Going to be installing a puck mount for antenna.
I decided NOT to drop the headliner, as it is much work, and I need to put a 3" hole in it anyways.
The puck mount will not fit behind the liner, the mount is heavy duty and strong.
So how do I get a clean cut hole into the headliner?
I'm going to glue edging around it, but need a fairly clean hole.
I thought about using a hole saw in reverse to cut the liner.
