Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
117 registered members (2015_PSD, 1911CHAMPION, 14Accent, 5AcresAndAFool, 14 invisible), 2,001 guests, and 54 spiders.
Topics306,109
Posts5,287,681
Members71,602
Amsoil new vs old SS oils #5373678 03/11/20 05:52 PM
spiderbypass Offline OP
I think the Low Speed Pre-ignition problems have negatively or at least hindered AMSOIL Signature Series oils. Comparatively speaking they do use more detectable additives compared with other synthetic oils that have lowered calcium levels and also use combination of calcium/magnesium wear package. However-Amsoil’s previous formula was absolutely loaded with Calcium like 3500 or more and still included moly and boron. I think the older formula resulted in maintaining a higher tbn throughout extended drain intervals. In several used gasoline oil analysis reports-it seems Amsoil’s tbn does not hold up as well as previous formula. Virgin oil analysis also has shown a starting tbn of 9 as opposed to 12.5 on data page. Wondered if others have noted similar general observations or am I over-generalizing or not seeing this potential trend accurately.
Insecurity with overcompensation are the root of evil deeds.
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5373761 03/11/20 07:21 PM
M
Mainia Offline
M
Doesn't the low calcium based formula dictate the use of another form of testing process because the new versions underlying add-pack is more complex then the older formula and gives a low TBN reading? New oils need ASTM D2896 vs old ASTM D4739 that give new oils a low TBN. What say you?
2018 Lowered Hyundai Kona AWD 1.6T
2014 Toyota Rav4 AWD
2005 Honda Civic
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5373951 03/11/20 09:37 PM
MolaKule Offline
Global Moderator
Global Moderator
...I think the older formula resulted in maintaining a higher tbn throughout extended drain intervals. In several used gasoline oil analysis reports-it seems Amsoil’s tbn does not hold up as well as previous formula.
What do you mean by "hold up" and from what VOA/UOA analysis supports your definition?
... Virgin oil analysis also has shown a starting tbn of 9 as opposed to 12.5 on data page. Wondered if others have noted similar general observations or am I over-generalizing or not seeing this potential trend accurately.
You are assuming that calcium, magnesium and sodium chemistries are the only chemistries available that can control TBN.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5374029 03/11/20 11:00 PM
M
madeej11 Offline
M
It still has moly and boron. Just check out a new formula voa.
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5374051 03/11/20 11:36 PM
O
OilUzer Offline
O
What determines or help TBN retention?
In general and not focusing on Amsoil, let's say your start with oil #1 with tbn of 12 and oil #2 with tbn of 9 ... If after 7000 miles and in the same engine, oil #1 has a tbn of 1 vs. oil #2 having a tbn of 3 ...then which oil is better? I would think oil #2.
Isn't retention more important than the starting number?
Re: Amsoil new vs old SS oils [Re: OilUzer] #5374076 03/12/20 12:40 AM
MolaKule Offline
Global Moderator
Global Moderator
Any alkaline component, whether seen or not seen in a low cost analysis, sets the original starting point.
To answer the second part, anti-oxidants, metal inhibitors, and stable DTC compounds can reduce oxidation, metal catalysis and acid formation, respectively..
Recall that any of the "Dithio" compound contains sulfur and phosphorus atoms as do ZDDP and MoDTC. Anytime we have sulfur and phosphorus atoms breaking away from those compounds, those molecules can contribute to acid formation. The more stable the ZDDP and MoDTC compounds, the less chance there is that the sulfur and phosphorus atoms in those compounds can break away to cause acid formation.
Yes, TBN retention is very important.
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5374236 03/12/20 08:08 AM
Saw this post and at glance seemed like oil did not hold up as an exemplary product like Amsoil usually does-now when looking at it again-did seem like gentleman’s engine had fuel dilution going on as well.
https://www.bobistheoilguy.com/foru...ra-amsoil-ss-5w30-5300-miles#Post5354529
I appreciate your response MolaKuke and you are correct-I was totally assuming that-often look at additive package that can be seen on an oil analysis and do not consider unseen additives that constitute many qualities of the oil including tbn retention.
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5374256 03/12/20 08:29 AM
M
metroplex Offline
M
BITOG has told me Amsoil SS 5W-30 doesn't even meet Dexos 1 Gen 2 contrary to their claims.
Re: Amsoil new vs old SS oils [Re: metroplex] #5374371 03/12/20 10:23 AM
V
Virtus_Probi Offline
V
Amsoil just claims to pass the d1G2 LSPI tests with their SS line.
They come right out and say their sulphated ash levels are too high for the d1G2 standard...and I think this is something of an advertising point for them as they seem to like to claim they have a lot of "good stuff" in their oils (some here would call them "stout" as a result). Some would argue from the other end that high SA might lead to extra deposits in DI engines. I wouldn't have a problem running 5W30 SS in my FXT, just too expensive for my tastes.
2014 Forester XT, 114800 miles
Last Change;
Valvoline AFS 5W30
Tokyo Roki 15208AA170 oil filter
Subaru 16546AA10A air filter
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5374375 03/12/20 10:30 AM
J
JoelB Offline
J
Dexos is a certification. Amsoil doesn't have it. They don't claim to have it. They very sneakily imply they have it by saying they exceed the requirements. Simple as that.
Mine: 2020 Corolla SE
Factory fill
OE Filter
Wife's: 2018 Chevy spark 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: Amsoil new vs old SS oils [Re: JoelB] #5374587 03/12/20 02:31 PM
T
Tundra73 Offline
T
BS. There is nothing sneaky about it. They don't have the cert. They don't claim to have it. They don't imply anything. They just state the fact that their oil exceeds the requirements of the cert. Simple as that. Anyone who states that means they are implying that they have the cert is not very bright.
2019 Toyota Tundra CrewMax 5.7 FFV V8 4x4 | Amsoil SS 0w-20 | Toyota OEM Oil Filter | 10,000 OCI
2017 Hyundai IONIQ | Amsoil SS 0w20 | Hyundai OEM Oil Filter | 10,000 OCI
Re: Amsoil new vs old SS oils [Re: Tundra73] #5374623 03/12/20 02:59 PM
K
kschachn Online Content
Online Content
K
No, you are the one that doesn't understand. They say to use the oil in applications that require any of the following specifications, then they include dexos 1 Gen 2 in the list. Contrary to your statement this most certainly does imply it meets the spec requirements. But then they later say it does not meet the specification because it exceeds the sulfated ash requirement for the license. The thing is that this part of the specification is integral to the dexos 1 Gen 2 licensing. They try to make it sound like it is a good thing but in fact the upper limit for sulfated ash in dexos 1 Gen 2 is there for a reason.
One might counter that those who carefully read what they say and comprehend it are the ones that are brighter than the ones who don't. Why are apologists for some brands often the ones who come on with snarky remarks like this?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Amsoil new vs old SS oils [Re: kschachn] #5374685 03/12/20 03:55 PM
T
Tundra73 Offline
T
Excellent point. My apologies to JoelB. However, I am not an apologist for Amsoil. This is my first time using it with my vehicles now that my free oil changes are finished. I was giving my opinion based on what I read without throughly researching the specifics. Not a wise decision on my part.
Maybe you should use some of your intellect to consider that people often make decisions without truly thinking it through, a fault yes, but not an indication that people are brand loyal.
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5374693 03/12/20 04:18 PM
Ironically if Amsoil kept their old formula that I miss so much because I drive a 2000 Lexus-then their statement about compliance with the new Dexos1 gen 2 would be outlandish. The older Signature Series oils had a sulphated ash content of 1.4 according to oil analysis on the Oil Club Ru. Amsoil’s current formula has an ash content of 1.02 according to a virgin analysis done in the Russian Oil Club.
Amsoil and Redline are “boutique” oils that provide exemplary choices for the consumer who may want a little more performance or a longer drain interval in their vehicles. I have and would use their products without hesitation-both oil companies have been around for forty years or more and are used worldwide-How else would I have data from a Russian Oil Club that has done awesome virgin oil analysis on multiple Redline and Amsoil products. Google AMSOIL oil club ru or Redline Oil club ru and it will have multiple virgin oil analysis of multiple products from both companies. Use google translator for English .
Re: Amsoil new vs old SS oils [Re: spiderbypass] #5374714 03/12/20 04:37 PM
This is a link to all oil analysis from the Oil club ru-
http://www.oil-club.ru/forum/topic/7906-idealnye-masla-po-vashemu-mneniyu/page-30#entry628868
I like how they often estimate the type of synthetic base stocks used in most of the oils that are analyzed in their website.
