AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
Ghosty, zmann96, yetti96, weekendwally, Bugsbrewery
71601 Registered Users
100 registered members (53' Stude, 830Lee, 4WD, 2015_PSD, 77GrandPrix, 2010Civic, 9 invisible), 1,976 guests, and 56 spiders.
Topics306,104
Posts5,287,564
Members71,601
Page 1 of 3 1 2 3
Stuck oil filter #5372379 03/10/20 11:11 AM
P
pbm Online Content OP
OP Online Content
P
The 4967 (small) size filter on my 2008 Corolla is on very tight and I can't get it off with various types of filter wrenches. The problem is that I have mutilated the filter trying..the other part of the problem is I'm 1500 miles from home. If I pierce the filter and cut it with aviation snips...will the snips be strong enough to cut the base plate? I don't think I want to chance driving it with the filter so beat up (although it doesn't appear to be leaking...yet)
I should have left well enough alone...I shouldn't have tightened it so much last time...I should have put more oil on the gasket last time..etc..etc.. For those who don't know the filter location on the 1zzfe...it's recessed and the correct 14 flute cap wrench is mandatory ...and I unwittinly used the wrong wrench initially which is what started my problem.
Thoughts and suggestions?
'Journalism is Dead'
Re: Stuck oil filter [Re: pbm] #5372382 03/10/20 11:16 AM
Chris142 Offline
you need one of those 3 finger tools. Your not going to cut a baseplate with tin snips.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Stuck oil filter [Re: pbm] #5372384 03/10/20 11:18 AM
Astro14 Online Content
Online Content
Since you’re that far from home, I would take it to a Toyota dealer who’s undoubtedly seen this before and can get it off for you. Pay them for the change and be done with it. Bite the $$ bullet, it’ll save you more heartache in the long run.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Stuck oil filter [Re: Astro14] #5372386 03/10/20 11:21 AM
A
Alfred_B Offline
A
+1
At some point, you cut your losses
Re: Stuck oil filter [Re: pbm] #5372389 03/10/20 11:22 AM
B
Barkleymut Offline
B
agree with the 3 finger tool. I doubt there is an oil filter that you cannot remove using it. I got mine at Home Depot a few years ago and now I cannot live without it. Neighbor was about to take his car to the dealer to have them remove the filter because his wrench would not budge it and he asked me if I had any ideas. I let him borrow mine and 1 minute later he was done. He went and bought one the next day.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Stuck oil filter [Re: pbm] #5372390 03/10/20 11:22 AM
M
meep Offline
M
If you can get a cold chisel against the base you could coax it to rotate with a hammer. Pound a notch into it and then hit it to rotate.
Or the hail mary final move is to stab a screwdriver through it, but, you recognize the finality of that one (it's never not worked for me). But if you're nervous, Astro14 gives you a safe play.
2018 F150
2015 crv (wifey!)
Re: Stuck oil filter [Re: pbm] #5372392 03/10/20 11:22 AM
Mike L. V. Offline
Crush it with an adjustable oil filter pliers. Had this problem before with my 1ZZ. Come from the bottom and if needed wrap some sandpaper around the filter and give it a good twist. These worked well.
https://www.harborfreight.com/oil-filter-pliers-61477.html
Re: Stuck oil filter [Re: meep] #5372394 03/10/20 11:23 AM
Mike L. V. Offline
Done the screwdriver trick and that works well.
Re: Stuck oil filter [Re: pbm] #5372395 03/10/20 11:23 AM
B
Barkleymut Offline
B
btw, I bought the Husky brand at Home Depot for $10. Very well made and designed.
Re: Stuck oil filter [Re: pbm] #5372407 03/10/20 11:40 AM
A
andyd Offline
A
Meep, It is comforting in a way to know that I'm not the only hack out there. Trouble is the Camrys have a cartridge filter these days. and you need a special socket to R+R. Even the the Rat required a socket for the first filter change. With an oiled gasket, spin ons just require a hand tighten. grin2
Thick oil is better grin2
Re: Stuck oil filter [Re: Mike L. V.] #5372409 03/10/20 11:46 AM
P
OP Online Content
P
I bought those filter pliers at HF this morning....can't get it to budge but my lower radiator hose and Magnafine ATF filter are obstacles which I could remove if I were back home. I also tried the 3 finger wrench to no avail albeit it was a cheap one from Walmart....maybe the dealer is the best route....or maybe I could cut the filter with the snips and use those pliers to crush the base plate? I'm lucky to have the wife's car here to get around...I think the last time I paid for an OC was in 1974...
Re: Stuck oil filter [Re: pbm] #5372412 03/10/20 11:49 AM
T
tiger862 Offline
T
https://shop.advanceautoparts.com/p/lisle-import-car-oil-filter-wrench-63600/25981259-P
Can't stress enough how handy this tool is for oil change. Stuck filter no problem. It is my go to filter. Home Depot seems to have it cheaper but I would have to order it over here.
Tiger862
2018 Grand Caravan
Re: Stuck oil filter [Re: pbm] #5372413 03/10/20 11:50 AM
P
PowerSurge Offline
P
Probably a long shot but is there enough room to get a small chain wrench around the base plate?
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Stuck oil filter [Re: tiger862] #5372414 03/10/20 11:51 AM
P
PowerSurge Offline
P
Yes. I have one of those as a ‘just in case’.
Re: Stuck oil filter [Re: pbm] #5372417 03/10/20 11:53 AM
A
atikovi Offline
A
How far is a Jiffy Lube? Start it up and idle engine for 5 minutes while looking for leaks. A few drips are ok. If it looks good, drive it there, assuming your oil light works.
Page 1 of 3 1 2 3
