Couple Q's on pulling axles from my '99 Camry: do I need to drain the transmission first, and can I use a pry bar to pop the axle out of the case? I'd like to avoid the brute force method with a slide hammer. [Would it be the transmission or the diff that needs draining? Now that I think about it, it's not the trans that would be drained, if at all, since it's to separate sumps on this car.] I realize the axle nut has to be pulled, along with either the ball joint or the strut, so that the knuckle is free to get out of the way.
[At some point I want to reboot the CV's but right now I just want to unload the wheel bearings and see how they feel--I think I have one going bad on me.]
