98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
MechEnDawg, jimbacot, MowerVet, RonWSmith3, LJB
71535 Registered Users
113 registered members (50jeffrey, 928, alchargo, 53' Stude, 762fermeandyou, Al, 11 invisible), 2,724 guests, and 63 spiders.
Topics305,905
Posts5,282,539
Members71,535
Page 2 of 3 1 2 3
Re: Here it goes again [Re: P10crew] #5373824 03/11/20 08:03 PM
V
vw7674 Offline
V
Is there a way to retrofit 7.3 PS into later chassis to put an end to the issue?
Or is it an emissions nono?
Re: Here it goes again [Re: P10crew] #5373852 03/11/20 08:17 PM
M
mattd Offline
M
Injection pump could have locked up and stop the engine from turning over. I have seen that first hand. These engines are usually good for 20,000-25,000 hours. Before needing over hauls. The one I thought locked up still wouldn’t turn over with all the glow plugs out. Got down to the CP3 and it was LOADED with metal. Would not move. Could spin the engine over with my hands after removing the pump.
Only wild card, what is the build date? Early 11s had exhaust valve issues where the ends would break off during regen and usually destroy the affected cylinder(s). There was a manufacturing issue with the valves themselves that caused it.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Here it goes again [Re: P10crew] #5373858 03/11/20 08:21 PM
super20dan Online Content
Online Content
junk that only fools buy
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
Re: Here it goes again [Re: P10crew] #5373859 03/11/20 08:22 PM
P10crew Offline OP
2011
Re: Here it goes again [Re: P10crew] #5373861 03/11/20 08:23 PM
M
mattd Offline
M
Originally Posted by P10crew
2011
Build date?
Did it die during a regen by chance? Any low fuel pressure warning pop up on the IC? I am going to guess HPFP/fuel system failure but definitely curious to what failed. Those cab and chassis turbos are much more reliable than the pickup ones FWIW
ASE Master, L1, L2
Re: Here it goes again [Re: PimTac] #5373868 03/11/20 08:30 PM
A
AC1DD Offline
A
Originally Posted by PimTac
Originally Posted by sloinker
Navistar knew how to build an engine back in the day.
Yep, when they were known as International Harvester.
I wonder how much they paid some genius to rename the company. Hahaaa..
The priorities these insane companies have.
Re: Here it goes again [Re: P10crew] #5373869 03/11/20 08:30 PM
P10crew Offline OP
Dan they keep low balling the rest of the field.
Thank god I have a supervisor that has the berries to 86 this brand completely. They are slowly going away And I just hope it’s another motor because I think they will ditch this thing if it is.
Re: Here it goes again [Re: mattd] #5373878 03/11/20 08:36 PM
P10crew Offline OP
2011
Build date?
Did it die during a regen by chance? I am going to guess HPFP/fuel system failure but definitely curious to what failed. Those cab and chassis turbos are much more reliable than the pickup ones FWIW
I don’t know I’m home now and it’s at the dealership. Honestly I hope I only see this one last time. The day we go get our tools out of it.
I fully understand the cab and chassis difference. We buy all of them that way to get the biggest of everything. I’m sure you know exactly what I’m saying here.
We had been off hiway all day and he was giving her [censored] to get up to interstate speed on an on ramp. He said he was looking at the boost gauge when it let go. I find myself looking at the boost gauge a lot too. Gutless until max boost is reached.
Re: Here it goes again [Re: P10crew] #5373882 03/11/20 08:38 PM
M
mattd Offline
M
2011
Build date?
I fully understand the cab and chassis difference. We buy all of them that way to get the biggest of everything. I’m sure you know exactly what I’m say here.
I understand your frustration. Good luck and please Post back when you find out what happened!
ASE Master, L1, L2
Re: Here it goes again [Re: P10crew] #5373895 03/11/20 08:50 PM
A
A_Harman Offline
A
2011
Build date?
What is the approximate GTW that you work the truck?
2008 Dodge Ram 3500 diesel/G56
1985 Z51 Corvette track car 355/6-speed
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel/NV4500+GV
1972 GMC 1500 shortbed project truck 307/SM465
Re: Here it goes again [Re: P10crew] #5373912 03/11/20 09:00 PM
P10crew Offline OP
The heaviest trailer that we have loaded weighs 11,000
The safety folks watch the weight stuff to a T.
Re: Here it goes again [Re: mattd] #5374066 03/12/20 12:11 AM
02SE Offline
You're more familiar with the 'Scorpion' than I am, but I was pretty sure they used the CP4.2.
Re: Here it goes again [Re: P10crew] #5374126 03/12/20 05:10 AM
A
Amkeer Offline
A
There is a reason Ford stock trades at $5+ a share and going lower. Sad.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
Re: Here it goes again [Re: 02SE] #5374162 03/12/20 06:17 AM
M
mattd Offline
M
They do thanks for catching the typo!
ASE Master, L1, L2
Re: Here it goes again [Re: vw7674] #5374229 03/12/20 07:58 AM
J
jeepman3071 Offline
J
Nope, emissions regulations won't allow that.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Page 2 of 3 1 2 3
