Forums Migration
Please read this thread
DIY Injector cleaning - What cleaner?
by Spetz - 07/13/20 12:50 AM
Rock Auto promo code
by daves66nova - 07/12/20 11:09 PM
05 Dodge 4.7 L head gasket blown again
by vwmaniaman - 07/12/20 09:44 PM
How come every vehicle’s MPG computer is off?
by OppositeLocK - 07/12/20 09:37 PM
Glock Gen 5 .40 Caliber
by BlueOvalFitter - 07/12/20 08:34 PM
Help me determine if my CVT fluid has been changed
by Dallasmale1970 - 07/12/20 08:01 PM
Hyundais, Hyundais, Hyundais!
by csandste - 07/12/20 07:57 PM
Traveller's (WPP) $10.99 - 5 QT
by Gene K - 07/12/20 07:26 PM
PEAK 10X or Peak Global Lifetime
by pbm - 07/12/20 07:25 PM
Nio stock. How high will it go?
by motor_oil_madman - 07/12/20 05:34 PM
AAP Rotella Gas Truck Clearance
by Sam_Julier - 07/12/20 05:32 PM
Any 47RH Transmission Experts? CTD Ram
by JHZR2 - 07/12/20 04:58 PM
WM Magna1 10w30 gallon $5
by 2strokeNorthstar - 07/12/20 04:55 PM
I found a WWII movie for yinz to watch.
by JimPghPA - 07/12/20 04:45 PM
Jackpoint Jackstand Review
by RamFan - 07/12/20 03:03 PM
Lesabre Brake fluid capacity
by Ihatetochangeoil - 07/12/20 02:56 PM
Baking Cookies in the Car - 2.0
by Nick1994 - 07/12/20 02:17 PM
Dealer ruined my transmission!!!!
by John344 - 07/12/20 02:04 PM
Mark_C, fxxkat, Ajreitano, Slick122, Ford4life76
71917 Registered Users
28 registered members (19elantragt, blufeb95, ctechbob, daves87rs, Dallasmale1970, cadillactech, 1 invisible), 885 guests, and 31 spiders.
Topics307,781
Posts5,317,714
Members71,917
MC 75W-140 @ 44.9k; 15 Fusion PTU 135k #5365111 03/02/20 10:48 AM
ssamaroo01 Offline OP
Just thought I'd share this one.
[Linked Image]
2018 Explorer Platinum 3.5L Ecoboost 27k
2015 Fusion Titanium AWD 2.0L Ecoboost 139k
2012 Escape Limited 2.5L Duratec 48k
2000 E-250 4.2L 92k
MC Filters
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: ssamaroo01] #5365149 03/02/20 11:16 AM
J
jcartwright99 Offline
J
Any reason you stuck with Motorcraft? I know a lot of Fusion owners that have switched to Amsoil or Mobil 1. I did my first one at the dealer so Motorcraft was used. I think next time I'll use Amsoil.
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: jcartwright99] #5365151 03/02/20 11:19 AM
No reason in particular other than I have it on hand. And from the report, it seems to be doing the job so far.
2000 E-250 4.2L 92k
MC Filters
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: ssamaroo01] #5365169 03/02/20 11:35 AM
J
J
It looks like it's doing its job which is good to see.
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: jcartwright99] #5365173 03/02/20 11:37 AM
Thanks.
2000 E-250 4.2L 92k
MC Filters
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: ssamaroo01] #5365251 03/02/20 01:06 PM
Snagglefoot Offline
Is this the PTU that doesn’t have a drain plug? A magnetic plug is also a great way to gage wear. Yes, I realize slivers of steel are not the same as ppm.
It’s still complicated to get a baseline because of the conditions under which it operated, such as how much torque splitting was going on etc. How much driving on slippery roads vs cruising down a dry highway. Thanks for the post. frown
If you want the job done right......do it yourself.
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: Snagglefoot] #5365254 03/02/20 01:14 PM
Originally Posted by Snagglefoot
Is this the PTU that doesn’t have a drain plug? A magnetic plug is also a great way to gage wear. Yes I realize slivers of steel are not the same as ppm.
It does have a drain plug. I haven't really thought about using a magnetic plug before but I might give it a try if I can find one.
2000 E-250 4.2L 92k
MC Filters
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: Snagglefoot] #5365286 03/02/20 01:50 PM
I'm not sure how to measure or trend the torque split. Most of my driving is on dry pavement, but I do drive in the rain and snow being that I live in the northeast.
2000 E-250 4.2L 92k
MC Filters
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: Snagglefoot] #5365301 03/02/20 02:07 PM
M
mpgo4th Offline
M
Torque splitting is happening in the rear electronically. The PTU is turning if the car is moving.
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: ssamaroo01] #5365302 03/02/20 02:08 PM
B
benjy Offline
B
if you can spend $$$ on Scamsoil may as well use the better redline lubes, but for most mobil or other similars are more than adequate.
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: ssamaroo01] #5365319 03/02/20 02:25 PM
T
thastinger Offline
T
How do you manage to pull a sample from this thing? I holds barely more oil than the size of the blackstone sample bottle LOL
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: mpgo4th] #5365328 03/02/20 02:42 PM
Snagglefoot Offline
I'm certainly no expert on this. Given what you said then, it sounds like there is not much going on inside the PTU, except having the rear end calling for torque, and that torque is also seen in the gears of the PTU, sort of like on, off, on, off, as the rear wheels call for torque. That should cause some wear.
smile
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: Snagglefoot] #5365340 03/02/20 02:52 PM
Haha. I know right! Luckily it has a drain plug or I'd be scratching my head on this one. Now only if the rear diff has a drain plug too....
smile
There doesn't sound like a lot is going on, but there are tons of failures of these PTUs.
Mpgo4th is right. The PTUs are always spinning. The newer designs have PTUs that only spin when there is a demand. My PTU holds less than 12oz of oil.
2000 E-250 4.2L 92k
MC Filters
Re: MC 75W-140 @ 44.9k; 15 Fusion PTU 135k [Re: ssamaroo01] #5366360 03/03/20 02:48 PM
M
mpgo4th Offline
M
The PTU turns if the wheels are turning. They speed up and slow down with the wheel speed of the vehicle. The PTU turns the drive shaft to the rear end unit at the same time as it turns. The rear coupling unit lets the power free wheel until commanded to engage the rear differential. That's how the rear wheels get powered.
