Who knows about external cell phone antennas. Currently using TMobile B12ac band or ~700 MHz. I have a Netgrear NightHawk MR1100 M1 wifi Internet router as the main device. It has two antenna inputs and two more hidden as I understand it.
I have a single antenna that is for Verizon that is around 850-900Mhz. When it is connected to one antenna input it actually degrades the signal. But I put a spliter on it so one antenna feeds two inputs. This gave me a -10 dbm increase in signal from ~-108 to -.98 per the router, 2 bar to 3.
I've heard that if you use more than one MIMO input antenna that they should be the same. So should I look for one more specific to the TMobile frequency and get a pair or just get another of what I got?
NIGHTHAWK® M1 Mobile Router (MR1100)
The antenna I have
4G LTE External Antenna&TS9 Adapter cable For Novatel Verizon Jetpack MiFi 6620L
Quote
11db Gain External Magnet Antenna: Model: 3A1-2158-F02SJ-110-300
700~2600MHz
GSM/GPRS/EDGE 850/900/1800/1900/2100
HSUPA/HSDPA/UMTS 2100MHz/900MHz
CDMA 1900 MHz
Gain: 11 dBi
VSWR: â¤2
Horizontal Beamwidth: 360°
Vertical Beamwidth: 42°
Max power: 50 W
Nominal Impedance: 50 Ω
Connector : FME female straight as default, SMA/SSMB/MCX/CRC9/BNC/TNC/and so on.,please give us notes if the connector is chosen !
Extended Cable :RG174 Cable
Cable length: 3M
Weight:0.180 KG
Polarization :Vertical
Radiation :Omni -directional
Mount Magnetic antenna base
This antenna can be used indoor and outdoor,and can be put on the Metal place.
External Antenna Adapter Cable:
Cable Type: RG174
Cable Length: 8 inch (20cm)
Connector: FME Male to TS9 Male straight
Compatible with Novatel Wireless Verizon Jetpack MiFi 6620L
Here is a map of the cel tower cells and coverage. I am along the far south east last line of dots by the river in the blue area.
The antenna I have
Quote
700~2600MHz
CDMA 1900 MHz
Gain: 11 dBi
VSWR: â¤2
Max power: 50 W
Cable length: 3M
Weight:0.180 KG
Cable Type: RG174
