Originally Posted by 13Track38
Seafoam in the oil and fuel since the pistons look caked with deposits when I removed the plugs.
I would stop adding seafoam to the fuel. Seafoam is a light oil with alcohol and some naptha. Burning oil in the fuel could contribute to the piston deposits.
If i used an additive for carbon deposits, it would be a pea product like techron. Berryman b-12 is good for cleaning the carb. Make sure the sparkplug is gapped correctly and reinstall it.
If its using oil, a high mileage 10w30 , or a hedo 15w40 should help. If you are running a straight 30 it should NOT be a ND( non detergent ) sae 30.
