Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 04/01/20 02:41 PM
NEW Adam's Polishes - Hand Sanitizer
by SavagePatch - 04/01/20 02:40 PM
Home vehicle modification fails
by IMSA_Racing_Fan - 04/01/20 01:57 PM
Internet speeds in current climate.
by sloinker - 04/01/20 01:55 PM
concrete work while at home
by spasm3 - 04/01/20 01:19 PM
Oil change
by IvanPletex - 04/01/20 12:52 PM
New Battery --> Group 25 (stock), 24 or 34???
by gathermewool - 04/01/20 12:49 PM
KenoshaWizard, junipertoxic, mtnrider, Rickborn, TreyT42
71071 Registered Users
103 registered members (928, 53' Stude, Astro_Guy, 2002 Maxima SE, 2K2AcuraTL, apollo18, 10 invisible), 1,807 guests, and 19 spiders.
Topics303,443
Posts5,235,369
Members71,071
Leaky sels best additive?? #5372848 03/10/20 07:34 PM
J
jssaab Offline OP
J
Read through the reviews here but an still confused. What additives do a good job stopping leaks ( rear main seal and oil pump.) I have seen there are different additives that swell seals and others that hurt them any choices to make out therre?
It is a car belonging to a girl I am dating so if I can seal a few leaks I will be a god to her... I like that.
Car is a wreck but anything to help her get along till she graduates college would be great.
2013 Jaguar XF 3.0 AWD Supercharged, Tuned 460HP Castrol Edge 5w-30 90k
2006 Saab 9-3 Aero 160K tuned 360 HP Mobil1 European 5W-30
Re: Leaky sels best additive?? [Re: jssaab] #5372856 03/10/20 07:45 PM
I
Ihatetochangeoil Offline
I
ATP-205
https://www.amazon.com/ATP-AT-205-Re-Seal-Stops-Bottle/dp/B000NVW1LM
The stuff actually works. I've saved replacing two rack & pinion steering gears and a front main seal. It may take several days of actual driving, but, IMHO, if ATP-205 doesn't work, you've got problems too big to be solved by a bottle of anything.
Re: Leaky sels best additive?? [Re: jssaab] #5372857 03/10/20 07:46 PM
Chris142 Online Content
Online Content
Valvoline maxlife.
The Super-s high milage fixed the oil burning tahoe
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Leaky sels best additive?? [Re: jssaab] #5372939 03/10/20 09:01 PM
B
buck91 Offline
B
Never had one help in the least!
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Leaky sels best additive?? [Re: Ihatetochangeoil] #5373010 03/10/20 10:26 PM
F
FusilliJerry82 Offline
F
Originally Posted by Ihatetochangeoil
ATP-205
I used it in a Protege 1.6 with 270k and it significantly slowed the rear main seal leak. Curious as to whether it might help 3-4 slipping at WOT in ATF but its not enough of a problem for me to risk adverse effects.
Will likely try spraying it on some bushings and boots with a spray bottle to keep them pliabe like Scotty Kilmer suggests though I think he's a bit of a clickbaiting goofball.
Re: Leaky sels best additive?? [Re: jssaab] #5373054 03/11/20 01:17 AM
J
Jackson_Slugger Offline
J
I'd give Mobil 1 HM a try, the higher AN ester content seemed to shut down leaky seals on my father's Taurus...
Re: Leaky sels best additive?? [Re: jssaab] #5373090 03/11/20 03:21 AM
O
Olas Offline
O
You won't help the poor girl with $3.50 spent on snake oil - the only way to fix leaky seals is to replace them with new seals that don't leak.
The question has to be;
Is she worth the time & effort of fixing it correctly? If she's not then find one that is.
Cable ties should hold it
Re: Leaky sels best additive?? [Re: jssaab] #5373239 03/11/20 08:55 AM
Danh Offline
Liqui-Moly Oil Saver. Worked like a charm on my V-6 Duratec front seal leak. Not a cheap task to replace the seal and this product bought me a couple years leak-free until trade-in time.
If you use this product, use the full dose the first oil change and taper off to progressively smaller amounts.
Re: Leaky sels best additive?? [Re: Olas] #5379758 03/18/20 05:55 PM
J
jssaab Offline OP
J
Her car is not worth fixing, not going to pull the motor on a 2002 Pontiac GT with 175 K on it. It has cracked windshield dents and dings. actually just trying to keep her from dumping a qt of oil in each week
That said she's a 22 yo college hottie but they are a dime a dozen
Re: Leaky sels best additive?? [Re: Danh] #5379759 03/18/20 05:56 PM
J
jssaab Offline OP
J
Sounds like a winner....
