VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
121 registered members (Al, 53' Stude, 2010Civic, 2009Edge, AC1DD, 2015_PSD, 11 invisible), 1,947 guests, and 26 spiders.
Topics303,444
Posts5,235,397
Members71,072
Fuel Injector Cleaner vs Fuel System Cleaner? #5375436 03/13/20 11:30 AM
B
BucDan Offline OP
B
Looking to run a bottle through the car for some peace of mind. Been filling up with Chevron 91 in my car (see signature). I've seen pictures of the fuel injectors for this model car and they still looked a bit clogged and dirty even after the owners ran TT gas. Would this really make a difference? I know it won't get as clean as injectors going through a wash cleaner, but I'm poking some brains here for info.
If it makes a difference, then why should I pick one product over the other? Wouldn't they basically achieve the same goal?
Thanks!
2013 Audi S4 6MT - 45K miles
- OCI every 5K miles
- Motul X-cess 5w-40
- Mann OEM oil filter
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BucDan] #5375468 03/13/20 12:54 PM
V
Virtus_Probi Online Mad
Online Mad
V
Are you talking about the Chevron products in particular?
The last time I looked at the SDS for it, their Fuel Injector Cleaner product looked to be composed of petroleum solvents that would be typical of general low end gas treatment products that you might find in a typical gas station.
The Complete Fuel System Cleaner at least used to contain PEA...it's hard to say exactly what's in it now, but I think it's safe to say it has detergents that will work to remove carbon deposits (even in the combustion chamber).
Plus the CFSC will also contain solvents that are similar to those in the less expensive products for the type of cleaning they will do (which is probably minimal when a small bottle is dissolved in a gas tank).
I've been buying Gumout Regane products for a few years because I'm not sure exactly what's up with Techron's detergents lately, but I strongly suspect the CFSC is the product to go with here. And it's only about 50 cents more expensive than the FIC at Walmart...
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BucDan] #5375514 03/13/20 01:56 PM
B
blufeb95 Online Content
Online Content
B
I'm too lazy to pull the SDS, but If I recall right the Fuel System cleaner has about 3 to 6 times as much PEA as the injector cleaner.
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BucDan] #5375541 03/13/20 02:44 PM
B
BAJA_05 Online Content
Online Content
B
I seriously doubt Chevron Techron Complete Fuel System Cleaner is gonna take any steps "backwards" with there product. Run it with confidence per instructions on bottle. Gumout Regane High Mileage and Gumout All in One is also a good fuel system cleaner besides Redline S1 fuel system cleaner.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BucDan] #5375561 03/13/20 03:03 PM
csandste Online Content
Online Content
Yup, I use Chevron complete or one of the high PEA Gumouts, bought one of the Chevron injector cleaners but seemed to have lower detergency and little if any PEA (or whatever Techron is running now).
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BucDan] #5375608 03/13/20 04:20 PM
P
Pete Offline
P
I agree with all the above. Too bad there isn't a "nutrition information" chart for fuels system cleaners!
Another one to consider is the Lucas "Upper Cylinder Lubricant." This may not have PEA in it, but it's cheap.
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BucDan] #5375642 03/13/20 05:03 PM
Dinoburner Offline
Just ran a bottle of Chevron fuel system cleaner thru Wifeys Equinox and noticed smoother idle and better mileage. Am now chasing a tankfull of hytest through it which admittedly has little basis in logic. Just something we do after winter.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BAJA_05] #5375673 03/13/20 05:44 PM
B
Online Content
B
It hasn't they just started obscuring PEA on the datasheet, calling it some weird combo of letters and numbers, I've heard the old SDS used to say it had 32% or thereabouts of PEA and the current datasheet says something like 25-45% of 01154100-5179P, which I'm pretty sure is some internal identifier for the particular poletheramines that Chevron uses in Techron
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BucDan] #5376156 03/14/20 10:12 AM
Y
Y_K Offline
Y
It's an excellent product, but I have seen quite a few S4 engines taken apart, and those needed good, old hazelnut cream applications.
It is still good to run this through the system, but you had already done this with your regular Chevron fills.
Added: these cars love Italian tuning on a daily basis
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: blufeb95] #5376347 03/14/20 04:44 PM
M
Mad_Hatter Offline
M
Check out Chevron's foreign language MSDS's. Last I checked, both the French and Spanish one's "decoded" those numbers, revealing PEA as the ingredient. But in reality we know that already because "Techron" is Chevron's trademarked name for PEA and Chevron uses a couple of different patented, nitrogen based PEA cleaners in a kerosene/solvent like carrier.
Fwiw, Chevron still claims it's aftermarket cleaner to have the highest concentration of PEA. How one would verify that is beyond me...
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: BucDan] #5376513 03/14/20 09:56 PM
P
painfx Online Content
Online Content
P
You can try Redline SI-1. It has high PEA.
Re: Fuel Injector Cleaner vs Fuel System Cleaner? [Re: Y_K] #5377846 03/16/20 01:09 PM
B
BucDan Offline OP
B
Great thanks guys! Should be it be snake oil since I'm already always filling up with Chevron 91, at least I'll be at peace for $12 for a few thousand miles.
I know that when I run this car hard with WOTs, it seems to really really like it and clean up a lot where throttle response feels immensely better.
