RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
29 registered members (edhackett, Char Baby, FT92, 73guna, alcyon, 3 invisible), 1,164 guests, and 20 spiders.
Topics303,700
Posts5,240,225
Members71,116
Page 1 of 3 1 2 3
2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles #5375260 03/13/20 08:23 AM
ChrisD46 Offline OP
Below is my first UOA on my 2017 Hyundai Sonata 2.4L GDI (non - turbo) performed by WIX - Atlanta.
I've run a DEXOS approved 5W30 all it's life (34K miles) with 4K mile OCI's using a Fram Ultra #9688 oil filter changed each time.
QSUD 5W20 was used with an OCI of 3,800 miles ; suburban driving conditions run from Oct. 2019 to end of Feb. 2020 in Georgia with average runs of 40 minutes (one way to work) .
I wanted to establish a worse case OCI with the QSUD 5W20 (I normally run a 5W30 D1 / Gen 2 rated synthetic oil for 4K miles ) .
*Your comments regarding the wear numbers , sodium , TBN , etc. ?
Wix - Atlanta Report:
Engine wear levels appear satisfactory for first sample.
Silicon level (dirt/sealant material) satisfactory.
Water content acceptable.
Viscosity within specified operating range.
Action: Resample next service interval to monitor and establish wear trend..
SAMPLED29-Feb-20
Quaker StateUltimate DurabilitySAE 5W20
Metals (ppm)
Iron (Fe)14
Chromium (Cr)<1
Lead (Pb)<1
Copper (Cu)2
Tin (Sn)<1
Aluminium (Al)3
Nickel (Ni)<1
Silver (Ag)<1
Titanium (Ti)4
Vanadium (V)<1
Contaminants (ppm)
Silicon (Si)16
Sodium (Na)9
Potassium (K)2
Additives (ppm)
Magnesium (Mg)533
Calcium (Ca)1370
Barium (Ba)<1
Phosphorus (P)666
Zinc (Zn)812
Molybdenum (Mo)167
Boron (B)37
Contaminants
Water (%)<0.05
Coolant : No
Physical Tests
Viscosity (cSt 100C)7.9
Physical / ChemicalBase
TBN Number (mgKOH/ 2.9
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375288 03/13/20 08:43 AM
A
ARCOgraphite Offline
A
Wow looks Ok, but way short OCI.
I'm at 9K OCI now with the subaru and posting much better than average UOA.
Try 75000 next time.
warranty? Show then the UOA, they can't deny if there is no lube related failure.
S Korea trying to destroy our environment .
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375345 03/13/20 09:43 AM
Danno Offline
Iron seems high, and TBN is getting low.
Canada has 3750 mile OCI requirement for Hyundai.
If it was my Sonata, no more than 5,000 miles between OCI. If PYB 5W-30 saves money vs QSUD, I would run that at max 5,000 miles.
More important to run shorter OCI on DI engines vs running synthetic, and longer intervals - imo of course.
And I would run the OE Hyundai blue can filter, it's robust, and just works for this application.
Owned a 2013 2.4L Sonata until it was totaled.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375369 03/13/20 10:14 AM
Propflux01 Offline
5k OCI, especially if is GDI. check that air filter, silicone (to me) is too high. 5w-30 regardless of what the oil cap says.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375383 03/13/20 10:29 AM
csandste Offline
Five with 5w30 is my usual with any HyunKia. Of course some will say that the base of 5w20 is actually stouter and it probably makes little difference.
2017 Kia Soul+ Valvoline Daily Protection 5w30+ a bit of Harvest King syn 5w30-- 75,000 miles
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375396 03/13/20 10:40 AM
ChrisD46 Offline OP
*OP Here : I failed to state that 1 quart of make up oil was required over the 3,800 OCI (QSUD 5W20 was used for make up oil as well … Probably doesn't make the OCI look as good now ?
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375415 03/13/20 11:06 AM
T
Triple_Se7en Offline
T
Go back to 5W30 and stay at 4K OCI. That's what I'm doing with my 2.4 GDI. SOPUS or Valvoline oils are a good choice.
Wix/OEM, Mobil-1, Toughguard and Ultra oil filters are probably the best for Hyunkia GDI/TGDIs. All protect well. Any Hyunkias before 2016 should probably just use OEM oil filters.
I prefer Calcium at 1100 max. Yours is nearing 14. Your Zinc is up-there. The add-pack for 5w30 should be a little different. It will probably see lower Zinc and lower Calcium..... plus for sure be Dexos 1 Gen 2.
Keep Your Pistons, Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Platinum 5W30 / AC Delco PF 1127
04 Chev Colorado Napa Syn 0w20 & K&N
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375429 03/13/20 11:21 AM
J
JustN89 Offline
J
A quart low over 3800 miles would not leave me with the warm and fuzzies, but it's certainly not something to be exceptionally concerned with. It just warrants monitoring. I agree with the above, try a 5W-30 or, being in GA, even a 10W-30. I don't think you're going to see much better wear numbers as those look to be right at averages for that engine, but it's worth a change in viscosity to see if it can curb some of the oil usage.
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: JustN89] #5375432 03/13/20 11:24 AM
T
T
Yep, 10w30 might be the best idea for a rainy night in Georgia. Could cut consumption in half and still protect as well.
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375450 03/13/20 12:19 PM
B
benjy Offline
B
ditto on above quaker state ultimate durability fake synthetic 10w30 is what girlfriends 18 kia optima gets, no consumption unlike her oil eatin 60 plus thou 2.5 13 malibu it replaced
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: JustN89] #5375534 03/13/20 02:31 PM
ChrisD46 Offline OP
*I'm not particularly pleased with the 1 quart of QSUD 5W20 make up oil used over the 3,800 mile OCI run . I wanted to use the exact same make up oil as the 5 qrt fill I used (QSUD 5W20) to keep the test consistent . The air filter (Hyundai OEM) was changed less than 10,000 miles ago but I will check it to make sure it's seated properly ... Currently I have PUP 5W30 (from my stash) as the current oil fill with a Fram Ultra #9688 being used . I'll run this fill for a 4,000 mile OCI and see how things look with another UOA .
**If nothing else , I'm happy providing an actual UOA on a well maintained 2017 Hyundai Sonota 2.4L GDI non - turbo engine for the Bob's oil community to have on hand for reference .
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5375737 03/13/20 07:12 PM
T
T
Looking forward to your PUP results Chris. Just wish it were the 5w30, to match mine. But my UOA ain't coming until Fall. My retiree job shuffling handicapped kids around in a big yellow bus shut down due to Covid19 and may be down for months. So my Hyundai will sit in the driveway for long spells gathering dust.
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: ChrisD46] #5376868 03/15/20 10:40 AM
Propflux01 Offline
Keep an eye on that consumption. Rather high in my opinion for that mileage. From what I’m understand, GDI engines that start using oil are because GDI tends to coke oil rings rather quickly.
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: Triple_Se7en] #5377311 03/15/20 07:48 PM
ChrisD46 Offline OP
*Current fill now is PUP 5W30 with a 16 oz. bottle of Rislone to clean rings better to see if oil consumption will slow down . Doubtful the Rislone will do much as this GDI engine has seen D1 / Gen 2 synthetic oils <5K mile OCI's it whole life of 34K miles .
Re: 2017 Hyundai Sonata 2.4L GDI QSUD 5W20 3,800 Miles [Re: Propflux01] #5377313 03/15/20 07:50 PM
ChrisD46 Offline OP
*I agree - hence why I am trying the Rislone to deep clean the rings.
Page 1 of 3 1 2 3
