Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
Downshift before WOT?
by Avery4 - 05/26/20 08:01 PM
Getting a free 1997 Chevy 1500 extended cab
by FADEC - 05/26/20 07:22 PM
Got new tires for the trailer today
by BeerCan - 05/26/20 07:06 PM
how much cca is necessary for a truck battery?
by apollo18 - 05/26/20 06:17 PM
Electric car charge cord review
by OVERKILL - 05/26/20 04:55 PM
faulty bosch right angle drill
by benjy - 05/26/20 04:14 PM
2017 Accord Hybrid Brake Fluid Flush
by Tundragod - 05/26/20 04:12 PM
06 GMC Hybrid
by hardheaded - 05/26/20 03:57 PM
98 Camry busted oil drain plug
by JeffKeryk - 05/26/20 03:31 PM
Picked up a used Honda Push Mower today
by redhat - 05/26/20 02:43 PM
Mevotech vs. MOOG
by pbm - 05/26/20 01:47 PM
Any experience with MU-MIX ?
by henni - 05/26/20 01:22 PM
RA code
by Koncrete_Cam - 05/26/20 12:12 PM
Bruce_S, Rwogs, MechEnDawg, jimbacot, MowerVet
71537 Registered Users
93 registered members (01rangerxl, 4WD, 92saturnsl2, Astro14, amblerman, 10 invisible), 2,304 guests, and 60 spiders.
Topics305,923
Posts5,282,817
Members71,537
Page 2 of 2 1 2
Re: Efficiency of Mahle Filters? [Re: IndyFan] #5364911 03/02/20 05:47 AM
dlundblad Offline
I like the brand. I mostly run these in the wife’s Volvo. If RA is sold out, I’ll get a Mann, but they usually end up a little wavy. The Mahle always looks new and is the cheapest option to boot.
I might have to try these on my brothers 2016 Jeep. What year is your Pentastar OP? (Sorry if you have it in your signature, can’t see it on my phone.) I believe they made a change around 2014. Lately we’ve just been using Mopar. Always seems to hold up the best.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Efficiency of Mahle Filters? [Re: 2015_PSD] #5365114 03/02/20 10:51 AM
2015_PSD Offline
Originally Posted by 2015_PSD
I was curious about this as well so I send a request to Mahle asking for the efficiency rating for the OX1213D. I will post back here if they reply.
Very disappointing, but not unexpected (I replied stating they did not answer the question and will update this thread if they do):
Originally Posted by Mahle
Thank you for your recent Inquiry.
Question: Can you tell me the efficiency ratings for the Mahle oil filter for this engine which is a Mahle OX1213D? Thanks in advance!
Answer: Our filter is made to exactly meet the matching OE specifications for form, fitment & function.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Efficiency of Mahle Filters? [Re: IndyFan] #5365202 03/02/20 11:58 AM
2015_PSD Offline
Here the "answer" such that it is (ZeeOSix - can to make a guesstimate?):
Thanks for the response, but you did not answer the question. What is the efficiency rating of an OXD filter? [email protected]%, [email protected]%, etc.
Answer: The only published data available for our filter is the material which is Cellulose & the Nominal Micron rating which is 13. Most of the efficiency information is proprietary due to OE agreements. Rest assured the Mahle filter will meet all necessary OE replacement guidelines. It is a direct interchange from the most current Chrysler OE number 6819134AC.
History:
Date From Message
2020-03-02 MAHLE Our filter is made to exactly meet the matching OE specifications for form, fitment & function.
2020-03-02 MAHLE Thanks for the response, but you did not answer the question. What is the efficiency rating of an OXD filter? [email protected]%, [email protected]%, etc.
2020-03-02 MAHLE The only published data available for our filter is the material which is Cellulose & the Nominal Micron rating which is 13. Most of the efficiency information is proprietary due to OE agreements. Rest assured the Mahle filter will meet all necessary OE replacement guidelines. It is a direct interchange from the most current Chrysler OE number 6819134AC.
Re: Efficiency of Mahle Filters? [Re: 2015_PSD] #5365454 03/02/20 04:30 PM
Z
ZeeOSix Offline
Z
"Nominal Efficiency" typically means the efficiency at 50%. So that would equate to 50% @ 13 microns in this case.
Beta 2 = 50% = Nominal Efficiency
Beta 75 = 97.8 % = Absolute Efficiency
[Linked Image]
[Linked Image]
Re: Efficiency of Mahle Filters? [Re: ZeeOSix] #5365482 03/02/20 05:07 PM
2015_PSD Offline
Can you extrapolate to what it might theoretically be at 95%?
Re: Efficiency of Mahle Filters? [Re: 2015_PSD] #5365488 03/02/20 05:15 PM
Z
ZeeOSix Offline
Z
From an earlier post in this thread, and basing it off their 50% @ 18u spec for the OC 1177:
The specifications for OC 1177 are:
Beta Ratio:
50% -- 18 micron
75% -- 24 micron
90% -- 28 micron
So my best guess would be around 90% @ 20u and 95% @ 25u.
Re: Efficiency of Mahle Filters? [Re: ZeeOSix] #5365572 03/02/20 06:34 PM
2015_PSD Offline
Beta Ratio:
50% -- 18 micron
75% -- 24 micron
90% -- 28 micron
Thanks Zee; I must have missed it. I surmise the efficiency is not too bad then and likely in line with **most** filters like it (except perhaps a FRAM Ultra).
Thanks again.
Re: Efficiency of Mahle Filters? [Re: IndyFan] #5365627 03/02/20 07:21 PM
Z
ZeeOSix Offline
Z
^^^ Any time. 95% @25u isn't too far off from standard WIX at 95% @ 20u.
Re: Efficiency of Mahle Filters? [Re: ZeeOSix] #5365631 03/02/20 07:25 PM
I
IndyFan Offline OP
I
Still better than what Wix told me about their standard filters. I can't remember the exact figure but it was worse than that.
WIX standard oil filters (not the XP) are 95% @ 20 microns. That's much better than 50% @ 18 microns.
That's not what they told me a couple months ago. Maybe they gave me wrong info or have published new data. Where did you see that? I'm talking standard Wix, btw, not their premium filter.
Typically it's shown on WIX's website in the beta ratio info. I'm thinking someone at WIX doesn't know what they're reading from.
What filter number did you ask about? I'm assuming "their premium filter" you mean the XP full synthetic filter.
I asked about the filter for the newest Pentastars. Fram equivalent 11665.
18 Jeep JLUR Wrangler 3.6 31k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 29k
08 Jeep Wrangler 3.8 141k
04 Jeep Grand Cherokee 4.7 111k
99 Mercedes E430 Sport 90k
Re: Efficiency of Mahle Filters? [Re: dlundblad] #5365635 03/02/20 07:26 PM
I
IndyFan Offline OP
I
It is a 2018 JL with the Pentastar Upgrade, or some call it the Gen 2 Pentastar. Same as in current Wranglers and Grand Cherokees.
Re: Efficiency of Mahle Filters? [Re: IndyFan] #5365673 03/02/20 08:14 PM
Z
ZeeOSix Offline
Z
Is it the WIX WL10010?
If so, WIX shows the beta ratio as 2/75=13/35 which means 50% @ 13u and 98.7% @ 35u. So yeah, it's worse than their typical spin-on efficiency of 95% @ 20u.
https://www.wixfilters.com/Lookup/PartDetails.aspx?Part=1876852
Re: Efficiency of Mahle Filters? [Re: IndyFan] #5365749 03/02/20 09:30 PM
2015_PSD Offline
Yes; a WIX WL 10010 is the "base" WIX filter for the latest gen of the 3.6L Pentastar engine.
Re: Efficiency of Mahle Filters? [Re: IndyFan] #5365980 03/03/20 07:40 AM
Sayjac Offline
As noted by others I suspect it will be very difficult to find authoritative Mahle efficiency information, ie, in the form of 'published' in standard ISO 4548-12 notation. That said, I bet that no different than the Mopar OEM cartridge. That being the case, the Mopar may or may not be even at the level some of the beta information posted previously. Lots of vehicles, even members vehicles here running OEM filters with unknown efficiency.
Based on that I'd say if authoritative efficiency data a priority, then imo likely should chose a filter that provides that up front.
Re: Efficiency of Mahle Filters? [Re: IndyFan] #5366143 03/03/20 10:37 AM
F
Farnsworth Offline
F
Mahle is an old company well respected, whatever media they choose will probably be the best they know how to make. Or buy, maybe media isn't even made by most companies. Seeing the Champ Labs synthetic with the black wire square mesh it sure looks just like the Wix Platinum. One is rated [email protected] the other not. What are the chances two companies would come up with identical looking media down to the wire mesh each on their own. Zero I would say are the chances.
Page 2 of 2 1 2
