Pennzoil Ultra Additive Fallout in Sump
by 5AcresAndAFool - 04/01/20 07:50 PM
2008 BMW M3, BMW TwinPower Turbo 10W-60, 4915 mi
by d00df00d - 04/01/20 07:41 PM
2017 Corvette / Mobil 1 ESP 0w40 / 7.1k miles
by dparm - 04/01/20 07:40 PM
Just when you think it can't get any worse
by Chris142 - 04/01/20 07:40 PM
VIRGIN NAPA PRO SELECT 21334
by 53' Stude - 04/01/20 07:18 PM
M1 5W30 EP Users ?
by ChrisD46 - 04/01/20 07:15 PM
VIRGIN MO-899 CUT OPEN
by 53' Stude - 04/01/20 07:06 PM
When to replace a battery?
by Chris142 - 04/01/20 06:49 PM
Blauparts 15% off double rewards
by sloinker - 04/01/20 06:14 PM
Ordered some VW 0-20 for my Beetle
by widetrax - 04/01/20 06:10 PM
Mobil 1 210-A Cut open
by kstanf150 - 04/01/20 05:56 PM
Buying tap and die set. SAE or metric first?
by HawkeyeScott - 04/01/20 05:47 PM
Yahama 189cc OPE engine?
by 92saturnsl2 - 04/01/20 05:17 PM
Insulating underlayment on concrete floor
by MoneyJohn - 04/01/20 05:07 PM
Black Silicone ADBV?
by The Critic - 04/01/20 04:25 PM
RxP gas kicker
by pbm - 04/01/20 04:02 PM
Pennzoil Extended Care -Ford EcoBoost?
by ls973800 - 04/01/20 03:59 PM
Rotella 5 gal bucket at Fleet Farm $39.99 AR
by biggusblockus - 04/01/20 03:46 PM
Mobil ones email response to bad oil filter.
by Micahmcmeen - 04/01/20 03:09 PM
ripcord, KenoshaWizard, junipertoxic, mtnrider, Rickborn
71072 Registered Users
119 registered members (ABomb369, 5AcresAndAFool, 53' Stude, alanwayne1908, 55hambone, 19 invisible), 1,809 guests, and 20 spiders.
Topics303,450
Posts5,235,463
Members71,072
Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs #5365733 03/02/20 09:09 PM
B
bronx Offline OP
B
I stumbled across this fluid shopping for my Subaru Outback. I can't find much info on the fluid, but it looks like it could be an alternative to Subaru OEM fluid???
ATF-SCV is formulated for Subaru & Mitsubishi Transmissions that require CVTF-II & CVTF-J4 Fluid.
https://aisinaftermarket.com/uploads/nu4qa786_ATF-SCV_Product_Annoucement.pdf
[Linked Image]
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: bronx] #5365861 03/02/20 11:51 PM
M
Mitsu4B11 Offline
M
Take a look at Castrol Transmax CVT. I have it in my Mitsubishi requiring J4 spec, and Castrol's PDS states it meets Subaru's i-CVT and i-CVT FG specs as well. It can be had for $5.83/qt on Amazon pretty regularly (6qt case for $35).
'15 Mitsubishi Lancer 2.0L (4B11) // Pennzoil Platinum 0W-20
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: bronx] #5365974 03/03/20 07:31 AM
J
Jimzz Online Happy
Online Happy
J
Only issue with Castrols CVT fluid is the color, its red. So if you ever have any CVT issues the dealer/manufacture may push back. I used a lot of aftermarket fluids and praise them. But for my customers I use a fluid that has a similar color while under warranty.
yup
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: bronx] #5365982 03/03/20 07:41 AM
G
Gebo Offline
G
It is an alternative. But why not just use what was designed specifically for your Subie if you plan on keeping it for a while?
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: bronx] #5366137 03/03/20 10:33 AM
P
Pelican Offline
P
Be careful, Subaru doesn't source out AT boxes they manufacture their own Auto Trannies. So it may be OK and it may be not.
Only you can decide.
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: Jimzz] #5366157 03/03/20 10:51 AM
slacktide_bitog Offline
Amazon has a couple CVT fluids that are green and at a great price, not too much more than Castrol smile
Transtar (sold individually)
Cam2 (sold by the case of 12)
Valvoline CVT is amber, a neutral color that shouldn't cause any color conflict, but it is a bit more expensive ($7/qt at Walmart)
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: bronx] #5377970 03/16/20 04:24 PM
B
bronx Offline OP
B
I went ahead and ordered the Aisin ATF-SCV for my 2013 Subaru Outback and did a fluid change.
My observations:
The original fluid had 55K miles on it. It was brown like used motor oil with a green tint
I haven't seen the Subaru CVTF-II fluid in person, but from the pictures online, the ATF-SCV looks like a similar shade of green, much better looking than the brown green fluid that came out.
Both new and used CVT fluids smell like sulfur, similar to gear oil.
Post fluid change, no noticeable differences in driving and noise.
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: bronx] #5378500 03/17/20 10:14 AM
J
JTK Offline
J
Thanks for the update bronx!
It's a bit odd that this fluid is recommended for both Subaru and Mitsubishi applications given they're different CVTs. Like said above Subaru supposedly makes their own units and Mitsubishi uses Jatco units. Plus you're talking a chain CVT vs the Jatco belt.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: JTK] #5378634 03/17/20 12:48 PM
B
bronx Offline OP
B
Is it odd? Considering most aftermarket CVT fluids specify belt and chain compatibility (Amsoil, Valvoline, Eneos)
AMSOIL Synthetic CVT Fluid provides exceptional metal-to-metal frictional properties to help prevent belt and chain slipping and help extend transmission life.
ENEOS ECO CVT FLUID is applicable for both belt and chain pulley types of CVTs.
Valvoline CVT Fluid is recommended for use in most belt and chain-driven continuously variable transmissions and will not void new car warranties.
Re: Aisin ATF-SCV fluid for Subaru and Mitsubishi CVTs [Re: bronx] #5379505 03/18/20 11:55 AM
J
JTK Offline
J
Good point on that.
Even Nissan Jatco units can have a belt or a chain. The Pathfinder CVT uses a chain and uses the same NS-3 fluid recommendation as the belt versions.
