Forums Migration
Please read this thread
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
07 Tahoe trans fluid change.
by Anthony - 07/07/20 06:06 AM
Ravenol 15W40 Marine
by Realfine69 - 07/07/20 05:10 AM
2020 VW 0W20??
by Realfine69 - 07/07/20 05:06 AM
Who makes the O'reillys trans filters ??
by GMguy84 - 07/07/20 05:00 AM
[Seattle Craigslist] Cheap Pennzoil 5w20
by SlavaB - 07/07/20 02:14 AM
Best Synthetic Oil For Cleaning
by BlueOvalFitter - 07/06/20 11:18 PM
Make your predictions for 20 years from now...
by sloinker - 07/06/20 10:47 PM
Getting rid of carbon in exhaust ports?
by Spetz - 07/06/20 10:15 PM
Rotella Gas Truck 0W-20 VOA
by HDoilDude - 07/06/20 09:57 PM
Two Mobil 1 M1-110A filters. Different sizes
by Dallasmale1970 - 07/06/20 09:46 PM
BITOG forums migrating to Xenforo soon
by wwillson - 07/06/20 09:41 PM
JDMorgan, sycboi, Chuck_Ellison, BakonBittz, ssoH
71870 Registered Users
100 registered members (4WD, ABN_CBT_ENGR, Anthony, 2003f7, AndyB, 2015_PSD, 10 invisible), 1,720 guests, and 33 spiders.
Topics307,542
Posts5,312,757
Members71,870
Dexron VI #5370710 03/08/20 02:36 PM
7
762fermeandyou Offline OP
7
Hi all,
Just did a drain and refill on an '11 Equinox with 118,000 on it. Fluid flowed out of transmission well, but was black and barely smelled like transmission fluid. My question is, does the Dex VI lose the red dye color in short order and turn black, or was this fluid just in need of a change out? May have been original for all I know. No shifting problems before or after change. 4.75 qts exchanged.
62 Mercury Meteor 5.0 10w30 VPB blend / FL1A
95 Jeep ZJ 4.0 5w30 Havoline Conv / Rislone ZDDP / XG8A
15 Silverado 5.3 0w20 QSUD / PF63E
17 Explorer 3.5 N/A 5w20 Napa syn / Napa Proformer
Re: Dextron VI [Re: 762fermeandyou] #5370720 03/08/20 02:54 PM
c502cid Offline
I've done two drain and refills on my 2015 Trax, first at 60,000 second at 66,000, both times the Dex VI was black. Will keep doing it until it turns red again. Trans shifts fine.
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
77 E250 Quadravan 460/C6/NP205 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
Re: Dextron VI [Re: 762fermeandyou] #5370736 03/08/20 03:12 PM
SteveG4 Offline
Accomplished that Dex VI task on my 2013 Nox at 85K miles. Will do it again at 150K miles.
Somewhere between Alaska and Wisconsin...
2006 4WD Silverado LT Crew Cab & 2013 AWD Equinox
Re: Dextron VI [Re: 762fermeandyou] #5370758 03/08/20 03:31 PM
ls1mike Offline
It was just dirty. It will stay red if you keep it clean. Was that your first service?
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Dextron VI [Re: 762fermeandyou] #5370759 03/08/20 03:31 PM
JohnnyJohnson Offline
Soon as the weather get a little better the Duramax is going to get a spill and fill and external filter change. Currently just over 77K miles. It will be the second first was done after 30K.
2004 Corolla 140638
Out: Pennzoil Platinum HM 5W-20 ST 4386
In: Valvoline Synpower Full Synthetic 5W-30 Purolator PureONE
2006 Duramax 77117
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Dextron VI [Re: ls1mike] #5370789 03/08/20 04:24 PM
7
7
I would bet it was the first service, the aluminum around the drain plug had no dark spot from a previous drain, i think i will do it again next weekend.
Re: Dextron VI [Re: 762fermeandyou] #5370821 03/08/20 05:17 PM
4WD Online Confused
Online Confused
Not sure what’s in your owners manual … but our Cruze was 40k and we did that. ATF was coal black.
Ran the next (gallon) just 10k and still somewhat dirty. Just started doing it yearly … 10 minute extra and $20 during an oil change. Bumping up on 129k and shifts great (LG red in latest MaxLife change).
Annual change keeping it nice and red.
Re: Dextron VI [Re: 4WD] #5370830 03/08/20 05:28 PM
7
7
No dipstick with 4 cyl. only way to see color is with side plug or drain. Is MaxLife any better than Dex VI?
Re: Dextron VI [Re: 762fermeandyou] #5370845 03/08/20 05:40 PM
4WD Online Confused
Online Confused
MaxLife is a great ATF … but I’d never say it’s better than Dex VI …
There used to be a price spread but Dexron has come down so I’m using that in two other GM’s and Castrol MV in the Fusion Hybrid (it actually carries both Mercon LV and Dexron VI) …
Re: Dextron VI [Re: 762fermeandyou] #5370861 03/08/20 05:59 PM
E
eljefino Offline
E
Brown is a good time to get it. Black, you over-shot. Surprised it happened in such a short time interval.
Re: Dextron VI [Re: 762fermeandyou] #5370885 03/08/20 06:42 PM
blupupher Offline
When I did a pan drop on my mom's '07 Saturn Vue that uses Dex VI it was still reddish/brown with 140,000 miles on it.
'18 Santa Fe: PP 10w-30/OEM
'18 Soul: Delo 400 10w-30/ST
'12 xB: M1 EP 0w-20/CQ Blue
'10 Santa Fe: Pento HP 5W-30/TG
'04 F150: Delo 400 10w-30/ST
'02 F150: PP 0w-20/M1
'94 GL1500: Honda 10w-40/OEM
Re: Dextron VI [Re: 762fermeandyou] #5371009 03/08/20 08:23 PM
H
HyundaiAbuser Offline
H
Dex VI is a good stable atf, if your trans is cooking it to be black you should change it out earlier. I would probably start doing more frequent changes on that one.
03 Hyundai Tiburon:
PP High Mileage 5w30
Redline MT85
94 Mazda B4000 (RIP)
Supertech 10w40 High Mileage
Valvoline Maxlife
Re: Dextron VI [Re: 762fermeandyou] #5371045 03/08/20 08:50 PM
J
Jetsfan421 Offline
J
Sounds like a candidate for some lg red. My dad's Acadia has factory dex vi and 1oz per qt of lubegard red and the fluid is pretty pink/red. Thats with 141k miles. Shifted like butter before and after the treatment.
Re: Dextron VI [Re: 762fermeandyou] #5371073 03/08/20 09:15 PM
B
benjy Offline
B
drain + fills only get 1/3 to 1/2 of the fluid, then you mix new with the older dirty fluid so start early + change again as need, DIY is cheap trannys are $$$$$
Re: Dextron VI [Re: 762fermeandyou] #5371135 03/08/20 10:23 PM
N
Nyquist Offline
N
I had a 2011 Equinox and can relate. Based on the bulletin the GM dealer gave me at the time (around 2013), there are some coatings on parts in the transmission that will turn the fluid dark. However, the chemical properties (e.g. protection, lubrication, etc) are not affected by the color. However, those 6-speed transmissions do get warm and are tough on fluid.
You did the right thing by changing it, but I would do a couple more drain and fills over the next 5,000-10,000 miles to gradually cycle the old fluid out. I've had great luck with that approach on 6-speed GM transmissions. My Traverse has about 75,000 miles on it, and it is on its 3rd "spill and fill". It shifts like a brand new car.
Edited to add:
Here is a link to the fluid I started using: https://cglapps.chevron.com/sdspds/PDSDetailPage.aspx?docDataId=478991&docFormat=PDF
2015 Chevy Traverse 3.6L (LLT) Mobil 1 5w30 w/ Fram Ultra
2018 Chevy Cruze 1.4L (LE2) Mobil 1 5w30 w/ ACDelco
