Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
98 registered members (azjake, 55hambone, andyd, ammolab, Alain2, 7 invisible), 2,280 guests, and 37 spiders.
Topics306,108
Posts5,286,556
Members71,586
NAG1/W5A580 Behind 5.7 Hemi, 91k Miles, Fluid Change Now or Already Too Late? #5373825 03/11/20 08:05 PM
M
Msmith68w Offline OP
M
Alright I know this might be a controversial topic, but I have had some personal experience with automatic transmissions that crapped the bed immediately following a fluid/filter change. My theory for this is that the clutches are already failing, but the contamination of the fluid gives them the "grit" necessary to continue to function. Once you remove the old fluid and replace it with nice new fluid, the failure of the clutches becomes apparent and you lose function and end up needing a rebuild/replacement.
I just purchased a 2014 Charger R/T with 91k on the clock. The transmission functions perfectly, and I'd like to keep it that way for a long time. Chrysler says the first transmission fluid change should occur at 60,000 if used for police, taxi, or frequent towing (none of these apply, but it was probably hot-rodded a fair bit), or 120,000 under normal driving. At 90k, I'm splitting the difference there almost exactly, and I think the usage is probably somewhere in-between normal and severe duty as well...so it seems like a safe enough bet to go ahead...I'm just nervous about it.
Is there anyone here with significant experience with these transmissions that could speak to this issue and give a recommendation? I would like to add that I just ran a piece of coated cable down the dipstick tube and blotted a small amount of the fluid on a paper towel to check the condition. It's still red, not brown or black, but a dark red. By comparison, I dabbed a little fresh ATF+4 on the towel and it looks pink. So there's some fluid degradation for sure, but it's not in horrible shape. Doesn't smell burnt, but doesn't smell fresh either.
Thanks.
Re: NAG1/W5A580 Behind 5.7 Hemi, 91k Miles, Fluid Change Now or Already Too Late? [Re: Msmith68w] #5373862 03/11/20 08:23 PM
clinebarger Online Content
Online Content
The NAG1 is a very tough unit, Change the fluid & sleep well!
2001 Chevy Camaro L92/4L80E
Re: NAG1/W5A580 Behind 5.7 Hemi, 91k Miles, Fluid Change Now or Already Too Late? [Re: Msmith68w] #5373925 03/11/20 09:11 PM
slacktide_bitog Offline
welcome
There is nothing wrong with replacing the fluid if the transmission still shifts fine smile
If your transmission doesn't have a drain plug, buy an aftermarket pan that has one. This will make future ATF changes much easier
You can use any licensed ATF+4 from Chrysler's official approved list. Even Walmart brand ATF+4 is approved.
Re: NAG1/W5A580 Behind 5.7 Hemi, 91k Miles, Fluid Change Now or Already Too Late? [Re: clinebarger] #5374130 03/12/20 05:18 AM
demarpaint Offline
+1 As mentioned use only ATF+4, I would not use a universal fluid in that unit. hide
God Bless Our Troops
Re: NAG1/W5A580 Behind 5.7 Hemi, 91k Miles, Fluid Change Now or Already Too Late? [Re: Msmith68w] #5409459 04/21/20 11:47 AM
T
The_Nuke Offline
T
I have purchased 3 Dodge LXs in the past 10 years that were used and had at least 90K miles on their NAG1 transmissions. All worked fine before the fluid and filter change i did, and all worked fine after.
Use ATF +4 and you’re golden to do the fluid and filter on yours like you desire.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
