I had some time on my hands today and decided to load up the new gun with Mystic JT6 High Temperature and lube the snowblower. My first impression is that the Mystic looks less viscous than the Lucas RNT. Obviously looks are often misleading. Once things warm up a bit I will store both guns side by side to compare the oil separation.
So now that I have two guns, what other type of grease [other than NGLI #2 High Temp] might be useful for the typical OPE fleet? Actually I should extend that to un-powered stuff like the wheelbarrow, lawn spreaders, etc. ???
I use Mystic JT-6 green tube in everything including my Tie Down boat trailer bearings and zero turn bearings. Never any separation. My second pick would be green grease but it was hard to find.
I tried Lucas red n tacky and Walmart marine grease. I pulled them from the gun and tossed in garbage.
I only use 2-3 tubes a year so I am not putting up with the mess.
