I have heard 2 different methods for torqueing bolts when using a silicone sealant for a differential cover install.
1) Apply a bead of sealant to the cover and install until sealant starts to squeeze out. Let dry for 1 hour and then torque bolts to spec. (This is for Permatex Ultra Black)
2) Apply a bead of sealant and tighten bolts in cris-cross pattern, then torque to spec.
I am using Motorcraft Ultra Silicone Sealant. Directions say to apply sealant and assemble while sealant is still wet. No mention of when to torque.
What do you guys do?
