2017 Corvette / 14.4k / ACDelco MTF
by dparm - 04/01/20 08:10 PM
Replacing Rusty Brake Lines
by 92saturnsl2 - 04/01/20 08:08 PM
2017 Corvette / 14.4k / ACDelco 75w90 gear oil
by dparm - 04/01/20 07:59 PM
Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
113 registered members (5AcresAndAFool, 92saturnsl2, Alfred_B, ABomb369, 53' Stude, 16 invisible), 1,732 guests, and 24 spiders.
Topics303,453
Posts5,235,482
Members71,072
Speedometer cable: How to lubricate? #5368812 03/06/20 10:22 AM
L
LucasDK Offline OP
L
Hi,
What product is needed to properly lubricate the speedometer cable/wire in such a way, that it will last at least 100000 miles (daily driver summer and winter)?
Does anyone have some hands on real world experience - not just from show cars that run a few hundred miles a year during summer conditions only?
Lucas
Toyota Hiace 2,4D (2L engine)
Toyota Corolla AE92, (4A-FE engine)
Ford Model A (3,4 liter engine)
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5368822 03/06/20 10:30 AM
E
Elevguy Offline
E
Pull cable out from top and lube with light grease
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5368831 03/06/20 10:39 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
Ditto. I was told the same thing by the guys at Bob's Speedometer Shop.
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5368852 03/06/20 10:54 AM
N
nwjones18 Offline
N
I pulled mine out on my 88 f-150 and lubed it with a wax chain lube with good results.
2016 Ram 1500 5.7 Hemi 30k QSUD 5w-20 Mopar filter
2008 Honda CRV 125K QSUD 5w-20 Fram ultra
2007 Mazda 3 2.3 130k 5w-30 syn-blend Denso filter
1988 F-150. 4.9 I6 251k. 10w-40 QSHM Motorcraft FL1A
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5368891 03/06/20 11:31 AM
W
WyrTwister Offline
W
Wyr
God bless
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5368978 03/06/20 01:47 PM
B
bullwinkle Online Confused
Online Confused
B
I used white lithium on mine back in the day, but I don’t think any of the vehicles went 100K after doing it.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5368996 03/06/20 02:07 PM
Carbuff Offline
While I've heard many suppliers recommend Lithium grease on cables, I always used a liquid graphite lubricant, like Lock-Ease. The liquid carrier evaporates, and the graphite alone does not attract dirt that could make the cable-core seize or bind.
I always dribbled the graphite lube onto the cable core while pushing the core into the sheath.
Atwell Haines
NJ
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5369091 03/06/20 03:52 PM
M
mk378 Offline
M
Sharp bends will greatly shorten the life of the cable. Route it with as wide a radius as it can.
Back in the days of speedometer cables, no moving part of the car was expected to last 100,000 miles.
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5369121 03/06/20 04:30 PM
L
Lubener Offline
L
Pull it out, clean with alcohol and lubricate with graphite and reinstall.
The "thinking" man's friend.
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5369286 03/06/20 07:37 PM
P
PowerSurge Offline
P
Graphite.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
Re: Speedometer cable: How to lubricate? [Re: PowerSurge] #5383631 03/23/20 11:04 AM
R
Randy_R Offline
R
Originally Posted by PowerSurge
Graphite.
+1
2018 Mazda CX-5 6600 miles Zepro advanced moly 0W-20 Mazda filter
08 Saturn VUE AWD 3.5 V6 65,000 miles Schaeffer 9000 5W30 Wix 51522XP
65 Pontiac Tempest 355 Chevy Schaeffer Racing 10W30 K&N
Re: Speedometer cable: How to lubricate? [Re: LucasDK] #5383819 03/23/20 03:13 PM
DBMaster Offline
If you pull the inner cable just about any type of lube will help, but by the time you are having issues the wear that the cable has produced on the inside of the plastic casing allows play in the cable. All you are doing is buying some time, but the best approach is to replace the cable, assuming it's not an onerous job to do so.
