Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
80 registered members (390pi, 4WD, 2015_PSD, 14Accent, 86cutlass307, 4 invisible), 2,282 guests, and 40 spiders.
Topics306,057
Posts5,286,607
Members71,593
4 stroke snowmobile oil #5367188 03/04/20 02:41 PM
F
FastLane Offline OP
F
What are you guys running in your 4 stroke snowmobiles? My Yamaha manual says 0W30. Lots of guys are running 0W40. What brand are you using?
2010 Silverado 4.8 4x4 Mobil 1 5W30 Fram XG10060
2002 Mustang GT 4.6 Mobil 1 5W30 Fram XG2
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Lund SV16
2007 Yamaha Nytro
Re: 4 stroke snowmobile oil [Re: FastLane] #5367452 03/04/20 07:14 PM
U
userfriendly Offline
U
A motorcycle engine in a snowmobile. What does Yamaha know? 0w40 Delvac. Back in the day I used 0w40 Esso XD3 in everything.
Re: 4 stroke snowmobile oil [Re: FastLane] #5367496 03/04/20 07:51 PM
dave123 Offline
Amsoil AFF 0w40 4stroke Oil
Re: 4 stroke snowmobile oil [Re: FastLane] #5368899 03/06/20 11:43 AM
M
Mr_Joe Offline
M
I use Mobile 1 in my Yamaha Vector. The book calls for 0-40, wouldn’t have a problem with 0-30 if it’s all I could find. I’m due an oil change this Spring
Re: 4 stroke snowmobile oil [Re: FastLane] #5369598 03/07/20 07:47 AM
F
FastLane Offline OP
F
Seems like all the new4 strokes call for 0W40. I sit on the fence on what to run. I have a jug of Pennzoil 0W30 I was going to dump in.
2007 Yamaha Nytro
Re: 4 stroke snowmobile oil [Re: FastLane] #5370315 03/08/20 12:11 AM
Brian553 Offline
What do you think the coldest temperature you'll crank it would be?
I'd vote for
Delvac 1 ESP 5w-40
Rotella T6 5W-40
Mobil 1 FS 0w-40
Re: 4 stroke snowmobile oil [Re: FastLane] #5371195 03/09/20 02:08 AM
U
U
My home town is Brandon, Manitoba. When I was about 12, it got down to -51F. Winnipeg is typically colder by a few degrees.There are jokes about the Golden Boy, cold enough to freeze the.......
Petro-Canada (Holly Frontier) Duron 0w30 & 0w40 are other HD options. Rotella 0w40 T6 another.
PC also has old skool 15w40 and 20w50 HDs in their Duron line.
www.lubricants.petro-canada.ca
Re: 4 stroke snowmobile oil [Re: Brian553] #5371196 03/09/20 02:21 AM
O
Olas Offline
O
I'd vote for
Delvac 1 ESP 5w-40
Rotella T6 5W-40
Mobil 1 FS 0w-40
10 points to the guy who considers climate!
Re: 4 stroke snowmobile oil [Re: FastLane] #5372274 03/10/20 09:04 AM
F
FastLane Offline OP
F
-25C. No colder. Really I probably wouldn’t ride below -20. I ran Supertech 5W30 in it this year. No issues. Spun over quick at -20. Last weekend it hit +4C on the ride home. I think this season is over.
2007 Yamaha Nytro
Re: 4 stroke snowmobile oil [Re: FastLane] #5393415 04/04/20 10:48 AM
R
repairman54 Offline
R
0-40w M1 in my '09 & '13 1200 Ski Doo's . That's what viscosity BRP recommends. 9500 miles on the '09 and no starting issues at -20 f . Motors runs 5k rpm mostly and not worth being cheap for a few bucks on a very expensive motor.
John
Anything you say can & will be misquoted & used against you
'16 Equinox 3.6 AWD
'11 Tahoe LTZ
'15 2.5 Malibu
'17 Continental 2.7 twin turbo
FLHR
SkiDoo 1200's
Sea Doo GSX
Re: 4 stroke snowmobile oil [Re: FastLane] #5399791 04/10/20 09:30 PM
T
Thetruck454 Offline
T
I'm looking for another oil for my pair of Nytros too. Not only does it call for a 0w-30 API SG or higher, but it also says JASO MA or higher. The JASO is for motorcycles with wet clutches, yet the Nytro doesn't have one so that spec confuses me. I was all set to run M1 0w-30 AFE until I stumbled upon that little tidbit.
Re: 4 stroke snowmobile oil [Re: FastLane] #5425518 05/10/20 12:11 PM
F
FastLane Offline OP
F
JASO because the starter has wet clutch. I found a little comment in the owners manual. I’m just running Pennzoil 0W30. No issues. Not too concerned.
2007 Yamaha Nytro
Re: 4 stroke snowmobile oil [Re: FastLane] #5430858 05/16/20 06:42 PM
I
irv Offline
I
A little late to the party but I have been running Mobil-1 0W-40 European Formula in my 08 Vector since I purchased it in 2010. A year from now or next spring, I will be switching to your brand in Pennzoil 0W-30 as well.
Not that I've had bad luck or anything with the Mobil but I like Pennzoil products better and have been running them exclusively for quite a while now in all my other vehicles. (I just used up my last bit of Mobil this spring)
Curious, what are you guys using for filters? Since 2010 I have been using Hi-Flo filters, a HF-147 to be specific. Rumor has it these guys/company make them for Yamaha anyways. Same with Yamalube, Yamaha does not have its own refinery.
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: 4 stroke snowmobile oil [Re: FastLane] #5435441 05/21/20 08:57 PM
F
FastLane Offline OP
F
I run the Fram PH6017A on my Nytro. Fits but it’s longer than factory. No issues. Seems like a decent filter.
2007 Yamaha Nytro
Re: 4 stroke snowmobile oil [Re: FastLane] #5435442 05/21/20 08:59 PM
F
FastLane Offline OP
F
[Linked Image]
[Linked Image]
2007 Yamaha Nytro
