VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
129 registered members (5AcresAndAFool, 53' Stude, 2004tdigls, Alfred_B, Al, 2010Civic, 16 invisible), 1,887 guests, and 22 spiders.
Topics303,447
Posts5,235,438
Members71,072
Viper remote start systems any good? #5376150 03/14/20 10:04 AM
V
Vern_in_IL Offline OP
V
https://www.viper.com/car/
Looking for a good remote start national dealer network.
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376178 03/14/20 10:37 AM
B
BHopkins Online Content
Online Content
B
I've had a Viper remote start installed on my Outback for about 5 years now. I"ve been very happy with it. Here is the one I went with.
https://www.viper.com/car/remotestart/product/4816v/viper-value-2-way-remote-start-system
I like the 2-way, so you have an acknowledgement that the engine started. My only complaint about this kit, and all other kits I've looked at, is that only one of the two remotes is two-way. The second is only one-way. If you want to have two, two-way remotes, you have to buy a third remote.
On two occasions, my remote start has stopped working. But both times the dealer was able to fix it quickly, by just reprogramming everything. Of course the Viper lifetime warranty covered the reprogramming.
As far as which dealer to use, ask your neighbors and friends who they have used. Also, look at the dealers listed here. Go into the dealerships and talk to the techs. Find out what connection methods they use. Installation can make all the difference on how reliable the installation is. I personally suspect, that is why I have had to have my system reprogrammed.
https://www.viper.com/wheretobuy/
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376180 03/14/20 10:39 AM
SatinSilver Offline
I just did a quick search and they seem to rank pretty high. Of course it prob depends on which model you select.
https://www.google.com/search?sourc........0i131.7_SrK4fQV2k#spf=1584200196801
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376228 03/14/20 11:40 AM
A
Aichiguy Offline
A
I think the installer plays into the equation as well. I have a Viper on my 09 Ridgeline and it works well. The fob seems high quality. Just don't use a fly-by-night retailer would be my advice.
2019 Honda CR-V LX 2.4
2009 Honda Ridgeline 95k
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376241 03/14/20 11:49 AM
G
GMguy84 Offline
G
Have a 791XV remote start in my 82 trans am since 2006 and nothing but problems with remote range and defective crappy remote
Sometime this year im getting to this upgraded. All the local Audio shops swear by it !!
amazon.com/gp/product/B07HMX118W
Compustar CS7900-AS All-in-One 2-Way Remote Start and Alarm Bundle w/ 3000 feet Range
Dave
01 Silverado 1500HD Shell RGT 5W30 /XG3675
07 Suburban 1500 Mobil SuperSyn 10W30/ XG10060
09 Crown Vic Police Shell RGT 5W20 /POBOSS
82 Trans Am (KITT) M1HM 10W40/XG5
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376257 03/14/20 12:31 PM
H
hallstevenson Offline
H
I think in the world of alarms and remote starters, there's only a couple of hardware manufacturers out there. All of the brand names that you see all use the same hardware underneath. Look at Viper, Directed Electronics, Compustar, Crimestopper, Cllfford, Python, and so on. Many are owned by the same parent company.
What I've found is the "module" it common across most and what you are paying the difference on is the remotes, believe it or not.
What car is this for ? If you're lucky, you can get a remote starter that uses a T-harness for the connection. This avoids having to cut and splice many, many wires. Not all cars are set up to easily accommodate this though.
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376319 03/14/20 03:40 PM
F
fsdork Offline
F
I've had long term experience with Viper 2-way systems on two different vehicles.
The first was a past personal vehicle, a 2009 Ford Escape. No issues at all.
The second is my current work vehicle, a 2018 Chev Suburban. In this vehicle, the factory alarm system seems to be fighting the Viper. If I get up in the morning and start the vehicle with the Viper, the factory alarm goes off, and is a complete pain until the vehicle is turned off and re-started. If I disarm the Viper, then start the vehicle with the remote and re-lock the vehicle after it has started, there are no problems.
As others have mentioned, a lot of the issues with remote starters can be traced back to the installation. In the case of the Suburban, it was put in by a Chev dealer 3 hours from where I live, and I haven't been able to afford the downtime to bring it in and have them mess around with it. I might prioritize that differently if I hadn't found a workaround.
Overall, I would recommend a Viper 2-way from a reputable installer. I would suggest having the installer walk you through the functions before leaving their location with it, as this would help catch any installation or programming issues.
2003 Ford Explorer Limited 4.6L 4x4 - 219K km
2008 Ford CVPI 4.6L - 133K km
2011 Ford F-150 Lariat S/C 6.2L 4x4 - 90K km
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376365 03/14/20 05:36 PM
L
Lolvoguy Offline
L
I didn't think they (the company) lasted much past the 1990's.
shrug
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376493 03/14/20 09:18 PM
B
bowlofturtle Offline
B
i have a compustar 2 way installed on the infiniti for the last 5 years.
No issues what so ever.
Had a viper 2 way system installed on a Lancer around 2008. That remote needed a battery change every month and the range was way shorter.
My toys
-05 Infiniti G35x 140k
-03 Suzuki SV650N 8.5k
Maintaining
-16 Jetta 1.4T 20k
-98 Nissan Maxima 160k
-09 Toyota Camry V6 96k
Re: Viper remote start systems any good? [Re: Lolvoguy] #5376504 03/14/20 09:28 PM
B
Online Content
B
Viper is by far the leading manufacturer of aftermarket remote start and alarm systems. Directed makes Viper, Autostart, Clifford, AstorStart, Automate, Python, and a few other related brands. Although I don't know for sure, I suspect Directed probably sells more remote start / alarm systems than all others combined.
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5376730 03/15/20 08:17 AM
F
Falcon_LS Offline
F
I installed a 4105V on the Mitsubishi back in January 2017, never had a problem it. Great range, works beautifully.
Petro-Canada Duron HP 15W-40 CK-4/SN
99 Explorer: H17W02
00 Pajero: XG9688
01 Grand Marquis: XG2
05 Envoy: XG9837
Motorcraft 5W-50:
18 Mustang GT: XG10575
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5377240 03/15/20 06:47 PM
T
t1snwrbrdr12 Offline
T
I’ve had a viper system installed in our van for at least 6 years. It loses programming randomly but has only been 2 or 3 times and the dealer has been able to reprogram it as I waited. The remote failed once, I programmed it myself when it came in. I had it installed so that I can still operate my lower doors with it. It is a one way system but we love it, more so for hot days but it doesn’t hurt in the winter either.
I think, like others are saying, it comes down to the install. I would only have a reputable place install it. Not some cheap tint shop that does radios.
Re: Viper remote start systems any good? [Re: Vern_in_IL] #5377680 03/16/20 09:05 AM
T
Tdbo Offline
T
Viper makes a good unit.
However, the most important thing is installation.
If it is not installed properly, it doesn't matter what brand it is.
I have had remote starters on six of the automobiles that I have owned over the years.
All have been Audiovox units
The only issue that I have had with any of them was once I had to replace a remote battery after twelve years.
2012 Honda Accord LX-P 102K
2008 Ford Mustang Pony Package Convertible 17K
2006 Honda Odyssey EX-L 77K
2003 Ford Ranger 3.0 Supercab 126K
