Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Two year check in - Dewalt 20 V String Trimmer
by Snagglefoot - 05/31/20 08:07 AM
Sturmey Archer 3 Speed-Shifting?
by ET16 - 05/31/20 07:45 AM
Power washing your home
by ARB1977 - 05/31/20 07:05 AM
Clint Eastwood car collection.
by PimTac - 05/31/20 04:51 AM
Bulk Oil Setup
by Jason_Michaels - 05/31/20 04:39 AM
First generator
by daves87rs - 05/31/20 01:50 AM
New junk tool
by P10crew - 05/31/20 01:07 AM
tetraethyl lead additive
by painfx - 05/31/20 12:40 AM
Best handheld cordless vacuum?
by montero1 - 05/31/20 12:15 AM
2005ToyotaSolara3MZ-
FE coolant leak
by juca - 05/30/20 11:22 PM
I made a dually today. Carftsman LT1000
by ls1mike - 05/30/20 10:39 PM
New Prestone Products
by Snagglefoot - 05/30/20 09:17 PM
BEST OBD2 scanner for UNDER $100
by flinter - 05/30/20 08:44 PM
AbbeyRoad, RPF, Rayi, juca, jrow96
71584 Registered Users
82 registered members (53' Stude, 2015_PSD, addyguy, 14Accent, 8 invisible), 2,522 guests, and 17 spiders.
Topics306,089
Posts5,286,163
Members71,584
Alcohol In Dry gas #5374803 03/12/20 06:25 PM
T
Toros Offline OP
T
What type of alcohol and what percentage by volume is it? I'm talking about Heet or similar gas line anti freeze.
"Beware the calculations of the meek, who gambled nothing, gave nothing, and could never receive enough." - John Ciardi
Re: Alcohol In Dry gas [Re: Toros] #5374818 03/12/20 06:39 PM
K
kschachn Offline
K
You should be able to find that in the SDS. For the Heet product in particular, the yellow bottle is methanol and the red bottle is isopropyl alcohol. Both are mostly alcohol with some minor other additives.
Red bottle Heet:
https://www.imperialsupplies.com/sds-pdf/_s/ds/0055120_SDS.pdf
The yellow Heet is 100% methanol per the SDS.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Alcohol In Dry gas [Re: kschachn] #5374882 03/12/20 07:46 PM
T
Toros Offline OP
T
Red bottle Heet:
Thank you
Re: Alcohol In Dry gas [Re: Toros] #5375025 03/12/20 10:06 PM
Donald Offline
With E10 gas why does anyone need gas line antifreeze?
But the local Stewarts (quick mart) sells it. If you buy 10 gallons of E10 you are getting a gallon of alcohol, maybe less, but probably at least 1/2 gallon. What will another 12oz or 16oz do that the first gallon did not? If you have that much water in your gas you have major problems.
2015 Ford F-250 w/Powerstroke
Re: Alcohol In Dry gas [Re: Donald] #5375127 03/13/20 03:35 AM
O
Olas Offline
O
Beat me to it! I was going to ask the exact same question.
Re: Alcohol In Dry gas [Re: Toros] #5375235 03/13/20 08:03 AM
gathermewool Offline
Poor man’s meth injection???
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Alcohol In Dry gas [Re: Olas] #5375241 03/13/20 08:06 AM
V
Virtus_Probi Offline
V
I used to get water buildup in my old snowblower even with E10 gas, one time I had to have a shop pick it up midseason when I couldn't get it to start and they told me the carburetor was just sodden with water. I would imagine that filling it up out in the driveway during snowstorms could have been the culprit, so I started being proactive by taking it back into the garage to top off the gas before it ran out as well as putting a bit of water remover in there.
Don't use the stuff in our cars...
I am actually wondering if my new snowblower has EFI...will have to look at it when I get home, can't even remember right now what brand it is!! Bought it cuz it's a three stage and I need to throw the snow a good distance with the ~30 foot turnaround circle in front of the garage. Old unit is a Yardman tracked jobbie, it put in over 20 years of yeoman service but just plain started to fall apart and some things were going to be tough fix...like a bolt holding part of the casing on needed to be retapped into the block. The track sprockets were shedding teeth like crazy when it was new, but they replaced those during the carburetor service and I didn't lose a tooth off those in 15 years.
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: Alcohol In Dry gas [Re: Toros] #5375261 03/13/20 08:23 AM
A
ARCOgraphite Offline
A
making some hand sanitiser?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Alcohol In Dry gas [Re: Toros] #5375280 03/13/20 08:35 AM
A
A
Don't forget to add some Locust bean gum ( or similar) as a thickener
They say 60% Ethyl but I'm sure 50% or a 2-propanol is fine.
