Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
109 registered members (ArrestMeRedZ, 2004tdigls, 762fermeandyou, 2015_PSD, 1978elcamino, 11 invisible), 2,629 guests, and 22 spiders.
Topics305,903
Posts5,282,478
Members71,535
Page 3 of 3 1 2 3
Re: Here it goes again [Re: P10crew] #5374373 03/12/20 10:25 AM
B
bullwinkle Offline
B
It’s looking more & more like big gas is the way to go in the F-450/-550s, the diesel ones just can’t seem to take it. And gasoline is only 2/3rds the price of diesel (& falling) these days anyway. Agree with the posters above, let us know what happened to it, and I share your Ford dealership frustration!
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Here it goes again [Re: P10crew] #5374395 03/12/20 10:53 AM
ls1mike Offline
I was just going to say something like that. Do you need a diesel? What is the combined weight of loaded truck and trailer. I mean a gasser can have problems too, but a cost perspective it will be cheaper to fix.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Here it goes again [Re: ls1mike] #5374602 03/12/20 02:44 PM
P10crew Offline OP
No we don’t need diesels. In fact back in the day we were just fine with the big blocks.
Here’s the deal though. My crew now has 2 soon to be 3 I hope diesels of fords competitor that are at about the 25-28,000 mile mark with absolutely no problems what so ever and the hands that drive them give them rave reviews. As stated prior we don’t baby them and they get worked hard. Oh btw we did have to relocate the urea tanks on the 2 new ones because they got smashed right away. Other than that we will see.
Latest update on the trouble child is that the service manager called to say they MAY have time to get it in the shop next week but more than likely the following for the diagnosis.
In the mean time another crew offered us one of their new trucks for a couple weeks. 👊
Re: Here it goes again [Re: P10crew] #5374749 03/12/20 05:10 PM
super20dan Offline
just stop buying ford diesel trucks-its that simple
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Here it goes again [Re: P10crew] #5375550 03/13/20 02:51 PM
M
MNgopher Offline
M
Stories like these exemplify why many of us, in fleet use and when applications allow for it, go gas instead of diesel.
Current employer has over 200 F250, 350, 450, and 550s. No diesels in the bunch anymore. The 550s can still tow over 16k with gas power, and it's more than we need.
Re: Here it goes again [Re: P10crew] #5376302 03/14/20 02:43 PM
sloinker Offline
In the oil patch around here there are many service trucks running around in 3/4-1 ton variations. Most are flat beds, 4x4's in white. About 80% are Rams with GM and Ford sharing the rest of the market. Not sure if this is due to cost/reliability/peer pressure. I agree with other folks, unless you need that huge diesel torque it makes no sense to not get a gasoline engine nowadays.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Here it goes again [Re: P10crew] #5378657 03/17/20 01:13 PM
P10crew Offline OP
They left me a message this morning saying turbo,injector pump and exhaust manifold needs to be replaced . No other info
Re: Here it goes again [Re: P10crew] #5378687 03/17/20 01:44 PM
M
mattd Offline
M
Sounds like fuel system failure along with turbo failure possibly? They are probably changing out the passenger manifold because the bolts for the egr inlet pipe broke off in the manifold. That will be a hefty bill. If the pump failed like they usually do you’ll need entire high side sysyem or their “contamination “ kit. They’d be crazy and foolish to replace the pump in this type of failure.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Here it goes again [Re: P10crew] #5378890 03/17/20 05:14 PM
P10crew Offline OP
Does any of that require another cab off?
Re: Here it goes again [Re: P10crew] #5378914 03/17/20 06:01 PM
M
mattd Offline
M
No it can all be done with it on. Though , with it off, it would make everything easy...I guess it depends on the tech. Cab removal is quick on a 6.7....1-1.5 hrs as long as there isn’t excessive wiring to separate between cab and chassis, or cab to utility bed
ASE Master, L1, L2
Re: Here it goes again [Re: P10crew] #5378981 03/17/20 07:49 PM
P10crew Offline OP
This ones been off twice so far.
The only wiring other than lights and trailer is that this rig has a Tommy gate and all of our rigs have big inverters this ones in a box on the bed.
Page 3 of 3 1 2 3
