
Unfortunately, there's too much plastic and rubber in the vicinity, so heat will be hard to apply. If it comes to it, I'll definitely consider wrapping everything in foil and heating the plug up as much as possible.
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: gathermewool] #5376542 03/14/20 10:57 PM
H
HangFire Offline
H
Get a socket-drive hex key that also has hex flats, and then put a big wrench on the flats.
I have such a set, the Astro Pneumatic low profile 78314, currently 26 bucks on Amazon. They take a 17mm wrench, which is large enough to push some real weight on.
https://www.amazon.com/Astro-Pneumatic-Tool-78314-Profile/dp/B01JBK1FHG
Various musings: http://hangfire.net
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: gathermewool] #5376559 03/14/20 11:50 PM
Chris142 Offline
Put an 8mm socket and long extension on the other end of your allen key.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: Chris142] #5376582 03/15/20 01:31 AM
SLO_Town Offline
This.
Scott
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Castrol Magnatec 5W-30)
11 BMW E90 328i M-Sport (Pennzoil Euro 5W-40)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-40)
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: gathermewool] #5376599 03/15/20 02:28 AM
Char Baby Online Content
Online Content
I usually take a chisel and cut a groove straight on the fill plug with a few )))SMACKS((( of the hammer.
Then turn the chisel to the Right and smack, Lefty Loosey which actually starts to bugger up the edge some.
This usually help to loosen up the fill plug. I can't explain in here as well as I could show you but others may/may not agree.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: gathermewool] #5376687 03/15/20 07:22 AM
O
Olas Offline
O
how about an extra long allen socket like this
https://www.ebay.co.uk/i/183245125401?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=183245125401&targetid=876875609442&device=c&mktype=pla&googleloc=9046645&poi=&campaignid=9441049872&mkgroupid=99468942881&rlsatarget=aud-629407025185:pla-876875609442&abcId=1139126&merchantid=9722174&gclid=Cj0KCQjwpLfzBRCRARIsAHuj6qUHTT3bguclHecCyEg7Q0gmi0UQ5cfsY854WclJssZeo69xEFsFktUaArtcEALw_wcB
it should reach down far enough that your breaker bar will not be obstructed by anything
Cable ties should hold it
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: gathermewool] #5376725 03/15/20 08:15 AM
E
eljefino Offline
E
I would be concerned that an impact would chew up the middle of the plug. Lightweight parts of the "loosening chain" see more stress under impact.
Is there any other way to get fluid into that diff, like via a vent line?
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: Chris142] #5376740 03/15/20 08:30 AM
J
JC1 Offline
J
Use a 1/2 inch copper pipe as the cheater bar. That should fit.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 8mm Hex Impact 1/2" Drive Suggestions [Re: SLO_Town] #5377943 03/16/20 03:39 PM
The winning combination pictured below: 14" 1/2" drive breaker --> 1/2" to 3/8" drive adapter --> 8mm 3/8" drive hex key
-----I had the Craftsman breaker, purchased with points before all of the local branches when under
-----I picked up the adapter and hex socket from HF
I tried to open-palm the breaker bar as much as possible, but still managed to slightly bust my pinky knuckle as the plug let go with loud POP!!!, ripping way a 1/4" of skin in the process...
The next hardest part was getting the diff full and THEN lifting the car to re-install the overflow-check plug. I had to lift the rear up and shimmy under, since the overflow/check plug is on the rear driver-side of the front diff. I knew I was on the right track when I began to lift and the slight dribble through the port, indicating that the diff was full, completely stopped.
MAN DO I MISS HAVING ACCESS TO A LIFT!!! The Forester front diff was MUCH easier to do, because the fill port is the vent port, which requires pulling a vacuum-style hose which is connected via o-ring seal only. There's also so much clearance that I didn't have to lift to vehicle to shimmy under and re-install its overflow/check port.
[Linked Image]
For reference, the plug is just above the driveshaft, which is covered with a green rag in the first pic, since I was spraying Deep Creep and PB Blaster over the preceding 48 hrs.
[Linked Image]
Here you can see the cat and exhaust right beneath, leaving very little room to barely get my hand angled in past
[Linked Image]
Here you can see the plug (without the hex installed), above and to the left of the driveshalf
[Linked Image]
