This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Refrigerator runs in cooling mode for 2+ hours.
by mrsilv04 - 03/30/20 09:24 AM
Non Detergent Oil
by 10ecfarmer - 03/30/20 08:06 AM
Joe Diffie on vinyl
by skyactiv - 03/30/20 07:52 AM
cooling system vacuum refill kit
by Donald - 03/30/20 07:35 AM
What's the proper oil for a push mower
by jayjr1105 - 03/30/20 07:31 AM
Honda DW-1 OLD Bottles Question.
by David1 - 03/30/20 06:25 AM
Winter 'shoes' for office goers
by MoneyJohn - 03/30/20 05:54 AM
2004 FZ6 Delo 400
by thestockie1 - 03/30/20 04:34 AM
Turn signals all blinking fast
by JHZR2 - 03/30/20 12:14 AM
rider9195, kingsville911, B34R, ChrisSnowden, DIY4quality
71055 Registered Users
109 registered members (53' Stude, Audios, 007, 2015_PSD, 440Magnum, 25ring, 14 invisible), 2,055 guests, and 17 spiders.
Topics303,358
Posts5,234,722
Members71,055
Page 1 of 4 1 2 3 4
Air Compressor Selection #5367283 03/04/20 04:28 PM
The Critic Offline OP
Objectives:
- As quiet as possible
- Budget is around $500
- MUST run on 110V. I do have a 20A circuit available
- Low use, probably several times a month. Impact wrench, cooling system vacuum filler, inflating tires and occasional air hammer use (1-2x/yr) for loosening axles from the intermediate bearing.
These are the two I am considering:
https://www.californiaairtools.com/...-grade/2-0-hp-air-compressors/cat-20020/
https://www.lowes.com/pd/Kobalt-KOB...XwwJEAQYASABEgKn7PD_BwE&gclsrc=aw.ds
Thanks.
2011 Toyota Prius 1.8L - 206K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 144K - Valvoline Premium Blue Restore 10W-30
Re: Air Compressor Selection [Re: The Critic] #5367294 03/04/20 04:36 PM
K
kschachn Online Content
Online Content
K
Originally Posted by The Critic
Objectives:
- Low use, probably several times a month. Impact wrench, inflating tires and occasional air hammer (1-2x/yr) for loosening axles from intermediate bearing.
https://www.californiaairtools.com/.../2-0-hp-air-compressors/cat-20020-22060/
Thanks.
Both of those are 230V, correct? The second one says it can be operated at 115V but the amperage would be double that at 230V.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Air Compressor Selection [Re: kschachn] #5367298 03/04/20 04:37 PM
Objectives:
Thanks.
Both should run on 110V. I just corrected the link for the first one.
Re: Air Compressor Selection [Re: The Critic] #5367300 03/04/20 04:38 PM
skyactiv Online Content
Online Content
I'd definitely get the California Air Tools compressor.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Air Compressor Selection [Re: The Critic] #5367315 03/04/20 04:47 PM
R
ragtoplvr Offline
R
Reciprocating air compressor, they all make noise. Direct drive make a higher pitch noise than belt drive.
To get quiet you have to put one in its own sound proof room
There is a type of compressor rotary screw or scroll that make much less noise and cost more $$$$
You do not get to combine inexpensive and quiet.
Re: Air Compressor Selection [Re: The Critic] #5367318 03/04/20 04:49 PM
K
Online Content
K
On a 20A branch circuit?
1994 BMW 530i, 252K
Re: Air Compressor Selection [Re: kschachn] #5367323 03/04/20 04:51 PM
The 20A circuit I have in mind is for the furnace only; I can unplug the furnace when the air compressor is in-use.
Re: Air Compressor Selection [Re: The Critic] #5367330 03/04/20 05:00 PM
T
Traction Offline
T
The biggest tank you can get, and the highest pressure, like 150psi minimum. You can always daisy chain another tank for extra capacity, which also helps cool the air, which helps get the water out of the air. And ALWAYS drain the tank before you fire it up.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Air Compressor Selection [Re: The Critic] #5367336 03/04/20 05:02 PM
Donald Offline
Not sure you will get a great compressor that runs on 120 V 20 amps.
2015 Ford F-250 w/Powerstroke
Re: Air Compressor Selection [Re: Donald] #5367339 03/04/20 05:04 PM
Yeah, I don't think any of these options are truly favorable.
Re: Air Compressor Selection [Re: The Critic] #5367341 03/04/20 05:05 PM
K
Kawiguy454 Offline
K
HF has an ultra quiet model that fills your bill at a very affordable price. This is the biggun ...two smaller quieter versions can be had.
https://www.harborfreight.com/4-gal...-carry-jobsite-air-compressor-56339.html
Re: Air Compressor Selection [Re: The Critic] #5367366 03/04/20 05:36 PM
E
Eddie Online Sleepy
Online Sleepy
E
I have always favored a belt driven compressor for quietness and longevity. For impact wrench or air tool use get a 20 gallon or bigger tank. Ed
2014 CX5 Touring 2.5L :-)
Re: Air Compressor Selection [Re: The Critic] #5367382 03/04/20 05:55 PM
H
hatt Offline
H
I've had the previous version of the Kobalt in the OP for 12-13 years. It's perfectly fine for what you're doing. The newer version should be even better.
2013 F150 5.0, Delo 400 XSP 5W-40, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Air Compressor Selection [Re: The Critic] #5367429 03/04/20 06:44 PM
B
BBDartCA Offline
B
Hopefully these homeowner scroll crompressors come down in price. They are very quiet.
https://www.eastwood.com/eastwood-elite-qst-30-60-scroll-air-compressor.html
Former lube industry insider...now vehicle OEM engineering insider.
Re: Air Compressor Selection [Re: The Critic] #5367495 03/04/20 07:51 PM
R
Rand Offline
R
throw in my 2 cents.. this one is the real deal.
https://www.harborfreight.com/29-gallon-2-hp-150-psi-cast-iron-vertical-air-compressor-61489.html
belt drive and 150psi. it vastly increases your usable air([email protected] use pressures) in the 29gal tank. vs a 125psi
Page 1 of 4 1 2 3 4
