Here are photos of my set up as posted in the other thread on this subject
https://www.bobistheoilguy.com/foru...-cord-cutting-costs-going-up#Post5359130
It may be similar to the RCA antenna. It could be made by Winegard which is likely who Denny uses for his stacker. His designs look good and sounds like he knows his stuffThis is what I use. It is the bomb. It's a hybrid yagi/log-periodic. Excellent service, great place to do business with.
http://dennysantennaservice.com/ez_hd_tv_Antenna.html
I don’t know if Denny’s Stacker is optimized for that band specifically, but VHF High 7-13 is covered. I bet VHF low would work way better on the stacker than those smaller uhf only antennas. You can’t defy physics.No VHF low signals were tested. The lowest station in the test was RF channel 7.
It is similar, but it is not the same thing as the RCA ones. Especially the ones made recently. I have no complaints at all on his antennas.It may be similar to the RCA antenna. It could be made by Winegard which is likely who Denny uses for his stacker. His designs look good and sounds like he knows his stuff
