Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Ivan30, mikespine, Typerguy, showtyme1958, rickyradit
71529 Registered Users
36 registered members (Char Baby, Boomer, Amkeer, alarmguy, blufeb95, 87sammy, 4 invisible), 1,186 guests, and 34 spiders.
Topics305,882
Posts5,282,013
Members71,529
Page 3 of 3 1 2 3
Re: Mobil 55% more cleansing agent claim [Re: Mike L. V.] #5372850 03/10/20 07:38 PM
4WD Offline
What a bunch of know it alls that actually don’t
Re: Mobil 55% more cleansing agent claim [Re: Mike L. V.] #5372862 03/10/20 07:49 PM
PimTac Offline
Originally Posted by Mike L. V.
Originally Posted by PimTac
Every fuel company blows smoke up their customers rear end to make a profit. It's all marketing claims. Gasoline is gasoline IMO. No brand of gas has every provided more MPGs or drivability improvements for me. Buy whatever is cheapest and sleep easy.
You are correct, gasoline is gasoline... Comes from the same source. HOWEVER, it is the Additives that makes them different.
Correct painfx and if your owners manual says to use Top Tier fuel then that is what you should be filling up with.
Car manufactures only recommend Top Tier fuels in their Owner's Manuals because Big Oil has paid for the endorsement. Top Tier gasoline can cost between $.10-$.25 extra per gallon. Some companies dump even more additives into their Premium Grades like Shell V-Power and Mobil Synergy Supreme+ which in my opinion is just more profit. Most gasoline cars on the road were designed and tuned for regular grade so why not add those additional cleaning additives across their entire line up.. easy...PURE GREED.
Pure hogwash.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Mobil 55% more cleansing agent claim [Re: PimTac] #5372870 03/10/20 07:55 PM
4WD Offline
Yep … I have never used much less seen several of these
https://www.toptiergas.com/licensed-brands/
Re: Mobil 55% more cleansing agent claim [Re: wolf_06] #5372944 03/10/20 09:05 PM
caprice_2nv Offline
I stick to top tier Mobil (Esso here in Canada) to help prevent more carburetor issues in both my cars. The work truck gets it too because that's what our gas card is for.
I put e0 91 Shell v power in the summer car before it's parked for winter and in all the outdoor power equipment.
In the past I've gotten 3-5 years of using e10 all summer in my summer daily driver before the carb messed up. Only time will tell if switching to top tier e10 still causes the same issues.
With the price difference here, I could buy a brand new Summit racing carburetor for the Oldsmobile with 1 year of fuel savings. As much as I'd rather use e0 exclusively I can't afford it.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Mobil 55% more cleansing agent claim [Re: wolf_06] #5373221 03/11/20 08:31 AM
W
wdn Offline
W
All gasoline has detergent additives, Top Tier just has more of the same additive. To turn the minimum EPA gas into Top Tier requires adding just 34 ptb. That is per Keropur AP 205 additive’s documentation.
That is worst case, assuming like Top Tier likes base their claims on, that non Top Tier gas sold is the EPA bare minimum detergency and not one extra drop of additive.
To give Top Tier the benefit of the doubt, for any gas you can just add 34 ptb more of the same Keropur additive and turn it into Top Tier. That is 34 pounds per 40,000 gallons of gasoline, or one pound per 1,176 gallons. That is one ounce of detergent additive to upgrade 74 gallons of gasoline to Top Tier.
To compare that to Techron fuel system cleaner which contains 30% PEA then three 20-ounce bottles contains more than a pound of PEA, ignoring all the other, non-PEA detergents in Techron. Therefore 3.75 ounces of Techron by weight contains an ounce of PEA that seemingly is enough to turn 74 gallons into Top Tier. One ounce by weight then couldturn a 20 gallon tank of any gas into equivalent of Top Tier. That is assuming a pound of Keropur additive is as effective as a pound of pure PEA, which is debatable.
Page 3 of 3 1 2 3
