Bought a used Tundra, 2014, mostly for Son to use. It has larger Wranglers on it now, about 1/3 tread left. The problem is the ride, slight vibration, which I think is tire related. It's good enough for right now. I checked psi, kinda high, plan to try a rotation too.
The wheels are KD aftermarket. I would like to go towards a more road friendly, all season type, Michelin ‘Defender' or similar. I would also like to reduce the tread width, but then a tad more height to the sidewall. That may be asking a lot.
Is there an easy way to know what alternative 18" tires may fit this wheel? Beyond that, ideas to go towards a more common, quieter, narrower, & taller tire?
Thanks. So far I come up with 275/70/18"?
