Prolong
by IMSA_Racing_Fan - 04/04/20 01:34 AM
With most folks cooped up at home
by double vanos - 04/04/20 12:58 AM
'18 GMC Canyon Denali 7k Havoline Pro DS 5w-30
by montero1 - 04/04/20 12:52 AM
KTM 1190 Adventure oil viscosity?
by vfrkent - 04/03/20 11:42 PM
2011 Kia 2.7L Theta Hav. Pro DS
by twouvakind - 04/03/20 10:40 PM
Replacing Rusted Fuel Lines
by 92saturnsl2 - 04/03/20 10:35 PM
(3) 5-quart + Fixd ODB-II reader for $40.50+tax
by wkcars - 04/03/20 09:57 PM
Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
34 registered members (Blkstanger, blufeb95, AndyB, bernau, avi1777, 3 invisible), 1,116 guests, and 18 spiders.
Topics303,558
Posts5,237,355
Members71,086
Marine Grease for steering stem bearings? #5369751 03/07/20 10:42 AM
Degreaser Offline OP
I have a 2005 Kawasaki Vulcan 800 31,000 miles, and wanting to drop the steering stem to clean plus grease the top & bottom steering stem needle bearings, no record of this ever being down since factory new. Thinking of using a spray can of Gunk auto engine degreaser on the stem bearings for cleaning, or can I use brake cleaner.
I bought a 8 oz tube of lithium based NLGI 2 marine grease called Mercury 2-4-C at a shop that sells boat motors. The tube says this grease is good for boat linkages and for boat trailer wheel bearings and contains PTFE for added friction reduction and reduced wear, won't break down in the presence of water, and prevents rust and corrosion. If this grease is good for my steering bearings then I might also use it on most everything else on my bike.
is this grease ok to use on my motorcycle steering needle bearings?
Canada
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5369783 03/07/20 11:17 AM
I
Imp4 Offline
I
First figure out what's already in there.
Then, pick something that's compatible.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5369812 03/07/20 11:53 AM
I think this marine grease is silver because the web site called it Quick Silver, the grease is Lithium based NLGI 2
Canada
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5369824 03/07/20 12:03 PM
J
jeff78 Offline
J
Quicksilver is just a brand name used by Mercury Marine. I doubt there's any silver in that grease.
https://www.quicksilver-products.com/about-page/
Anyway, if that were my bike (second/third/fourthhand with unknown maintenance history), I'd have spare bearings and bottom seal handy just in case the ones on the bike are a mess. Or just replace em while you're in there anyway and you'll be good for 60K+ miles...
Brake cleaner works great for removing grease. On the metal of frames and steering stems, no problem, but be careful around plastics.
I can't think of a reason why that grease wouldn't be suitable for steering stem bearings.
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5369873 03/07/20 01:25 PM
B
BigCahuna Offline
B
When you think about wheel bearings, on a car or truck, or trailer, they do alot of spinning and in all types weather and temps for years. Your neck bearings only move a few rotations in 100 miles of riding. So if marine grease can hold up to highway speeds, then being dunked into cold water. There's no way you should have problems using it in your application, even riding in rain shouldn't effect the bearings. I agree you should remove whatever grease is in there before using any new grease.,,
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5369912 03/07/20 02:09 PM
I did a search on the Marine grease 8 oz tube I bought (it says cannot be used on needle bearings),
I removed the stem locknuts and dropped the stem, both top and bottom needle bearings look pretty good and rubber seals look good also, both top and bottom races are smooth with no marks or dents, the old grease on the bearings look factory stock, clear in colour, I have a very old tub of Motomaster wheel bearing grease but not sure I'll use it because I think it's thin and soluble, and the Marine grease says believe cannot be used on needle bearings, so I'm on the hunt for new grease, what about the Bel-Ray Waterproof Grease? I can get that from FortNine web site, they're out of Montreal, that's where i got my new stem locknut wrench from, came yesterday.
https://www.amazon.ca/MERCURY-2-4-C-Marine-Lubericant-Teflon/dp/B001HWPZ6Y
A high quality multi-purpose lubricant made to withstand extreme friction while providing added water resistance. Cannot be used on needle bearings or other internal engine parts. 8oz tube Part # :92-802859Q
Canada
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5369917 03/07/20 02:16 PM
how do i get the old grease out of top and bottom bearings? not sure i should use brake cleaner because of the rubber seals
Canada
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5369967 03/07/20 03:20 PM
Cujet Offline
That grease will work just fine.
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5369981 03/07/20 03:40 PM
so what do you make of that web page saying that Mercury Marine Grease 2-4-C with PTFE (I think that means with Teflon) that it cannot be used on needle bearings? marketing misinformation?
Canada
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5370033 03/07/20 05:11 PM
I think that I found what grease I want for my Kawasaki stem bearings, it's Lucas X-TRA Heavy Duty Grease , a GC-LB Polyurea based grease
Canada
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5370268 03/07/20 10:54 PM
i googled the question and google gives this answer:
Mercury 2‑4‑C is a high‑quality, multi‑purpose grease designed to withstand extreme friction in marine and non‑marine applications. Do not use on internal engine parts such as needle bearings.
Not to use on needle bearings? So I guess I can't use this lithium based marine grease on my stem head bearings.
So now I'm back to square 1. What kind of grease are you bikers using to grease your steering stem bearings?
Canada
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5370296 03/07/20 11:37 PM
Z
ZeeOSix Offline
Z
It says "internal engine parts", kind of a nebulous statement, so who knows for sure.
Why not just use some good wheel bearing grease?
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5370349 03/08/20 01:36 AM
dwendt44 Offline
Quote
the key word it "internal engine parts'.
Needle bearings were/are used in/on wrist pins and rod mains in
many 2 cycle engines for outboards.
Think 'high load/high speed'.
For steering bearings, either kind, it should be fine.
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5370425 03/08/20 06:42 AM
I'm thinking of getting this for my steering bearings, they have it at Canadian Tire
Shell Rotella HD Grease, 14 oz tube, red lithium complex, premium multi purpose grease with excellent high temperature, anti-oxidation, anti-wear and anti-wear corrosion properties. Suitable for bearings operating at high temperature and under load such as disk brake equipped wheel bearings.
Canada
Re: Marine Grease for steering stem bearings? [Re: Degreaser] #5370543 03/08/20 09:30 AM
J
jeff78 Offline
J
Holy first world problems Batman!
They're just steering stem bearings. And technically, not needle bearings but tapered roller bearings. Any one of the 4 (and counting) greases you mentioned will work fine for this application. Although people here seem to take a dim view of Lucas products....
