So, I kinda fudged up...
California
I'm in the process of reviving a Kohler Command 11 engine - cleaning up the carb and replacing the fuel pump due to California gas. In the process of tearing down the carb, I had to somehow get a welch plug removed. I used a screw and a hammer but that just deformed the plug. I then took a small 1.5mm flatblade screwdriver bit as a drift and managed to get the plug out.
The passages weren't damaged thankfully. But, the edge where the welch plug seats against is damaged, I did gouge the aluminum. It's not in a critical area but it could interfere with the carb working via an air or vacuum leak.
I was planning on using nail polish or a smear of epoxy to seal the plug after I drive the new one in. Will that work or just buy a new Chineseium carb?
I'd get a Chineseium carb. In machines that I pulled out of the garbage, fixed and sold or used, I had great luck with them. They saved me a lot of time installing them, vs. a rebuild, when a carb was in need of a rebuild vs. a good cleaning.
Metallic plug that seals the end of a drilled passageway in a carb body.
Like a miniature version of a freeze plug in an engine block.
If you have a tube of RTV gasket maker laying around you can smear it over the plug and wipe it off, just leaving a bit to fill the edges. Since its not a hot surface or likely to come into constant contact with gas any color will work. If you dont have that just try bathroom silicon caulk.
I do have some RTV and Shoe Goo - I'll use the RTV first. That way I don't need to buy a 1-time use epoxy syringe and make a mess.
Just use Permatex Ultra Black.
Don't RTV or shoe goo anything in the carb, it likely won't last. You likely will get a new Welch plug with a carb kit. Very last resort would be JB Weld.
I meant after I drive in a new welch plug - a smear of RTV or Shoe Goo on the outside of the welch plug. Not on the inner part where the air passages are.
In the past I broke part of the stand that holds the locating pin on the float in the carb. Before I bought a new carb I used JB weld and repaired it. It worked for a couple more years then I sold it. I would tap the welch plug back in and seal it with JB weld. The repair I did in the bowl was located in a place where it was submerged in fuel.
This is interesting. I have an older B and S that may need a new carb. I looked into the Chinese carbs on eBay and right where the choke should be, there's a plug.
I wouldn't even have taken the time to mess with the original. Store it somewhere safe and mail order a new one.
