RV's for MD's
by 02SE - 04/07/20 01:42 AM
Crawfish, It's A Louisiana Thang!
by BlueOvalFitter - 04/07/20 01:01 AM
M&P .40 Magazines $12.99
by BlueOvalFitter - 04/06/20 11:30 PM
Lots of Big Sur pics, only one of the car :-)
by SLO_Town - 04/06/20 09:24 PM
'16 Pilot Inline ATF filter
by parshisa - 04/06/20 08:55 PM
2019 Ram 1500 Classic
by Skippy722 - 04/06/20 08:53 PM
STP S3614 XL CUT OPEN
by 53' Stude - 04/06/20 07:15 PM
Kia Rio awful sound after sitting 5 years
by antonmnster - 04/06/20 07:13 PM
Cut open Motorcraft FL820S
by PantherFan88 - 04/06/20 06:38 PM
240V Electric Hookup Questions
by 92saturnsl2 - 04/06/20 06:33 PM
license plate frame with 3rd brake light
by wings&wheels - 04/06/20 06:12 PM
Wurth HHS 2000
by ejt - 04/06/20 06:06 PM
Snapper drive belt install trouble LT300
by spk2000 - 04/06/20 05:56 PM
installing garage LED shop light help needed
by FirstNissan - 04/06/20 05:20 PM
Casite filters
by opus - 04/06/20 05:16 PM
Oil for Jeep
by rokwldr - 04/06/20 05:12 PM
Kitchen sink faucet leak help
by 97prizm - 04/06/20 04:45 PM
RIP Al Kaline.
by PimTac - 04/06/20 04:36 PM
Frankentruck power steering question
by Thomcat316 - 04/06/20 04:11 PM
Comment from Miata track on Amsoil GL-4
by Bill_W - 04/06/20 03:28 PM
BludRacing, Cacciatore, Thomcat316, NTexian, LateLifeCrisis
71116 Registered Users
31 registered members (blufeb95, edhackett, Char Baby, 73guna, alcyon, 3 invisible), 1,140 guests, and 20 spiders.
Topics303,700
Posts5,240,225
Members71,116
So, I kinda fudged up... #5367171 03/04/20 02:09 PM
N
nthach Offline OP
N
I'm in the process of reviving a Kohler Command 11 engine - cleaning up the carb and replacing the fuel pump due to California gas. In the process of tearing down the carb, I had to somehow get a welch plug removed. I used a screw and a hammer but that just deformed the plug. I then took a small 1.5mm flatblade screwdriver bit as a drift and managed to get the plug out.
The passages weren't damaged thankfully. But, the edge where the welch plug seats against is damaged, I did gouge the aluminum. It's not in a critical area but it could interfere with the carb working via an air or vacuum leak.
I was planning on using nail polish or a smear of epoxy to seal the plug after I drive the new one in. Will that work or just buy a new Chineseium carb?
Re: So, I kinda fudged up... [Re: nthach] #5367175 03/04/20 02:15 PM
demarpaint Offline
I'd get a Chineseium carb. In machines that I pulled out of the garbage, fixed and sold or used, I had great luck with them. They saved me a lot of time installing them, vs. a rebuild, when a carb was in need of a rebuild vs. a good cleaning.
God Bless Our Troops
Re: So, I kinda fudged up... [Re: nthach] #5367215 03/04/20 03:14 PM
Schmoe Offline
What's a welch plug???
01 Supercrew Lariat 4X4
06 Accord EX-L V6
2018 CRV EX-L
2017 Accord Coupe V6 EX-L 6AT
Re: So, I kinda fudged up... [Re: Schmoe] #5367220 03/04/20 03:18 PM
V
vw7674 Online Content
Online Content
V
Metallic plug that seals the end of a drilled passageway in a carb body.
Like a miniature version of a freeze plug in an engine block.
Re: So, I kinda fudged up... [Re: nthach] #5367230 03/04/20 03:31 PM
Schmoe Offline
gotcha! Thanks.
06 Accord EX-L V6
2018 CRV EX-L
Re: So, I kinda fudged up... [Re: nthach] #5367253 03/04/20 03:55 PM
samven Offline
If you have a tube of RTV gasket maker laying around you can smear it over the plug and wipe it off, just leaving a bit to fill the edges. Since its not a hot surface or likely to come into constant contact with gas any color will work. If you dont have that just try bathroom silicon caulk.
Re: So, I kinda fudged up... [Re: samven] #5367305 03/04/20 04:42 PM
N
nthach Offline OP
N
I do have some RTV and Shoe Goo - I'll use the RTV first. That way I don't need to buy a 1-time use epoxy syringe and make a mess.
Re: So, I kinda fudged up... [Re: nthach] #5367520 03/04/20 08:18 PM
I
Imp4 Offline
I
Just use Permatex Ultra Black.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: So, I kinda fudged up... [Re: nthach] #5367581 03/04/20 09:26 PM
R
RyanY Offline
R
A lot of these Welch plugs are expanded and don't need sealant. Here is a discussion on the tractor forum (https://www.mytractorforum.com/threads/welch-plug-sealant.93060/). Of course, if you fudged up the surface this may not work; in that case RTV or the special loctite product would be my choice.
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >107k miles; STP (Amalie) 0W20 + ACDelco PF2057
Re: So, I kinda fudged up... [Re: nthach] #5367750 03/05/20 06:28 AM
L
Lubener Offline
L
Don't RTV or shoe goo anything in the carb, it likely won't last. You likely will get a new Welch plug with a carb kit. Very last resort would be JB Weld.
The "thinking" man's friend.
Re: So, I kinda fudged up... [Re: Lubener] #5368064 03/05/20 01:24 PM
N
nthach Offline OP
N
I meant after I drive in a new welch plug - a smear of RTV or Shoe Goo on the outside of the welch plug. Not on the inner part where the air passages are. cool
Re: So, I kinda fudged up... [Re: nthach] #5368116 03/05/20 02:11 PM
1
1978elcamino Offline
1
In the past I broke part of the stand that holds the locating pin on the float in the carb. Before I bought a new carb I used JB weld and repaired it. It worked for a couple more years then I sold it. I would tap the welch plug back in and seal it with JB weld. The repair I did in the bowl was located in a place where it was submerged in fuel.
Re: So, I kinda fudged up... [Re: vw7674] #5368228 03/05/20 04:17 PM
dlundblad Offline
This is interesting. I have an older B and S that may need a new carb. I looked into the Chinese carbs on eBay and right where the choke should be, there’s a plug.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: So, I kinda fudged up... [Re: nthach] #5369817 03/07/20 11:56 AM
J
JTK Offline
J
I wouldn't even have taken the time to mess with the original. Store it somewhere safe and mail order a new one.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: So, I kinda fudged up... [Re: nthach] #5381942 03/21/20 09:20 AM
R
racinjason Offline
R
If you want to seal it, re install the Welch plug and seal it with clear fingernail polish.
