Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Ivan30, mikespine, Typerguy, showtyme1958, rickyradit
71529 Registered Users
39 registered members (Boomer, Amkeer, Astro14, alarmguy, blufeb95, 87sammy, 3 invisible), 1,208 guests, and 34 spiders.
Topics305,882
Posts5,282,013
Members71,529
Page 3 of 3 1 2 3
Re: Any need for additive if always using TT fuel? [Re: wbwanzer] #5367350 03/04/20 05:15 PM
U
UG_Passat Offline
U
1 oz of Renewable Lubes Bio-Plus Fuel Injector Cleaner per tank
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Any need for additive if always using TT fuel? [Re: jimbrewer] #5368395 03/05/20 08:37 PM
M
Mad_Hatter Offline
M
Originally Posted by jimbrewer
Ford says categorically not to use fuel additives on my 3.7L. They do say fairly emphatically to use TT fuel (without actually using the words “top-tier”. I take that to mean that they didn’t take a bribe to make the recommendation.)
Probably the no fuel additive thing is to head off people putting who knows what in their tank instead of PEA.
In many cases the OTC fuel additives, like Techron, are just concentrated additives (PIB/PIBA/PEA) already found in TT fuel, although some addys contain addtl stuff like solvents to help clean out fuel lines/injectors/pumps... So Ford is being funny with it's language. Chevron private labels the cleaner for Hyundai,GM/Delco, Mopar and others, I'm surprised they haven't for Ford. But if you're religiously running TT fuel you shouldn't need any addtl additive every fill up.. more like once every few months if anything just to keep the build up to a minimum.
Re: Any need for additive if always using TT fuel? [Re: Mad_Hatter] #5368972 03/06/20 01:31 PM
Y
y_p_w Offline
Y
It has to be in a solvent just as a carrier for the detergents. Many of the detergents are solid.
Re: Any need for additive if always using TT fuel? [Re: y_p_w] #5369564 03/07/20 06:05 AM
M
Mad_Hatter Offline
M
Thanks for catching that..I guess what I'm saying (to clarify my prior post) is additional solvents besides the carrier. Some products have great solvency like a Berryman's B12 because they have a laundry list of solvents besides the carrier v. say, Lucas Fuel Treatment which is all heavy, paraffinic oil or Seafoam which i believe is a mix of pale oil and isopropanol. Both of these two treatments contain no addtl detergents like PEA/PIBA. So there can def' be a difference (in solvency) from one brand to the next.
Re: Any need for additive if always using TT fuel? [Re: Mad_Hatter] #5369568 03/07/20 06:14 AM
4WD Offline
The outboard motor companies rebadge Techron …
but my understanding it’s a stronger dose if anyone ever thinks they need that …
I just switched to Techron multipurpose marine additive for my boat
Figured they understood the balance of these chems
Re: Any need for additive if always using TT fuel? [Re: 4WD] #5370044 03/07/20 05:35 PM
M
Mad_Hatter Offline
M
It is. Both the Power sports and Marine have higher amount of pea by weight... but they're also spendier, dollars per oz.
Re: Any need for additive if always using TT fuel? [Re: Mad_Hatter] #5371969 03/09/20 09:32 PM
W
wdn Offline
W
That is incorrect. Lucas Fuel Treatment is not all heavy, paraffinic oil: it is polyisobutylene in a oil carrier.
Re: Any need for additive if always using TT fuel? [Re: wdn] #5373059 03/11/20 01:29 AM
M
Mad_Hatter Offline
M
Really?
I don't see PIB mentioned anywhere on their website nor in their SDS...Do you have a link to your discovery, so that I can verify?
Lucas UCL MSDS
Re: Any need for additive if always using TT fuel? [Re: Mad_Hatter] #5373279 03/11/20 09:49 AM
W
wdn Offline
W
What makes you think a product data safety sheet is a recipe or ingredient list? It isn’t. So in other words you are the one making claims about the absence of some ingredient of Lucas UCL based solely on a SDS that is not nor is it intended to be, a formula.
OK sure, really, here is a Fourier analysis infrared spectrometry of Lucas UCL done here, that reverse engineered the product:
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=284807&page=1
Page 3 of 3 1 2 3
