I don't believe it's the same oil as the SAE 30 HD. The CF rating on the label points to it as being diesel oil, similar to the Rotella SAE 30. If it doesn't have an SJ rating on the back of the label, I would pass. I'm using the Super Tech SAE 30 HD in the quart bottles and they are gasoline engine approved.
Printed On: March 19, 2019
Description
WALMART HD 30 6/1QT WSE
Inspection Information Test Method Typical Value
Gravity, °API
ASTM D287
29.85
Specific Gravity @ 60°F (15.6°C) ASTM D4052 0.877
Flash Point, °C
ASTM D92
210
Flash Point, °F ASTM D92 410
Viscosity @ 40°C, cSt
ASTM D445
87.96
Viscosity @ 100°C, cSt ASTM D445 10.94
Viscosity Index
ASTM D2270
110
Pour Point, °C (°F) ASTM D5950 -33°C (-27°F)
High Temperature / High Shear Vis at 150°C, cP
ASTM D5481
3.38
Noack Volatility, % loss ASTM D6375 6.1
Color
ASTM D1500
3
Zinc, wt. % ASTM D5185 0.085
Phosphorus, wt. %
ASTM D5185
0.077
Calcium, wt. % ASTM D5185 0.132
Sulfur, wt. %
ASTM D4951
0.3
Magnesium, wt. % ASTM D5185 0.043
Boron, wt. %
ASTM D5185
0.018
Molybdenum, wt. % ASTM D5185 0.004
Sulfated Ash, wt. %
ASTM D874
0.92
Nitrogen, wt. % ASTM D4629 0.086
TBN, mgKOH/g
ASTM D2896
7
Claims Information
API SN PLUS
Approved
API SN Approved
API SM
Meets Requirements
API SL Meets Requirements
API SJ, SH, SG, SF, SE, SD, SC
Meets Requirements
