Local dealership charges $15 for an oil change.....
by Harrington - 04/04/20 02:57 PM
Did harvest king change suppliers?
by Micahmcmeen - 04/04/20 02:30 PM
Switching back from High mileage to regular.
by Micahmcmeen - 04/04/20 02:28 PM
Changed the spark plugs on Subaru BRZ with pics
by Ded Mazai - 04/04/20 01:08 PM
Two filter sizes for Skyactiv 2.5?
by buster - 04/04/20 12:31 PM
Valvoline AFS Euro 0W-40 $25-4-10 Qts.
by Jackson_Slugger - 04/04/20 11:36 AM
pay cut at work
by marine65 - 04/04/20 11:17 AM
Asking For Advice- Lubricate Under Hot Water
by PGB1 - 04/04/20 11:05 AM
Castrol Magnatec 0W-20 2-4-$30
by Jackson_Slugger - 04/04/20 10:58 AM
Purolator One synthetic vs paper
by Duffyjr - 04/04/20 10:57 AM
RockAuto Discount Code
by RoadDukie - 04/04/20 10:53 AM
Grease fittings on drop links - is this a defect?
by wolfestone - 04/04/20 10:51 AM
How clean vinyl steering wheel?
by WobblyElvis - 04/04/20 10:49 AM
90s European Toyotas Coolant
by EWPE - 04/04/20 10:42 AM
Locker plants are swamped
by P10crew - 04/04/20 10:39 AM
New Jeep Rear Cargo Tray
by 2015_PSD - 04/04/20 10:30 AM
I'm getting fat.
by BeerCan - 04/04/20 10:26 AM
Penne alla Boscaiola
by vavavroom - 04/04/20 10:05 AM
Fuel stabilizers for e10 gas - long storage
by caprice_2nv - 04/04/20 09:59 AM
357sig, Garyv, PGB1, YoDaveO, Johnya25
71094 Registered Users
110 registered members (762fermeandyou, 01rangerxl, 928, 4WD, 41Pack, 2015_PSD, 10 invisible), 2,769 guests, and 17 spiders.
Topics303,589
Posts5,237,879
Members71,094
Valvoline Super Diesel 15W-40 in a motorcycle #5367545 03/04/20 08:47 PM
J
JamesK Offline OP
J
Hi All,
Hoping for some help in determining whether or not this particular diesel oil contains any friction modifiers.
I’ve run various car oils in my bikes for decades without issues. The only thing I always confirm is that the intended oil does Not contain friction modifiers which would impact a typical wet clutch.
I am trying to determine whether this particular Valvoline oil diesel oil contains friction modifiers. I have attached pictures of the labels so hoping someone smarter than I can help.
Thanks in advance for your help.
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5367590 03/04/20 09:32 PM
J
Jimiii Offline
J
Use it. The myth that oils cause clutch slippage is nonsense. Any oil that does not carry the "energy conseving" banner is ok. Ail diesel oils are fine. I put 109,000 miles on my last bike, Honda Goldwing 1800, using Mobil 1 5W40 synthetic turbo diesel. Many miles pulling a trailer. Original clutch, no slippage.
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5367650 03/04/20 10:48 PM
T
tundraotto Offline
T
diesel oils should work great....
PI sheet available if you search for:
Super_Diesel_15W-40-PI_Sheet.pdf
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5367676 03/04/20 11:43 PM
R
Rand Offline
R
If you are looking for a spec JASO MA or MA2 is good but not JASO MA1
Rotella T4 15w40 has JASO MA/MA2
Rotella T5 15w40 does not.
https://rotella.shell.com/en_us/pro...d0fc768d05faab7059e52f0938/t4-15w-40.pdf
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5368271 03/05/20 05:27 PM
P
Papa Bear Offline
P
Welcome !!
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5371293 03/09/20 07:04 AM
J
JamesK Offline OP
J
Thanks for the great replies guys.
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5374155 03/12/20 05:58 AM
A
alarmguy Offline
A
That is one heck of a good bike oil! Cant buy oil with those ratings anymore in the USA except for a select few. I have a similar rated oil in a 15/50 From Mystic JT8
No way would it hurt your clutch.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5375523 03/13/20 02:12 PM
BusyLittleShop Offline
Friction modifiers additives are only a small percent of the total oil product and help
the base oil do things that it otherwise could not... Additives fall into several basic
categories but Moly, Phosphors and Zinc are the most often used friction modifiers... what
ever small percent of FM employed they will not defeat a wet clutch in good working order...
The holy trinity of science is 1)Reason 2)Observation 3)Experience...
employing those tools we observe that the primary cause clutch slip
are high mileage... mileage is the constant among all of the clutches
that begin to slip... oil choice whether JASO approved or not is not a
constant... High mileage is the constant where all clutches begin to
loose grip due to normal glazing and contaminates that build up over use...
[Linked Image from vfrdiscussion.com]
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: BusyLittleShop] #5375918 03/13/20 11:21 PM
B
Bonz Offline
B
BLS, you cut and paste into every thread you join these days? Seriously, you've put the same thing in at least five or six threads now. You've had some legit things to say when you put something original out there and not reuse the same stuff over and over from multiple sources or post oil analysis comparisons to oils that don't exist anymore. Do you see my point, respectfully?
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5376456 03/14/20 08:31 PM
I see your point Bonz but respectfully my post are intended to inform the newbies... ignore it if you seen it before...
Larry L
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: BusyLittleShop] #5376773 03/15/20 09:14 AM
B
Bonz Offline
B
I can understand that, I just haven't seen that much duplicate in this many threads as I'm seeing here on any forum or this forum for that matter.
Carry on, enjoy your day.
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: JamesK] #5377128 03/15/20 04:19 PM
Thank you Bonz... I'll hold your thought...
Larry L
Re: Valvoline Super Diesel 15W-40 in a motorcycle [Re: BusyLittleShop] #5378785 03/17/20 03:38 PM
B
Bonz Offline
B
cheers
